hello,
i am planning to add a new hdd (750gb). i have a sata 2 seagate 750gb hdd (32mb buffer). i want to ask that is it necessary to use them in raid mothed or something like, beacuse i am not familiar with it ??
also, do i have to add same make and capacity of hdd or i can get other ??
thanks btw
Just connect your new HDD and it will work fine. Btw, you can use any make n capacity drive.
i have a spare 4-pin connector in the psu. motherboard has some converters which convert 4pin connector to sata connector.
my 6800gt is more than a electric store. it has 100c + temperature. hoping 4850 will run cooler. my budget is 12k(+1 max). so i want to buy a 1gb card.
