Old 31-10-2008, 07:09 AM   #1 (permalink)
Pragadheesh's Avatar
Unhappy problem with my sony DVD drive.
my sony dvd drive (DVD RW DW Q-120A) which i bought 2.5 yrs back,is not reading files greater than 20mb or so. I cannot copy or open the files. It is reporting I/O device error.
but no problem with smaller files of size less than 10mb. they are working fine..
also there is no problem when i write any contents on the dvd. the only problem is with reading files over a specified size.
i tested the dvds on other computers. its working perfectly.
so what would be the problem with my drive?
thanks in advance.
Pragadheesh is offline
Old 31-10-2008, 07:21 AM   #2 (permalink)
iChaitanya's Avatar
Default Re: problem with my sony DVD drive.
Damn, Sony strikes yet again.
Hand that drive over to the service center. I guess there's nothing anyone can do here.
@iChaitanya
iChaitanya is offline
Old 31-10-2008, 07:50 AM   #3 (permalink)
It doesn't matter!
Sumeet_naik's Avatar
Send it for repairs and pray its a small mechanical problem..
Sumeet_naik is offline
Old 31-10-2008, 08:12 AM   #4 (permalink)
Legen-wait for it-dary!
dheeraj_kumar's Avatar
Try reflashing your firmware from www.liggydee.cdfreaks.com or give it to the service centre. Most likely it will get solved if you flash the firmware.
dheeraj_kumar is offline
Old 31-10-2008, 02:16 PM   #5 (permalink)
your problem cable and chance the data cable.than go to BIOS setup.
alok raj is offline
Old 31-10-2008, 03:44 PM   #6 (permalink)
Ya, try upgrading your firmware 1st... before taking it to the service centre.
Raccoon is offline
Old 03-11-2008, 08:28 PM   #7 (permalink)
@dheeraj kumar
the link is not working.
is the the same link as this? http://liggydee.cdfreaks.com/page/en/
i checked this link http://tdb.rpc1.org/#FLASHERS but could not find any firmware for my drive model.
Old 03-11-2008, 11:38 PM   #8 (permalink)
My Sony DVD writer not reader self writed cd & DVD.
But those it destroy my some CD & DVD.
goel.suraj is offline
Old 26-11-2008, 04:24 PM   #9 (permalink)
i checked the drive in my friend's system and it is working fine. but the problem persists in my system. i can burn data but cannot copy or open any file. what would be the problem?
help me plz....
sony dvd drive tray is not opening? evewin89 QnA (read only) 5 30-09-2008 01:13 AM
dvd writer problem sony Sony AW-G170A brijand Hardware Q&A 6 25-07-2008 11:35 AM
Sony DVD RW Drive VarDOS Hardware Q&A 29 08-06-2008 01:18 AM
SONY DVD ROM drive nats10 Hardware Q&A 3 18-10-2006 07:15 PM
SONY COMBO DRIVE robogeek QnA (read only) 3 24-09-2005 02:17 AM
- by bhaskar
