Old 30-10-2008, 05:57 PM   #1 (permalink)
15.0 GHz
VarDOS's Avatar
Default Help!!!...Keyboard Problem
Hi Friends,
Yesterday I cleaned my keyboard by removing all its keys..I washed those keys and kept them for drying whole night..Today morning I again put it right back..but the problem is WINDOWS KEY and the EDIT key are pressed in. Rest all were fine and Key 1 on NumberPad is not working..Can anybody help solving the prob???
Thanks
Varad
VarDOS is offline
Old 30-10-2008, 06:27 PM   #2 (permalink)
Democracy is a myth
rhitwick's Avatar
Default Re: Help!!!...Keyboard Problem
Remove and put again.
"My opinions may have changed, but not the fact that I am right."
"I'm never wrong. Once I thought I was wrong, but I was wrong"
rhitwick is offline
Old 30-10-2008, 07:12 PM   #3 (permalink)
Legen-wait for it-dary!
dheeraj_kumar's Avatar
Take the 3 keys off, take a screwdriver, slowly prod the soft plastic thingy below the keys, till they are straightened up. Put the keys back. Enjoy.
dheeraj_kumar is offline
Old 01-11-2008, 09:09 AM   #4 (permalink)
15.0 GHz
VarDOS's Avatar
The KEY 1 is working fine not but WINDOWS KEY and EDIT KEY when pressed remains always in.
VarDOS is offline
Old 01-11-2008, 04:57 PM   #5 (permalink)
^^ Repeat what I said till it works fine.
Keyboard Problem RaghavKanwal QnA (read only) 2 20-07-2008 12:05 PM
Problem with keyboard Kalyan Hardware Q&A 1 10-09-2007 06:32 PM
Keyboard Problem ChaiTan3 Open Source 19 03-07-2007 08:21 PM
Keyboard Problem.. vandit Hardware Q&A 13 19-09-2006 02:46 PM
Keyboard Problem bendre123 QnA (read only) 1 30-06-2005 11:55 AM
- by bhaskar
