Hi all,
I am using a Hp V3155 au laptop.
AMD Turion 64 MK-36 (2.0 GHz), NVIDIA GeForce Go 6150
I am not using it for gaming but for normal MS office, net browsing etc.
but its overheating.
The GPU temp under idle- 67 C to 75 C and under load- 80 C.
The temp. of hard disk and CPU varies between 45-55 C.
I am using speedfan with automatic fan control.
I keep my laptop plugged in and rarely use it on battery.
now do I need a cooling solution or is the temp. normal??
should I buy a laptop cooler pad?
if Yes, please suggest me a good, durable, value for money laptop cooler pad, that I can buy from Nehru Place , Delhi.
thanks a lot
