Old 29-10-2008, 10:19 PM   #1 (permalink)
harish_21_10's Avatar
Unhappy SMART failure predicted
Hi..i have an Acer Aspire 5672WLMI laptop..2yrs old now..i have been getting SMART failue predicted message during booting...i downloaded HD Tune and found the HDD temp going upto 55c with normal operations i.e browsing net..no movie..no music..and here what the HD Tune shows:
HD Tune: ST9120821AS Health
ID Current Worst ThresholdData Status
(01) Raw Read Error Rate 100 253 6 0 Ok
(03) Spin Up Time 95 94 0 0 Ok
(04) Start/Stop Count 98 98 20 2137 Ok
(05) Reallocated Sector Count 1 1 36 13028 Failed
(07) Seek Error Rate 81 60 30 162079718 Ok
(09) Power On Hours Count 89 89 0 9705 Ok
(0A) Spin Retry Count 100 100 34 0 Ok
(0C) Power Cycle Count 98 98 20 2173 Ok
(BB) (unknown attribute) 1 1 0 65535 Ok
(BD) (unknown attribute) 78 78 0 22 Ok
(BE) Airflow Temperature 45 27 45 924713015 Ok
(C0) Power Off Retract Count 100 100 0 546 Ok
(C1) Load Cycle Count 1 1 0 356966 Ok
(C2) Temperature 55 73 0 55 Ok
(C3) Hardware ECC Recovered 60 43 0 152554580 Ok
(C5) Current Pending Sector 100 100 0 0 Ok
(C6) Offline Uncorrectable 100 100 0 0 Ok
(C7) Ultra DMA CRC Error Count 200 200 0 0 Ok
(C8) Write Error Rate 100 253 0 0 Ok
(CA) TA Counter Increased 100 253 0 0 Ok
Power On Time : 9705
Health Status : Failed
What i wantd to know is,if i change the hard drive when it dies how do i get back the OS?as the laptop came with Genuine WinXP home edition...is there a way to retain the OS copy nd use the same with the new hard drive?
NOBODY is PERFECT and i am NOBODY
harish_21_10 is offline
Old 30-10-2008, 03:09 PM   #2 (permalink)
It doesn't matter!
Sumeet_naik's Avatar
Default Re: SMART failure predicted
Make a copy/image/ghost of the partition wit norton ghost...
Sumeet_naik is offline
Old 30-10-2008, 11:00 PM   #3 (permalink)
by doing this i wont be losing the OS and can restore the same on the new HDD?
I did a backup of the primary partition using the Windows Backup option,will that be fine too??
Old 31-10-2008, 02:13 AM   #4 (permalink)
You wont loose the OS if you ghost it. But if you ask me, thats not the best idea - a fresh install of XP will get rid of gunk and all and is likely to give you much better performance. But for that you need an XP disc. You cant get that thru ghosting and all.
You may however not be able to ghost it in the 1st place... if you disk is returning read errors.
Raccoon is offline
Old 31-10-2008, 08:14 AM   #5 (permalink)
Legen-wait for it-dary!
dheeraj_kumar's Avatar
READ:
http://www.ariolic.com/activesmart/s...ors-count.html
http://forums.pcper.com/showthread.php?t=451503
Like the second link says, use the Seagate tool.
dheeraj_kumar is offline
Old 31-10-2008, 10:04 AM   #6 (permalink)
tht means i will loose the OS if i use the Windows Backup option to backup the partition?
Originally Posted by dheeraj_kumar View Post
I already used Active SMART and the Seagate Tool....both show a SMART fail...ActiveSMART shows my HDD health to be low and also sayd that i might have to soon chnge it....
Old 31-10-2008, 03:25 PM   #7 (permalink)
Cant recall the details about Win backup. Never used it either. But I guess you will almost definitely loose the OS. Back up utilities are not usually ment to back up an OS!
I guess your disk will be in warranty. You should back up your imp data asap... and claim warranty.
Raccoon is offline
Old 31-10-2008, 10:19 PM   #8 (permalink)
Its an laptop and is out of warranty...
any idea if microsoft will be able to help?coz i have the WindowsXP key sticker on the back of my lappy...cant afford to loose an genuine OS..
Old 31-10-2008, 11:10 PM   #9 (permalink)
If you can get a XP Home install CD from somewhere and then use your current serial, I guess MS might authenticate your XP as genuine. As far as I can remember, MS checks for some specific hardware to see if you are the same person. Cant recall more details at the moment. Wait and see if someone else here gives you a better answer.
Raccoon is offline
Old 12-03-2009, 07:58 AM   #10 (permalink)
Hi frienz! You can go to http://www.acerpanam.com to get back your driver. Its free download or u can sms me at hairy77power@hotmail.com i can give u a serial for uniblue driver scanner 2009. For uniblue program, you can surf to http://www.uniblue.com downloads & install. Use the serial i pass to you once you email to me. You can use uniblue to install back all your acer driver.
Posted again:
Kai Hansen is offline
HELP : SMART failure predicted on Hard Disk anish_sha Hardware Q&A 6 01-04-2008 02:20 PM
Smart Hdd?? varunprabhakar Hardware Q&A 1 03-01-2007 08:21 PM
Smart neyo Hardware Q&A 9 10-07-2006 08:38 PM
smart movie mohitgiri Mobiles and Tablets 1 05-06-2006 11:37 AM
what is smart net and how to use it? kin.vachhani QnA (read only) 3 08-03-2006 11:10 AM
- by bhaskar
