My new system is up and running but i need some help.
-MSI's Dual Core center shows CPU temp @ 43c,is that normal?
-ATI Catalyst Center shows 0c!?
-My screen flickers at times with red patches when switched on and then gets back to normal
-What should be my screens refresh rate?
-I have set the resolution to 1680x1050 which is my monitors Native resolution,but everything looks very thin an long
-What is the best softrse to track my GFX and CPU temp?
Im using the stock cooler for my CPU and i have a 120mm exhaust fan and two 80mm intake fans.should i make them faster and how do i do that?
Note-im using Vista Home Basic
tq
