Old 29-10-2008, 12:07 AM   #1 (permalink)
BLah.. Blah..blah.......
Sooraj_digit's Avatar
Default Laptop now or in next semester
Hey guys,
Staying in hostel, i m planing for buying a laptop in the next semester...
My priorities are:
1. It must have decent graphics capabilities not insane but mid-core, since i love playing games and i have graphics desining courses in the next semesters... it must have good support for games which should be able to play the latest games not at the max resolutions but at mids.
2. It must have good audio capabilities.... I love music
3. Storage-160-320 would suffice it.
4.RAM 1-3 Gbs
5. Screen size should be at least 15.4" i would be great if it would be 17" but not lower than 15.4"
6. Any suitable Core 2's would do and what about core 2 quads, when are they gonna be included in laps i could give it a another think too, if they are going to be included in future.
My budget decided on it is 35K-40K if i am buying it now or else if i would be buying it at March or April i could increase it to 45K.
I need suggestions... many suggestions...
Thanks in advice...
Sooraj_digit is offline
Old 29-10-2008, 12:14 AM   #2 (permalink)
At Hell's Disq
hellgate's Avatar
Default Re: Laptop now or in next semester
u wont get a gaming lappy in that budget.u sud min spend 60k for ur type of needs like gaming at mid res etc.almost all lappies within 45k come with onboard gfx solns.dedicated gfx cards in lappies r available in 50k and above.
hellgate is offline
Old 29-10-2008, 12:57 AM   #3 (permalink)
Point Blanc
I do not understand why people want to add gaming ahead of each reqs.
Dude its a system so you can play solitaire always
Youneed to check a good config than just saying gaming system/laptop
Bro, C2D + gfx card is hell more costly right now and creates alot much heat, why will they put a C2Q now to make it more bad.
Laptop is a laptop (closed space having all the hardware) having gfx card is good and you can play good games also but frankly it will get so much heated that you would think twice (I think I am sounding the same in each of my sentences)
acewin is offline
Old 29-10-2008, 01:18 AM   #4 (permalink)
damn busy...
utsav's Avatar
u cant do graphics designing on a 45k laptop. you need a dedicated gpu for it and as said by hellgate they will cost 60k+
MSI GX660 with ATI 5870 :grin: ultimate gaming lappy :grin:
Dell Studio 15(1555)
1TB+1.5TB external|N86|ZTE Blade|5230|E63|EP-630|Soundmagic PL50|Sennheiser CXL 400|Meelec M11P+
www.techjunkiez.com
utsav is offline
Old 29-10-2008, 12:45 PM   #5 (permalink)
ok renewing my priorities
any entry level graphics chipset suggestions which i should be looking for... also tell me about the processors which are good for laptops... if not graphics card and C2d's then which combination should i be looking for i didint ask for the ones which are perfect but the one which should just do or just help with my needs... since i will not be designing gaming graphics but just mild ones since i m in a bachelor degree course...
about proccies i asked for which are coming but not which i m gonna buy
At last i should say that please give me with suggestions which are helpful as well as which onborad solutions are good for my purpose... my budget is a little tangilbe
please supply me with tips...
Old 08-11-2008, 09:35 AM   #6 (permalink)
Pease some body... I need suggestions...
Locate Laptop - locates your stolen laptop! parthbarot Technology News 11 16-03-2008 11:29 AM
Laptop Lan Config error work only with laptop not with pc minniawochat PC Components / Configurations 4 19-09-2006 03:21 PM
- by bhaskar
