Old 27-10-2008, 08:51 PM   #1 (permalink)
Question Suggestion for buying a new PC
Friends i need a suggestion for buying a gaming PC
I have these 2 set of options
In the 1st set suggest about which processor to go for weither
AMD® Phenom™ X4 9650 or AMD phenom X4 9850"black edition"
Also suggest me some good graphics card which is less than 5000 quite good enough to play high ended games.Is the graphics card which i have mentioned above in the list good..
Please suggest me for the good one..if any changes please do tell
Thanks
surenther.ss is offline
Old 27-10-2008, 10:07 PM   #2 (permalink)
Bond, Desi Bond!
desiibond's Avatar
Default Re: Suggestion for buying a new PC
Dude. I don't understand one thing.
You spend 10k for mobo and buy a pathetic graphics card?
My suggestion would be this:
Processor: Intel Core2Duo E8400: 8.5k
Mobo: MSI P45 Neo-F: Rs.5.5k
Palit HD4850 : Rs.9k-10k
You don't need to buy a soundcard for SBS A500. For those speaekrs, onboard audio is more than enough.
HDD 640GB Western Digital sata2 : Rs.3.5k
2Gig Kingston RAM: 1.5k
600W Cooler Master SMPS: 3.5k
Cooler master Elite 330 Black: 1.8k
Creative T6060 speakers : 3.5k or Logitech X530 for 4k or Altec Lansing VS3251 for 3k
desiibond is offline
Old 28-10-2008, 10:41 AM   #3 (permalink)
At Hell's Disq
hellgate's Avatar
dont even think bout getting a X4 9850 B.E.
its nothing more than a piece of sh!t.had used it 4 bout a week and sold it off.the E8400 oc'd kicks its a$$ anyday.
with my current config i get a 3DMark06 score of 16840 but with the same card on a X4 9850 @ 3GHz and MSI K9A2-GM i used to get 13367.
hellgate is offline
Old 28-10-2008, 03:26 PM   #4 (permalink)
EXIT: DATA Junkyard
comp@ddict's Avatar
GO with this, get Q6600 if u can
U'd be a fool to get what u mentioned in the 1st place.
And read Hellgate's personal exp. to tell u why!
About me:
http://about.me/preetam_nath
comp@ddict is offline
Old 28-10-2008, 08:19 PM   #5 (permalink)
toofan's Avatar
Go with Desi bond's configuration. At present time this is the best solution you can get with good vfm.
Check my work at:
http://www.flickr.com/photos/vimaljoshi
toofan is offline
Suggestion for buying new mobile for rs. 13k nitansh Buying Advice 25 03-05-2008 02:11 PM
Microwave buying suggestion ! indian_samosa Chit-Chat 13 05-12-2007 07:56 PM
HTC Touch - Buying suggestion gdatuk Buying Advice 22 08-11-2007 05:05 PM
Any suggestion On buying Home PC for gameing dilpedilip Hardware Q&A 3 04-11-2006 03:01 PM
Buying Laptop suggestion needed eagle_y2j Hardware Q&A 7 31-08-2006 01:23 PM
- by bhaskar
