Old 26-10-2008, 12:55 PM   #1 (permalink)
15.0 GHz
VarDOS's Avatar
Default Help Installing !!!
Hi Friends,
I brought a wireless headphone on 24th from Lamington Road, Mumbai...I am unable to Setup the wireless connectivity....I have got the following things.
Transmitter, Headphone, Audio and microphone with connect line, Y type adaptor {2 in 1 "RCA plug to female stereo socket "}.
Can anybody help me connecting the wireless setup...
VarDOS is offline
Old 26-10-2008, 01:37 PM   #2 (permalink)
RMN
Default Re: Help Installing !!!
i guess it would help the guys here figure it out if you specify the brand and model.
RMN is offline
Old 26-10-2008, 05:05 PM   #3 (permalink)
15.0 GHz
VarDOS's Avatar
The Brand Is Intex & The Model Is Galaxy IT-901FM
Here goes the link : http://www.intextechnologies.com/ent...one&pro=Galaxy
Here Are The Pics
Line-In Cable
Head Phones
Transmitted Connected To RCA - Female Stereo Jack (Like Given In The Manual)
Transmitter
VarDOS is offline
Old 26-10-2008, 07:40 PM   #4 (permalink)
RMN
"I am unable to Setup the wireless connectivity"
im sry but what exactly do you mean?
is it that the receiver is not connecting with the head phone?or.....?
btw looking at the pic i guess its supposed to be connected to a stereo system coz it has RCA cables.may be get a converter.
RMN is offline
Old 26-10-2008, 07:47 PM   #5 (permalink)
I am not sure about Intex, but I have a Sony wireless headphone. The headphone unit has a scroll wheel to adjust the frequency. Check yours. It should have something similar to match up its frequency with the transmitter.
Bandu is offline
Old 27-10-2008, 08:51 AM   #6 (permalink)
15.0 GHz
VarDOS's Avatar
It means that...I put the transmitter(photo 5) into the audio out on my Soundcard & Added battries to the transmitter..as well as...in the headphone....my headphone has scan button and reset button...
The first step is to on the transmitter and then press the reset button on the headphone and then press the scan button on the headphone...unless u get the song being played...
VarDOS is offline
Help Installing XP SP2.. latino_ansari Software Q&A 6 15-04-2008 07:30 AM
re-installing xp...? karina_got_it Software Q&A 4 12-02-2008 02:48 PM
help installing xp maverick007 Software Q&A 1 17-01-2006 08:49 PM
Help in installing 2 OS navino87 QnA (read only) 1 27-04-2005 08:37 PM
installing khin007 Open Source 1 11-02-2005 11:36 PM
- by bhaskar
