Old 25-10-2008, 11:09 PM   #1 (permalink)
Thumbs down Motherboard Change or PC upgrade ?
HI
I have Pantium 2.8c GHz process, Intel865GBF mother board with 1.5 GB of RAM
Capactor of my Motherboard have problem, causing to PC to get hung while working quite frequently. I checked Intel's site that it has stopped supporting the Pantium4 process family and it's motherboard.
Now which option is better ? Either to replace mother board or go for CPU / Motherboard / RAM upgrade ?
Thanks
Akhil-
akhil.bansal is offline
Old 25-10-2008, 11:20 PM   #2 (permalink)
The Black Waltz
Default Re: Motherboard Change or PC upgrade ?
Replacing your motherboard will be a cheaper option. MSI P35 Neo F supports P4 Prescott processors.
#krow @ irc.freenode.net
Cool Joe is offline
Old 26-10-2008, 07:57 AM   #3 (permalink)
Bond, Desi Bond!
desiibond's Avatar
MSI P35 Neo is not compatible with Pentium 2.8GHz.
MSI board comes with Socket 775.
afaik, that particular processor uses Socket 478.
You cannot get new mobo for this processor. You may have to check for second hand boards.
Or you need to get new proccy mobo and ram.
desiibond is offline
Old 26-10-2008, 10:21 AM   #4 (permalink)
The Black Waltz
What I was saying was, P35 supports P4 Prescott processors. I don't know if this one's a Prescott or not.
Cool Joe is offline
Old 26-10-2008, 10:37 AM   #5 (permalink)
Bond, Desi Bond!
desiibond's Avatar
That P4 must be Socket 478 (as per the motherboard)
Old 26-10-2008, 01:53 PM   #6 (permalink)
Get some cheap upgrade like E2140/ASUS P5KPL-VM/2GB DDR2 667MHz RAM
If you still wanna buy new mobo... some shops here still stock old 845 based Mercury mobos. Dunno about big cities like Mumbai, etc.
"No one can ever change this animal I have become..."
Jack Carvar is offline
Old 26-10-2008, 02:30 PM   #7 (permalink)
The Black Waltz
Yep. His proccy is a P4 Northwood, and so it won't go with the P35.
A cheap upgrade would be
Intel C2D 2140/2180
MSI 945G Neo F
Kingston 1 GB DDR2 667/800 Mhz
Cool Joe is offline
Old 26-10-2008, 02:35 PM   #8 (permalink)
^^Actually ASUS P5KPL-VM will be better with G31 IGP
Old 26-10-2008, 09:36 PM   #9 (permalink)
The Black Waltz
^^But it will also be costlier.
Cool Joe is offline
Old 26-10-2008, 11:23 PM   #10 (permalink)
2.8k
Motherboard upgrade to support PCI-express graphics card with no change in processor ManojJumani9999 Graphic cards 1 23-08-2008 03:27 PM
NOKIA 6630 -- upgrade or change...!!! sunandoghosh Mobiles and Tablets 27 16-01-2008 11:07 PM
motherboard upgrade help.. gsmsikar CPU / Motherboards 8 06-03-2006 03:47 PM
graphic card upgrade(PCI) or motherboard upgrade? thetopcyborg Graphic cards 5 13-01-2006 02:32 PM
Upgrade only motherboard prasad_den CPU / Motherboards 4 13-10-2005 08:10 PM
- by bhaskar
