Old 25-10-2008, 09:45 AM   #1 (permalink)
The Black Waltz
Default UPS needed
Plz recommend a good UPS with back up time of at least 10 mins.
It will be used to drive a PC with a 600W PSU.
Recommend anything cheap- within 3K- 3.5K.
#krow @ irc.freenode.net
Cool Joe is offline
Old 25-10-2008, 09:58 AM   #2 (permalink)
Default Re: UPS needed
Go for APC - BACK- 650 = Costed around 3,000 rs when bought in September.
AMD 64 X2 5000+,Gigabyte GA-MA69VM-S2 ATI Radeon. Corsair 667 MHZ 1*2 GB PC 5300, Dell 19 LCD.
krinish is offline
Old 25-10-2008, 10:28 AM   #3 (permalink)
Bond, Desi Bond!
desiibond's Avatar
Get APC UPS and don't fall for the low quality UPS like Mercury
desiibond is offline
Old 25-10-2008, 03:14 PM   #4 (permalink)
The worst of the lot are Powercom, Mercury, iBall... and I'm sure many others. Dont ruin your equipment for a few hundred bucks... just get an APC.
Raccoon is offline
Old 25-10-2008, 04:29 PM   #5 (permalink)
Quad Core's Avatar
4 a back up of 10min u can get a NUMERIC 600 AX, jus for 2k.. Y wastin d xtra 1000 bucks??
Cant Stop Rolling In The Streets of Rockfort - Addicted!!!
Quad Core is offline
Old 25-10-2008, 07:21 PM   #6 (permalink)
The Black Waltz
Yes. APC is definitely reliable. That's what I'm using currently. ^^ What about the quality??
Cool Joe is offline
Old 25-10-2008, 07:41 PM   #7 (permalink)
Section Moderator
gopi_vbboy's Avatar
Go for APC-Not bad
gopi_vbboy is online now
Old 25-10-2008, 07:43 PM   #8 (permalink)
Debian Gnu/Linux User
Sathish's Avatar
APC maintains good customer service ...
Living for Learning & Learning for Living
Sathish is offline
Old 25-10-2008, 11:01 PM   #9 (permalink)
GO for APC. I am using it from last 4-5 years. They deliver what they commit in terms of backup time. They also have a good after sales support, in case you have any problem which includes replacement of faulty UPS with another UPS.
Akhil-
akhil.bansal is offline
Old 25-10-2008, 11:11 PM   #10 (permalink)
हॉर्न ओके प्लीज़
victor_rambo's Avatar
+1 for APC if you are looking for a quality product. I have used intex UPS before that and I know how unreliable that was. APC never let me down.
Also, APC comes with surge protection. Not sure if cheap UPSes provide that.
Also, few models have LAN cable port, to protect your computer from electric storm. If you are interested, you may buy that feature too. It is well within your budget.
गीक होना माँगता
victor_rambo is offline
Old 25-10-2008, 11:16 PM   #11 (permalink)
The Black Waltz
Thanks all for your suggestions.
My choice is the APC Back UPS 600.
Cool Joe is offline
Help needed. Things needed to connect SATA HDD to... prashantmaxsteel Hardware Q&A 3 21-11-2007 12:26 PM
Help needed.... part_time_ch Tutorials 1 19-01-2007 01:09 PM
needed 2 buy a good camera????? help needed.. The Day Walker! Cameras and camcorders 5 02-07-2005 04:43 PM
- by bhaskar
