Old 23-10-2008, 10:32 PM   #1 (permalink)
Post Ram Problem: Transcend 1GB Stick vs Xion 1GB Stick.
My friend has a motherboard with two DIMM slots. On one, he has a 1GB Transcend DDR2 667MHz single stick ram, the other is empty.
Today we went out and bought another 1GB stick, but not of the same company. It's from ZION, and it is a single stick 1GB DDR2 667MHz ram as well, so both of them are similar.
The problem is, the system boots with only one of them. If I put both into the two DIMM slots, then the system won't boot. If only one of them is put into ANY of the DIMM slots, the system boots fine. In other words, the two sticks are refusing to co-exist.
What could be the problem? Timings and CAS Latencies? Isn't RAM of same type (DDR2) and same frequency (667MHz) supposed to work with each other seamlessly?
GauravCJ is offline
Old 23-10-2008, 10:42 PM   #2 (permalink)
TheSaint
NucleusKore's Avatar
Default Re: Ram Problem: Transcend 1GB Stick vs Xion 1GB Stick.
It should, let him check again
http://www.neville.in
http://www.linuxrocks.in
"The Future Is Open"
NucleusKore is offline
Old 23-10-2008, 11:01 PM   #3 (permalink)
Checked again. Just won't boot with both, but only ONE of them. What could be the problem?
GauravCJ is offline
Old 23-10-2008, 11:37 PM   #4 (permalink)
Point Blanc
what about the slots putting only one and anyone in any slot works.
Or only one slot works. or only one of the 2 sticks work.
acewin is offline
Old 24-10-2008, 09:59 AM   #5 (permalink)
Both sticks work perfectly fine INDIVIDUALLY.
Both slots work fine.
GauravCJ is offline
Old 24-10-2008, 10:55 PM   #6 (permalink)
whats ur motherboard ?? looks like motherboard support problem to me ...tell us about ur mobo model ...
chilling.....
imgame2 is offline
problem in memory stick. Help!! saubrl Hardware Q&A 1 12-10-2008 10:00 AM
Hauppauge TV Stick Problem with media center speedyguy Software Q&A 18 13-02-2008 05:47 PM
Strange problem with Sony 512 MB memory stick pro Deep Buying Advice 2 26-08-2005 06:41 PM
Old 64 meg stick DKant QnA (read only) 2 28-05-2005 10:41 AM
- by bhaskar
