Old 23-10-2008, 08:09 PM   #1 (permalink)
Time To Play The Game
Thumbs up whats more important to upgrade
As last post, with the help this forum brothers I bought:
New N95 8Gb US unlocked
Now comes the PC UPGRADE.
A small problem, I came a little short on my budget.Which makes me go for either upgrades:
Setup A)
1. E8400/E8500 INTEL C2D 3.00GHZ.
2. Ati HD 4850 512Mb.
Or get a low price model. Please see my below specs....
Intel Pentium D (Dual Core) 3.00 GHz With Ring Heatsink Fan Cooler
Intel D945 GCNL MOBO with a PCX slot.
2 X 1Gb Kingston DDR2 RAM @ 667Mhz
400W generic PSU
LG Optical Combo drive CD/CD-R/CD-RW/DVD
2 X HD 160 Gb SeaGate 7500RPM
Apocalpyse X400 Custom MOD Case with 2 Aftermarket Fans
I hav a question the if I only get HD 4850, will it run 100% even with a 500W Cooler master Extreme Power Plus and Pentium D dual core 3.00GHz processor?
Help!
thanks in advance
bilal
Intel C2D E7200-Intel D945 GCNL Mobo-2 GB Kingston DDR2 RAM-XFX 9800 GTX+ 512 MB-
600w CoolerMaster PSU-160Gb SeaGate
SATA HDD-
Windows Xp Pro SP2 Genuine Validated.
bilalarc is offline
Old 23-10-2008, 08:19 PM   #2 (permalink)
EXIT: DATA Junkyard
comp@ddict's Avatar
Default Re: whats more important to upgrade
@bilal
U wud do me and oders good, by just mentioning this
1. Budget
2. Purpose
Got ur purpose, gaming, but jus specify a budget, and i'll try to get u the best possible.
About me:
http://about.me/preetam_nath
comp@ddict is offline
Old 23-10-2008, 09:52 PM   #3 (permalink)
Smile Re: whats more important to upgrade
22,000.00 PaKRupee OR 13,501.14 INdianRupee
thats Max I can do but if there is something close enough ~1000-3000 in pakRupee I can manage.
good luck helping me in Gaming PC
Thanks in advance.
SATA HDD-
bilalarc is offline
Old 23-10-2008, 11:27 PM   #4 (permalink)
Point Blanc
Pentium D 3GHz are of no good, get Core2Duo or Dual Core E4xxx or E2xxx series.
acewin is offline
Old 24-10-2008, 04:06 PM   #5 (permalink)
EXIT: DATA Junkyard
comp@ddict's Avatar
SETUP A)
Get E7200 and HD 4830 which will be available soon
About me:
Old 24-10-2008, 10:40 PM   #6 (permalink)
Point Blanc
or E7200 and already available 9600GT, check for Palit's Sonic Edition.
sorry mate do not prices in Pak Ruppees.
what are these 2 X HD 160 Gb SeaGate 7500RPM
Are you planning to run HDDs on RAID. If not you can easily get higher capacity HDDs like 500GB and all.
Tell us what hardware you already got.
acewin is offline
Old 26-10-2008, 10:46 PM   #7 (permalink)
Sorry that HDD was old one now I hav 2x 160 Gb maxtor SATA HDD. COZ had less money when buying those HDD sata .
Well thanks again but I am still confused in the GFX card.
SATA HDD-
bilalarc is offline
Need help its important!!! dashang QnA (read only) 11 18-08-2007 02:10 AM
AMD system upgrade..err??no u all bored of upgrade forums but pls do help me...!! karthik316_1999 Internet & WWW 11 18-07-2006 08:10 PM
graphic card upgrade(PCI) or motherboard upgrade? thetopcyborg Graphic cards 5 13-01-2006 02:32 PM
Important tushar_novice QnA (read only) 4 19-03-2005 05:28 PM
- by bhaskar
