Old 23-10-2008, 01:31 PM   #1 (permalink)
Designer Here
techking_dinesh's Avatar
Exclamation problem wid segate 80gb HD
My friend is undergoing this problem
As soon as he starts the pc the option screen comes wid 4 options
normally,safe mode,wid command prompt & wid networking. Selecting any option restarts the pc and brings us back to the same screen
i tried my hd on his pc and it worked fine
i tried his hd on my pc and same prob
It is a segate hd of 80gb
how to resolve this ??
he has some important error which he does not want to loose
Warranty is over
Also tell how to format if there is no other option available
I m sorry for the typos if any
techking_dinesh is offline
Old 23-10-2008, 05:02 PM   #2 (permalink)
Default Re: problem wid segate 80gb HD
How old is the disk? More than five years?
The problem may be with the OS. Repair the operating system using installation disk and tell the results.
ThinkFree is offline
Old 24-10-2008, 10:44 AM   #3 (permalink)
Designer Here
i dont know how old the disc is
i tried inserting xp disc and then doing the repair option
but no use
he is ready to loose data
jus tell us how to format it
i dont know how to format the hd without entering the os
Old 24-10-2008, 11:06 AM   #4 (permalink)
still find time for games
arijit_2404's Avatar
Boot with your windows setup. Now instead repair option go through setup option.
you'll now get the option to partition & format existing hard disk.
PhenomII X6 1055T | Gigabyte 890GX | 4GB GSkill Ripjaws DDR3 | XFX HD5770 | Samsung 943nwx | Coolermaster Hyper TX3 | Coolermaster Elite430 | Corsair HX750
arijit_2404 is offline
Old 24-10-2008, 03:59 PM   #5 (permalink)
Point Blanc
dude go with normally, and then check if it comes back again.
If not well and good.
But if it comes again, then boot again using normally. then put the setup disc when inside window and do the repair
acewin is offline
Old 25-10-2008, 07:05 PM   #6 (permalink)
Designer Here
@arjit
ya i will try it out
@acewin
booting normally restarts everytime
i have already tried the repair option twice
Virus Problem with iPod Classic 80GB Udaya Maurya Software Q&A 12 28-11-2007 12:20 AM
80GB Hard disk problem harikesh Hardware Q&A 5 30-01-2006 12:58 PM
wats better Hitachi(SATA) 80gb or Samsung(Sata)80gb ??? King_Niral QnA (read only) 12 14-08-2005 05:11 PM
80GB, 4 OS, how to partition? tuxfan QnA (read only) 18 08-09-2004 09:19 PM
- by bhaskar
