Old 22-10-2008, 07:26 PM   #1 (permalink)
Question Monitors:Widescreen or Non-widescreen.
Widescreen or Non-widescreen ?
Which one do you prefer ? Which is the better ?
redmanc is offline
Old 22-10-2008, 07:37 PM   #2 (permalink)
M3TAL H3AD M3
skippednote's Avatar
Default Re: Monitors:Widescreen or Non-widescreen.
Obviously widescreen
I spit Rainbows.
skippednote is offline
Old 22-10-2008, 07:51 PM   #3 (permalink)
Intel OCer
amitash's Avatar
Widescreen FTW
My site: collegeclassroom.org
amitash is offline
Old 22-10-2008, 08:13 PM   #4 (permalink)
Angry Re: Monitors:Widescreen or Non-widescreen.
Why u prefer wide screen?????
a stranger is offline
Old 22-10-2008, 08:40 PM   #5 (permalink)
its the simple reason why u prefer watching a movie in theater ... the screen aspect ratio is 16:9 or 16:10 ...which looks elegant for movies and most of the people tend to like watching movie and other stuff in that aspect ratio ...it has more to do with aesthetic sense of general public ....
chilling.....
imgame2 is offline
Old 22-10-2008, 08:52 PM   #6 (permalink)
15.0 GHz
VarDOS's Avatar
W I D E S C R E E N...has more resolution than normal screen...widescreen is gr8 for viewing movies..as most of the movies comes in widescreen ration 16:9..u can have more desktop space...good for gaming...and also for surfing on net...
in short widescreen is gr8
VarDOS is offline
Old 23-10-2008, 12:41 AM   #7 (permalink)
Core i7 (nehalem) Owner
ashu888ashu888's Avatar
Widescreen any time
Core i7-920
MSi X58 Pro-E
Corsair 3x1GB
Tagan BZ1100
WD 1TB
22" Samsung 2233SW
APC SUA1500i UPS
ashu888ashu888 is offline
Old 23-10-2008, 06:56 AM   #8 (permalink)
Legen-wait for it-dary!
dheeraj_kumar's Avatar
Widescreen allows more working space. Especially for programmers, developers and designers. You can have more toolbars or more area to work, whatever you like.
You can have more icons in the desktop, and um... people can post more thoughts about why they like widescreen... cant think now, its very late night now!!!
dheeraj_kumar is offline
Old 23-10-2008, 08:40 AM   #9 (permalink)
Bond, Desi Bond!
desiibond's Avatar
Widescreen.
Simple reason. Our eyes have higher horizontal viewing angle than vertical. That is the reason why widescreen LCD's look lot easier on eyes.
It's not just aesthetics. It's science
desiibond is offline
Old 23-10-2008, 11:57 AM   #10 (permalink)
paroh's Avatar
For better resolution with wide screen a good graphic card needed
paroh is offline
Old 23-10-2008, 05:07 PM   #11 (permalink)
why make a square monitor if wide screen monitor is science ...??
chilling.....
imgame2 is offline
Old 23-10-2008, 05:12 PM   #12 (permalink)
Fullbring
Zangetsu's Avatar
While watching a movie in a widescreen we c two parallel black stripes....
the image quality is gr8ly enchanced in a widescreen
In future we will c widescreen mobiles....
PSP is also widescreen....
Widescreen: more viewing area,gr8 pleasing experience
Zangetsu is offline
Old 23-10-2008, 05:31 PM   #13 (permalink)
Bond, Desi Bond!
desiibond's Avatar
maybe because CRT tube does not allow widescreen
Old 23-10-2008, 05:36 PM   #14 (permalink)
EXIT: DATA Junkyard
comp@ddict's Avatar
Cause it's WIDE and it's a SCREEN
Get it, WideScreen!!!
About me:
http://about.me/preetam_nath
comp@ddict is offline
Old 23-10-2008, 09:14 PM   #15 (permalink)
RMN
but then when you watch a movie you don't use around 30% of the screen right?
RMN is offline
Old 23-10-2008, 09:47 PM   #16 (permalink)
Though I agree that a widescreen monitor looks better, I think it is more because of the novelty factor. Screen clarity and resolution has nothing to do with a monitor being a widescreen or 4:3.
As far as screen area is concerned please note that FOR SAME DIAGONAL SCREEN SIZE A CONVENTIONAL SCREEN HAS MORE AREA THAN A WIDE SCREEN...it's a simple mathematics calculation...infact the screen area is largeby 15-20%. That is the the reason why conventional screens are costlier than widescreen for same diagonal size. Hence saying that Widescreen allows more working space is wrong. Infact with a 4:3 monitor you can view larger portion of your drawings or documents in one go provided their native size is not in landscaspe mode.
The only advantage you get with a widescreen monitor is while watching a widescreen movie (so that you can eliminate the black stipes while retaining the aspect ratio). Infact in India the tv telecast is in 4:3 so if u watch tv on a widescreen then either it will be in incorrect aspect ratio or picture is crroped.
Ankit is offline
Old 23-10-2008, 09:58 PM   #17 (permalink)
still find time for games
arijit_2404's Avatar
in my opinion it's totally depends upon the user/viewer.
i am using 19" wide screen LCD for last 6 months after using square monitors for last 9 years(still using at workplace).
here are some points i would like to say:
1. widescreen provides more screen area than square. so if you need more screen area - go for widescreen.
2. more and more movies are coming out in widescreen format - so u can go for it if you watch lots of movies.
3. widescreens are very convenient especially for spreadsheets where you can display more on the screen horizontally. for word docs, widescreen doesn't help much.
4. on the other hand, webpages are formatted in a portrait mode and at a lower width than most screens anyway, so you'll probably get little benefit with web viewing in widescreen.
5. today's games are widescreen supported ... gaming is awesome in widescreen monitors too!
6. widescreen really helps a lots of apps like, programming editors, graphics design softwares etc.
So make a list of your work area. then point out which one works best in widescreen and which one suited best for square monitor.
now go for most voted way.
I hope some confusion is gone now.
Originally Posted by Ankit View Post
... That is the the reason why conventional screens are costlier than widescreen for same diagonal size.
This is not true. they're same now.
even if widescreen becomes cheaper tomorrow then it'll be because of popularity or manufacturing cost factor. like, DDR1 is costlier than DDR2
PhenomII X6 1055T | Gigabyte 890GX | 4GB GSkill Ripjaws DDR3 | XFX HD5770 | Samsung 943nwx | Coolermaster Hyper TX3 | Coolermaster Elite430 | Corsair HX750
arijit_2404 is offline
Old 23-10-2008, 10:18 PM   #18 (permalink)
Kalyan's Avatar
square monitors were used before with a aspect ratio of 4:3 before as that was the standard for most formats before. document reading and other activities were supporting that format. and not the main reason but one of them was the resolutions of the movies. they were in 4:3 ratio.
But now, widescreens have more advantages, as @desiibond says, its science.
eye strain: your eyes would get more tired moving vertically than moving horizontal. so, the eye strain would be minimal while using the widescreen formats.
document space: with applications growing more and more gui specific, using a widescreen would accommodate more tools/pallets in a widescreen (eg: photoshop/eclipse/flash etc.) and using them with a 4:3 monitor would give u less workspace to work.
movies: as for the movie formats, there was the scope picture which was developed to accommodate more picture in the image. in a 4:3, the image would be smaller, covering the upper and lower picture which would be of lower importance like the sky/land we could see more people/scenery in a scope/widescreen format. as a consequence, the widescreen format would be better to view these movies in this format, as the normal one would have to set the upper and lower screen areas with a black image i.e., the scope to be able to view all the widescreen picture. same is the case when viewing a 4:3 picture in a widescreen. the black scope is placed on the sides.
my view: on first looks, widescreens dont look good compared to normal ones. the ws ones look a bit smaller than the normal ones. resolution wise, the widescreen ones accomodate less no of pixels than the normal ones.
ws: 1440 x 900 = 1296000 px
norm: 1280 x 1024 = 1310720 px
the lesser no of pixels is compensated by more usable area.
hope this helps.
My config: AMD Athlon x2 5600+, Asus M2NPV-VM, Transcend 2x1GB 800MHz, XFX 8600GT 256MB, Seagate 250GB SATA2 + Seagate 500GB SATA2, LG 1752s LCD, Sony DRU v200A DVDRW, Logitech MX518, iBall Benz cab
Kalyan is offline
Old 24-10-2008, 04:06 PM   #19 (permalink)
EXIT: DATA Junkyard
comp@ddict's Avatar
I'm able to run normal 4:3 videos on my POWERDVD in 16:9 with no probs
About me:
Old 24-10-2008, 08:47 PM   #20 (permalink)
toofan's Avatar
Jet Audio do this in much better way. I use jet Audio or VLC palyer. Both have great features.
toofan is offline
Old 24-10-2008, 10:26 PM   #21 (permalink)
i was Talking about LCD there not CRT and infact widescreen CRT were made but were very costly and bulky ..since with CRT the length of tube increases as well if u increase the screen size
http://www.amazon.com/Toshiba-MD26H8.../dp/B000F9WFK4
and widescreen is in the market for different reason cos they are much cheaper to manufacture than a 4:3 format
Then, you have to keep in mind that LCDs are manufactured using a process that's very similar to the one used for semiconductors. Glass substrates are printed using lithography, depositing the TFT transistors onto the glass. It's easy to see that the more displays that can be made from a sheet of substrate, the lower the unit price will be, since the cost of the sheet of substrate is divided by the number of displays. And that's just where wide 19" displays have an advantage. On a fifth-generation substrate, measuring 1100 mm x 1300 mm, the AU Optronics, Samsung and Innolux fabs can make nine 19" monitors in 5:4 format or twelve wide-format monitors with the same 19" diagonal. That's why 19" wide panels are less expensive than standard 19"ers.
source
the above was quite some time ago but it so happens that widescreen is much more cheap to manufacture even for higher screen sizes ...and this also gives an advantage as movies and videos in widescreen can be watched gleefully
chilling.....
imgame2 is offline
Old 30-10-2008, 01:34 PM   #22 (permalink)
Norms Buster
Is Widescreen suitable for normal office apps ?
VexByte is offline
Old 30-10-2008, 01:43 PM   #23 (permalink)
EXIT: DATA Junkyard
comp@ddict's Avatar
^YES
About me:
Old 30-10-2008, 01:57 PM   #24 (permalink)
Bond, Desi Bond!
desiibond's Avatar
Imagine a 42" CRT TV. That will eat up half of the living room space. Yes, it will have superior clarity. But......
Old 30-10-2008, 02:28 PM   #25 (permalink)
IM AS MAD AS HELL!!
max_demon's Avatar
u can see 2 Spreadsheets or Pages in Office
or 2 Pages Simuntenously in Web Browser
PDFs are also good as we can see 2 pages at once , like Book
i also prefer games in Widescreen as my view of sight is is in Widescreen
also many Digital cameras allow taking pics in (widescreen) format and it looks better imo
i assume if in future there would be touch support in widescreen monitors we can use both hands simuntenously .
let me show with an example image
When someone dies in the grip of a powerful rage... a curse is born.
Kayako Saeki: Croakkkkkkkkkkkkkkkkkkkkk!
max_demon is offline
Old 30-10-2008, 03:46 PM   #26 (permalink)
Down to Earth
Its simple to why widescreen are becoming popular, Our human eye expect ratio is wide something around 16:9 or so we feel comfortable with that. and along with time movies and games have developed with wide ratio. in any way widescreen will rule the future.
tusharlad is offline
Widescreen vs. Square LCD Monitors depolo08 Hardware Q&A 29 05-06-2008 04:18 PM
Widescreen dilemma nish_higher Hardware Q&A 20 02-10-2007 11:12 PM
AOC widescreen CRT??? Is it available? bikdel TVs / Monitors 6 22-09-2007 12:03 AM
widescreen LCD gksunil Hardware Q&A 3 23-04-2007 03:40 PM
19 inch LCD monitors.(Widescreen and Normal) I Do Not Have A Username. Hardware Q&A 22 13-12-2006 12:17 AM
- by bhaskar
