sometimes when i run my pc, the smps starts this clinking noise(obviously from the fan). right now its not there but it might be there soon. when i took it to repairing it just vanished. also if i lay the pc horizontally the noise vanishes. its only there when its vertical. any ideas?
Seagate 500gb 7200RPM l Corsair 2*1GB Ram 800mhz l XFX 8800 GTS 320MB Xtreme 650/ 1500/ 950 l Asus P5N-eSLI l Core 2 Duo e6750 l Coolermaster Extreme Power 600watts SMPS l Microtek 800VA Ups l
u might be interested to check out if it is making the "clinking" sound when the fan is hitting against the vent grill..
if it is indeed the fan hitting the grill..you can try to use screw driver to prise up the grill a bit...
Reason: Automerged Doublepost
i dont thats pretty much possible since as i said its not occuring now. but it does occur and when it does im not sure i can capture it. this was also a problem a month ago when the sound was more serious
