22-10-2008, 11:52 AM
Upgrading/Replacement Suggestions
I haven't been using my PC for over a year now as I was not at my place. So now, When I plug it, it doesn't work. The Repair guy tells me, the following has gone kaput.
~ SMPS, MotherBoard (MSI RS 480), 1 of 2 500MB Trancend RAM.
What I have right now,
- AMD ATHLON 64 2800+
- 300GB IDE HDD (which I'm planning to use as external)
- And the keyboard/mouse, DVD RW, Cabinet .. stuffs
For
- It'll be used for running the Adobe PS3, Dreamweaver, PHP, MySQL and few small apps (simultaneously).
- It should be able to run forthcoming games like GTA IV, NFS Undercover. (Thats the only two game series I play.)
- Ofcourse, it'll run 24x7 and "might" get 3-4 Hours sleep in a week.
I need suggestion (with prices if you can) for these, and should work with the athlon
- Motherboard
- GFX card
- Memory (I wonder if I can get the spec to support 4GB RAM). Also, note that I have a 512MB right now.
- SMPS
- No specific budget, but considering my need, it should to be reasonable. No unnecessary power needed.
Me - Gone :(
22-10-2008, 12:12 PM
Excessive happiness
Re: Upgrading/Replacement Suggestions
Ur proccy is Socket 754, rite...
Mobo choices
MSI K8MM3-V..
MSI K8N Neo3F(Max. 2GB)
ASUS K8N-E(Max. 3GB)
GPU
Palit HD4850 - 10k(Sonic Edition if avail)
Palit 9800GTX+ - 12.5k (If u r frm Kolkata )
RAM
Transcend 2GB DDR 400MHz - around 3k....
SMPS
PowerSafe Silver 500w SMPS - 1.7k
Corsair VX450W - 3.2k
Since the socket type is Socket 754 i didnt find many options for you... And i wont find any mobos that support DDR2 ram....Hope that helps u
My First Android phone : Samsung Galaxy SL i9003 - Rooted & Gingerbread XXKPQ
Updated : superteekz_V2 ROM for XXKPQ.
PS Request
22-10-2008, 03:08 PM
Violent serenity.
1x2GB Transcend DDR2 667MHZ RAM
ASUS K8N-E
Palit HD4850 512MB GDDR3
And ya, for the PSU, get either the Corsair VX450W or CoolerMaster EP 600W.
And before you ask, the 512MB memory wont work with this new PC
Reason: Automerged Doublepost
22-10-2008, 03:15 PM
Excessive happiness
^^ Does K8N-E supports DDR2 RAM.......
PS Request
04-11-2008, 11:38 AM
Thank you @rajkumar, @KPower.
I did a bit of calculation and found that it comes around 45k in the end
Palit HD4850 - 12k
Transcend 2GB DDR 400MHz - 3k
PowerSafe Silver 500w SMPS - 2k
ASUS K8N-E(Max. 3GB) - 5k
19" / 20" Display - 15k
Speakers - 5k
320 GB SATA HDD - 3k
Total - 45k
Now, before I buy, does anyone here think I should consider buying a new PC instead ?
Me - Gone :(
04-11-2008, 12:16 PM
Excessive happiness
HD4850 is just 10k and not 12k.
19" ViewSonic - 9k
19" Dell - 12k.. for 15k you may get 22"
These are the current market prices and the price u mentioned is bit high....
And yes for 45k you buy a new PC which outburst ur current config....
If u wish to get a new PC, then here is the config
E7200 - 5.9k
MSI P45 Neo F - 5.9k
2x2GB DDR2 800MHz - 4k
Palit HD4850 - 9.7k
ViewSonic 19" - 9k
WD 640GB AAKS - 3.9k
Altec Lansing BXR 2.1 Speakers - 1.2k
PowerSafe Silver 500W SMPS - 1.7k/CoolerMaster CM450W - 2.3k
Zebronics Cabinet - 1.2k
Around 43k......
PS Request
04-11-2008, 12:49 PM
Violent serenity.
Umm... go for :-
E7200
MSI P45 Neo-F
1x2GB DDR2 800MHz RAM
WD Caviar SE16 AAKS 640GB HDD
CM EP500W
Zebronics Bijli cabinet
Samsung SH-203 optical drive
Dell 198WFP 19" LCD
Altec Lansing BXR1121 2.1 speakers
Logitech Gaming G1 Desktop kbd/mouse
04-11-2008, 08:53 PM
You guys are quick  , thanks again . So I changed my plan then. Here's the price list I came up with.
Intel® Core™2 Duo E7200 - 6k
Coolermaster EP500W - 3k
MSI P45 Neo F - 6k
Palit HD4850 512MB GDDR3 - 10k
2 x 2GB DDR2 800Mhz - 4k
WD SE16 AAKS 640GB - 4k
Altec Lansing BXR 2.1 - 1.2k
Samsung SH-203 - 2k
Zebronics Bijli - 1.7k
22" LCD - 15k
Logitech Gaming G1 K/M - 1k
Comes at around 54k . (I had rounded off prices of some components)
Now, I called up few places for the prices but most of them told me they'll call me back. The only dealer (Vertical Systems 0422-4512204) who gave me the price list told me, "Palit HD4850 512MB" costs something below 3/4k, is it correct ? Also another problem I came across was, all of 'em either did not one had Western Digital or they didn't have the 640GB model.
With Seagate 500GB, Viewsonic 22", Vertical systems quoted me price below 40K. How's it ?
Me - Gone :(
04-11-2008, 08:59 PM
Violent serenity.
LOLz  , Palit HD4850 512MB GDDR3 is Rs. 9500/-
05-11-2008, 12:47 AM
LoL. Some shopkeepers are have no idea of the product ur asking them and assume it for somethere similar-sounding. Happened with me too. some 'Computronics' shop person told me MSI P45 Neo-F was for 2.3k
Dont be reluctant to do MenTaL work.
05-11-2008, 12:51 AM
Violent serenity.
^^You should have ordered it that time itself  .
05-11-2008, 01:37 AM
IronMan; Ready to Roll...
That might have been an MSI 945.
Aluminum MacBook 2.0GHz Collector's Edition
Windows Box: 2.26G P4, 1GiB RAM, 320GB SATA + 80GB PATA HDD, Nvidia FX5200
AOC Fovi F22
iPod Touch 16GiB, HTC Gene, Moto W230, Sansa Express
05-11-2008, 12:15 PM
Excessive happiness
@thread_starter
Dude where u get those price list....
@KPowerMania
Funny siggy.....
PS Request
05-11-2008, 12:16 PM
Violent serenity.
^^Dumb shopkeeprs  .
05-11-2008, 04:47 PM
$ is below 47 rs, this may be the reason of price cut
MasalaStation.com
05-11-2008, 09:20 PM
Thats what i concluded and ended the conversation. except that i concluded they wont even be knowig what MSI is coz most shopkeepers here know only of intel boards.
23-02-2009, 11:33 PM
Thank you all for your suggestions !
I need another small favour. My old PC box is now gives me "the Stare" every time I pass by it and I was hoping to give the poor soul a second life and maybe give it to someone. But I can't spend much on it as I have already spent bit too much on the new one.
So I have concluded
Mouse/KB - Keyboard/Mouse - 1k
2GB DDR2 800Mhz- 2k
250GBHDD - 2.5k
MSI P45 Neo F - 6k
Palit HD4850 512MB GDDR3- 10k
Now the prices of the Motherboard and GFX card are bit high, can someone recommend bit cheaper ones. (Please do mention its limitations)
Also, I wanted know if it would support 800/667Mhz DDR and if it could be connected to 22" LCD (1680x1050, 60Hz Max). Just inquiring, both are optional.
Thanks a bunch and anxiously waiting for replies
Me - Gone :(
23-02-2009, 11:48 PM
damnbadman666
Check out AMD 7750 is hot now !! the price is 3.5K
23-02-2009, 11:55 PM
#19 (permalink)
Is that a mobo ?
#20 (permalink)
damnbadman666
man its proccy ???
23-02-2009, 11:59 PM
#21 (permalink)
man its proccy ???
ok. thanks!
but I already have the old one " AMD ATHLON 64 2800+" . I need others to go with it.
24-02-2009, 12:00 AM
#22 (permalink)
damnbadman666
do u bought proccy ?? INTEL ?? what model ???
24-02-2009, 12:08 AM
#23 (permalink)
Let me elaborate,
- Cabinet
- Speakers
- Monitor
I have taken suggestions of @rajkumar_pb & Psychosocial and concluded this price list
Keyboard/Mouse - 1k
2GB DDR2 800Mhz- 2k
250GBHDD - 2.5k
MSI P45 Neo F - 6k
Now the prices of the Motherboard and GFX card are bit high, and I was expecting some cheaper ones. (Please do mention its limitations)
Hope you get the clear picture now
Me - Gone :(
24-02-2009, 12:25 AM
#24 (permalink)
damnbadman666
palit 9600GT - 5.5K
Asus M3A78-EM board - 4K
is it ok for now
