Old 20-10-2008, 08:48 PM   #1 (permalink)
Default hard disk problem
hello! i am getting the following error in event viewer:
The driver detected a controller error on \Device\Ide\IdePort4.
my pc works fine for 2 days if i remove the sata cable and reinsert it.i dont no why i get this error because i hav not inserted anything in the ide port.i hav connected both my hard disk and dvd writer in SATA and my dvd writer supports only SATA.my pc config is this:
Intel core 2 duo e8400 3.0ghz
biostar tp35d2-a7
Transcend 2 gb ram ddr2 667mhz
xfx 8800gt 512mb ddr3
western digital 500gb
MOSERBAER dvd writer
i am using windows vista ultimate and it hangs occasionally due to this error.please help me.this is a brand new pc and it has almost become useless now unless someone helps me.
Nandhi ganesh is offline
Old 20-10-2008, 09:20 PM   #2 (permalink)
Default Re: hard disk problem
Hey,
just replace that SATA cable and replug your all PC Config.( put ram on another slat )
still you are receiving relace your HDD
teamonesolutions is offline
Old 21-10-2008, 11:40 AM   #3 (permalink)
ok i will do that tomorow thanks for replying
Hard Disk Problem CHALLENGER Hardware Q&A 16 26-04-2008 02:05 PM
PROBLEM WITH HARD DISK coolrupesh Software Q&A 1 01-11-2005 12:40 PM
Hard Disk Problem valtea QnA (read only) 4 14-06-2005 07:15 PM
hard disk problem Techmastro QnA (read only) 1 02-06-2005 11:46 PM
80GB hard disk converted into 10780 MB hard disk ssingha QnA (read only) 12 24-08-2004 11:57 AM
- by bhaskar
