Old 19-10-2008, 01:00 PM   #1 (permalink)
Jatin
paper_heart_21's Avatar
Unhappy help......not able to format !!
hey i have a sensei 1 gb mp3 player !!
it was working fine till a week before but today when i try to format it , it is not able to format , either it takes to much time and afterwards hangs or shows an error !!
help me !!
| HP dv6 6044tx | quad core i5 sandybridge | 8gb ddr3 | AMD Radeon HD 6490M (1 GB DDR5) | 500gb HD |
| Samsung Galaxy S2 |
:mrgreen:
paper_heart_21 is offline
Old 20-10-2008, 10:16 AM   #2 (permalink)
sharma_atul85's Avatar
Default Re: help......not able to format !!
try 2 format using d CD u might hv got with player
sharma_atul85 is offline
Old 20-10-2008, 01:28 PM   #3 (permalink)
So others are also encountering the same problem and I was thinking I got to search a lot to find an answer to this, yeah friends thats the same problem that bugging me too and as you said atul the CD that came with it is not making it easier to format. Any other suggestions!
Another thing can someone tell me about konica minolta printers.
defredey is offline
Old 21-10-2008, 03:38 PM   #4 (permalink)
Jatin
yeah cd is not helping though !!
| Samsung Galaxy S2 |
:mrgreen:
Old 30-10-2008, 01:31 PM   #5 (permalink)
Norms Buster
There may be an option in the player itself for formatting. Go & read the manual !
VexByte is offline
Normal Format or Quick Format HDD drives???? life31 QnA (read only) 6 25-04-2008 02:46 PM
Suggest how to copy movies from CD format to DVD format? please help.its urgent tomdickharry QnA (read only) 2 17-10-2006 01:14 PM
CD/DVD RW Quick Format of Full Format techtronic Hardware Q&A 6 21-06-2006 12:45 PM
video file format to 3gp format converter beanstalk_230 Software Q&A 1 20-01-2006 01:12 AM
How to convert Real Audio format to MP3 or MP4 format ??? dkd903 Software Q&A 10 23-07-2005 11:38 AM
- by bhaskar
