Old 18-10-2008, 08:06 PM   #1 (permalink)
sreenisatish's Avatar
Default System Hangs - Need Help
I am having this problem from yesterday. The system suddenly hangs, the screen goes blank and nothing works. The keyborad lights are stuck and can't be toggled.
Initially, when I was working, the screen suddenly went all blurry - like looking through crystallized glass or something and then it hung. This happened for 2 times. After this, the system directly hangs without even the blurry screen. Sometimes, the system even refuses to start up. No POST, can't even get to BIOS. So, this doesn't look like a windows problem as the system even refuses to start up.
I have 2 1GB RAM sticks. I tried removing one (fearing it is a RAM issue) of those and starting, but the same thing happens - the system restarts. You can find my system config in my signature. Any help will be highly appreciated.
E8400 3ghz | MSI P35 Neo Combo | 2X1GB Corsair XMS2 800Mhz (5-5-5-12) | XFX 8800GT ADE 512MB | CM Extreme Power + 500W | Zebronics LAVA cab | ViewSonic 19'' VA 1912WB | Segate 320GB+WD 640GB
sreenisatish is offline
Old 18-10-2008, 11:35 PM   #2 (permalink)
is NOT a PC/Mac
debsuvra's Avatar
Default Re: System Hangs - Need Help
Are you having some BSODs as well ? If you are, please state the error message here.
I think this is a display driver related problem. Try the latest GeForce driver from nVidia site and check if the problem is solved.
debsuvra is offline
Old 19-10-2008, 02:00 AM   #3 (permalink)
Nope, no BSODs.
I dont think it is a display driver problem, cause it sometimes refuses to startup - not even POST/BIOS.
Old 19-10-2008, 12:39 PM   #4 (permalink)
Legen-wait for it-dary!
dheeraj_kumar's Avatar
We have 3 suspects - RAM, Mobo, and PSU.
For RAM, try Memcheck.
For PSU, try a different PSU.
If not, its the Mobo.
dheeraj_kumar is offline
System hangs on inserting DVD chandru_skc Software Q&A 6 20-02-2008 01:05 PM
System hangs..help linardni QnA (read only) 3 10-02-2007 03:59 PM
search system hangs!! gary4gar QnA (read only) 2 23-02-2006 01:27 PM
system hangs frequently legolas QnA (read only) 7 26-10-2005 10:04 AM
HELP!!! SYSTEM HANGS TOO MUCH hsnayvid QnA (read only) 26 21-04-2005 05:27 PM
- by bhaskar
