Old 17-10-2008, 10:34 PM   #1 (permalink)
Question Suggest a CRT Television in 20K budget
As the title reads Im looking at purchasing a new 29" CRT Television in 20K,
I looked at LG and Samsung websites and the slim CRTs looks good but none of the websites seems to have any reviews about them, So any suggestion from users in this forum would be useful
BTW people might ask me why am i not looking at LCD? as we dont have any 16:9 content on Cable or DTH and i dont watch many movies on TV ( prefer Comp) i dont think LCDs are worth the money spent and I feel CRTs are much better at reproducing color compared to LCDs (may be personal opinion
Thanks
Me Me Me ........
metoo is offline
Old 17-10-2008, 10:44 PM   #2 (permalink)
Point Blanc
Default Re: Suggest a CRT Television in 20K budget
right, but long run LCDs are good. Though the screensize is less.
Most of the CRT displays are good, check with the price and features given in them
you will get very good 29 inch in 15-17K
as per me LG Samsung Philips are good for price and feature they good. Sony's price as usual is higher than them
acewin is offline
Old 18-10-2008, 09:03 AM   #3 (permalink)
99.9% Idle
axxo's Avatar
There is a model(Jumbo 34) from videocon for 13k offers big screen13", 800pmpo, 200channels, etc.
Unban praka123
axxo is offline
Old 19-10-2008, 07:25 PM   #4 (permalink)
aswin1's Avatar
Check this link for choices and reviews.
http://www.compareindia.com/products/televisions/
aswin1 is offline
Suggest a Good 29" Television in range of 15 - 25k sbhas2k QnA (read only) 2 28-11-2006 09:04 PM
My Budget is 20-25K Pls suggest the Config.... satyamy PC Components / Configurations 8 25-09-2006 12:49 PM
lappy budget=Rs. 1 Lac...suggest the best Ishan Buying Advice 8 21-09-2006 01:57 AM
lappy budget=Rs. 1 Lac...suggest the best Ishan QnA (read only) 1 17-09-2006 06:29 PM
Suggest a mob for budget around 10k ymhatre Buying Advice 11 23-02-2006 08:14 AM
- by bhaskar
