| Forum |
| Graphic cards News, discussions, queries and problems related to Graphic cards. |
#1 (permalink) |
ma card is 8500gt and i updated ma driver still the problem persists Last edited by AYmn; 09-10-2008 at 09:20 PM. Reason: Automerged Doublepost |
#2 (permalink) |
Super Moderator
Which Forceware driver..?
Which OEM..?
MSI P45 Platinum(BIOS v1.7B)|Q9550[E0]@3.85Ghz@1.320V[453x8.5]MCH@1.184V|ICH@1.55V|DDR_V_Ref_A_B@1.05V|NH-D14|Corsair TWIN2X4096-8500C5(5-5-5-15)@1089Mhz@2.14V 2xHD4890[Xfire]@1000/900[MEM/GPU]|Corsair 650TX|Seagate180GB+80GB+WD1TB|SONY-DVD-R|CM690|2x120mm Scythe Ultra Kaze|DELL S2409W|APC 1100VA|Scythe Kaze Server Windows 7 Ultimate RTM - 64BIT|Catalyst 10.5 (8.14.10.0753) forced with RadeonPRO|PS3 160GB|Sony 40EX520|AC Ryan POHD Mini|APC 800VA|APC 800VA|D425KT|CM100 Elite|2TB WD|Acer D255 Test your spoiler tags before submitting |
#3 (permalink) |
Wire muncher!
A gfx card cannot get any "virus". The problem you are most prolly experience is due to heating up of the gfx card. Check if the fan is working properly. Also try to report the temp. of the gfx card which will clear the doubt whether its due to the excessive heating of the gfx card.
"The true measure of a man is how he treats someone who can do him absolutely no good." http://phoenix-ani.blogspot.com |
#10 (permalink) |
666
pal.. you monitor is nearing "end of its life"
MSI-P35-NEO| C2D-E7300 | XV-9600GT | WD-640 | LEADTEK-DTV-1800H | CORSAIR-TWIN2X2048-6400C4DHX | ZEBRONICS-PRO M500W | SONY-DRU-V200S | LOGITECH-X90 CORDLESS |
#11 (permalink) |
Fullbring
I havent seen ne virus till date which causes such type of problem...
![]() Perhaps, ur monitor may be faulty..just check it with hardware engineer..or call customer help if its under warranty... Also do a check with GCard
Windows OS Calculator Bug Sqrt(9) - 3 = check the answer |
#12 (permalink) | |
EXIT: DATA Junkyard
Letz name the new virus pinky and white
http://pleaseguide.me/ |
#13 (permalink) |
Violent serenity.
lol....
Anyways, its either to monitor or overheating of the grafix. Monitor ur temps. with SpeedFan or RivaTuner...... anthing above 75C mark is dangerous!!
Registered pwner of theists, noobs, posers and emos. |
#15 (permalink) | |
Violent serenity.
XFX 8600GT is an Electirve Stove, it aint a grafix card. Though a little effort for XFX's side led to the XFX 8600GT UDF3 but it made a little difference. HD4850's problem is nearly sorted out and Palit is offering the Sonic Edition with new BIOS update and a new fan
#16 (permalink) |
EXIT: DATA Junkyard
SOnic official price is+++ Rs. 12000
#18 (permalink) |
EXIT: DATA Junkyard
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| Prevent/Remove Virus | Lucky Rathod | Software Q&A | 4 | 03-04-2008 05:14 PM |
| how to remove virus manually | NiluGeek | Software Q&A | 4 | 01-04-2008 11:25 PM |
| Virus Remove!!!! | Zangetsu | Software Q&A | 2 | 19-02-2008 05:42 PM |
| Unable to remove Virus | ritish | Software Q&A | 9 | 04-08-2007 09:21 PM |
| Virus ! Need urgent help to remove it. | Tech&ME | Software Q&A | 6 | 03-03-2006 07:28 PM |
