Go Back   Digit Technology Discussion Forum > Hardware > Graphic cards
Graphic cards News, discussions, queries and problems related to Graphic cards.
Old 12-09-2008, 08:05 PM   #1 (permalink)
IM ThE DEVIL
Davidboon's Avatar
Question graphic card problem
my friend got a new nvidia 8600gt 512mb ddr2 graphic card,
but he has a strange problem. he has a branded lenovo ideacentre k200 computer, his computer supports pcie x16 graphic card ,
but a strange problem occurs when he inserts his graphic card in his computer, his computer does not show the login screen i.e.the accounts does not come up.
but windows boots successfully until the login screen, without the accounts. so he could not proceed to his desktop,
the specs of his computer are
IdeaCentre K200 53123CQ
Model name --53123CQ
Description --IdeaCentre K200
Operating System
Operating System Title --PC DOS license
Software
Operating system provided --PC DOS license
Architecture
Slots x bays total (available) --4(3) x 5(2)
Orientations allowed --Vertical
Bus type/architecture --PCI/PCI Express
Form Factor --Tower
Processor
Processor Type --Intel Core 2 Duo E4600 Processor
Processor internal clock speed --2.40 GHz
Front side bus --800 MHz
Internal L2 Cache Size --2 MB
Memory
Memory (RAM) std. / max.[ --1 GB / 4 GB
RAM slots total --2 DIMM
RAM slots available --1 DIMM
Module Specifications --PC2-5300
Memory Type --DDR2 SDRAM
RAM speed supported --667 MHz
Hard Disk Drives
Hard disk controller --Serial ATA
Hard disk size[4] --250 GB
Hard disk type --SATA
Platter RPM
Graphics Subsystem
Type
Graphics bus interface --Integrated
Max colours (with max video RAM) --16777216
Description --SiS Mirage Graphic Engine
Video RAM type --DDR
Max resolution (with max video RAM) --2048x1536 16777216 colours
Audio
Description --SoundMAX Integrated HD Audio
Audio on Planar --Yes
Expansion options
Slots total (free) and type --2(1) PCI Full height, 1(1) PCI Express 1X Full height --(1) PCI Express 16X Full height
Plug and play support --Yes
Serial Port Type --1 Serial
Parallel Port Type -- 1 Parallel
Planar Expansion Port Type
RJ-45, RJ-11, Mouse (PS/2), Microphone (front), Line out (front), Keyboard (PS/2), External Display (VGA), 4 USB 2.0 (back), 2 USB 2.0 (front)
Expansion Bus --PCI Express 2.0
BIOS Type --Flash ROM
Security Chip --No
Weight & dimensions
Height --390 mm
Width --180 mm
Depth --440 mm
can anybody here solve the problem ??
AMD Phenom II X6 1055T||MSI 890FXA-GD70||CORSAIR 4GB DDR3||2 * SEAGATE 500GB + WD 500GB ||ASUS EA5870 1GB||RAZER ARCTOSA||RAZER DEATHADDER||NZXT M59||BENQ G2220HD||CORSAIR TX650W||Canon 550D
Davidboon is offline
Old 12-09-2008, 08:32 PM   #2 (permalink)
Treatment in progress...
mukherjee's Avatar
Default Re: graphic card problem
well,it seems that the bios is set to default wid the onborad graphix.
u can try going into the bios,and modifying the default display(may be there as"Display Init") to pci express,and not onboard.
keep us posted....
Core i7 2600K||Z68V Pro||Noctua U12P SE2
Vengeance 1600Mhz 8GB||GTX560Ti HAWK
CM Elite 430||1TB+300GB
VX550||G110||G1 mouse||Razer Goliathus
PX100 II||Nikon D5100
Comments required : Balanced Armature Earphones
mukherjee is offline
Old 12-09-2008, 08:37 PM   #3 (permalink)
-----ATi-----
nvidia's Avatar
^^I dont think thats the problem.. He says it boots till the login screen.
http://twitter.com/akshayms
nvidia is offline
Old 12-09-2008, 08:44 PM   #4 (permalink)
mukherjee's Avatar
but he says he inserts the card.
now bro,when can u use both IGP and addon graphix in tandem widout running into probs,other than hybrid sli/crossfire stuff?
Old 12-09-2008, 08:48 PM   #5 (permalink)
-----ATi-----
nvidia's Avatar
^^He didn't mention that his computer works fine with IGP.
nvidia is offline
Old 12-09-2008, 08:51 PM   #6 (permalink)
mukherjee's Avatar
hmmmm...so we need more informstion.
but,dont u think its got sumthng to do wid the bios?
IMO,he needs to try the card on another pc to make sure the card itself is okay!
then,we can hav a definite point to focus on....
Old 12-09-2008, 08:55 PM   #7 (permalink)
-----ATi-----
nvidia's Avatar
If in case he didn't see the computer boot in until the login screen, then he has to change the settings in BIOS and make the computer's default display out to PCIe. Otherwise its someother problem. I really don't think there is a problem with the graphics card too.
nvidia is offline
Old 12-09-2008, 10:44 PM   #8 (permalink)
IM ThE DEVIL
Davidboon's Avatar
well my friend's graphic card is all right, it works perfect on my computer .
graphic card problem adithya217 Graphic cards 22 04-05-2008 11:35 PM
HELP ME (Graphic Card Problem) Please Urgent yarasu Graphic cards 5 15-04-2008 05:34 PM
Help! Some problem with my graphic card the.kaushik Graphic cards 7 03-03-2008 12:37 PM
Graphic Card Problem vaibhavtek Graphic cards 13 19-12-2007 05:51 PM
Graphic Card Problem. Please Help Polter Graphic cards 7 26-10-2006 08:16 PM
