| Forum |
| Graphic cards News, discussions, queries and problems related to Graphic cards. |
#1 (permalink) |
AMD Athlon 64 X2 6000+ Biostar TA690G AM2 Transcend 2^1 GB DDR2 800MHZ Ram Viewsonic VA1912WB Monitor the problem is i brought an XFX 8600GT 256mb gddr3 graphic card.when i put the card in pci-e slot and connect the monitor to the card's dvi port,the monitor just stays blank saying no signal.i even changed the settings in bios like Initial display first to pci-e and even disabled the onboard graphics but still the problem persists but i can tell that the card is powered because it's fan starts running as soon as i switch the power on.what do i have to do to make the card detected?please help me! |
#2 (permalink) |
Living to Succeed
what PSU do u use
Q6600+Abit IX38QuadGT+Corsair 4gb 800mhz+ Ultra 120 Extreme+ tagan 600wts+CM690 & Alienware M15 - with Gforce 460 1.5gb + 8gb DDR + i7 1.73ghz |
#3 (permalink) |
No pain....No gain
Try clearing the CMOS and then see if the card is detected.
--------------------------------------------------- Faith is the boast of a man who is too lazy to investigate. --------------------------------------------------- |
#5 (permalink) |
Rising ApocalypsE
Try using onboard display and also use the VGA cable with the card, this may solve ur problem!
AMD Athlon 3200+,MSI RS482M4-ILD,Kingston KVR 512MB 400,Gainward 6800GS 256MB,250GB WD Caviar,Cooler Master 430Watts. |
#6 (permalink) |
i finally figured out the problem.believe me it was the dumbest reason for all.so here goes
there was some transparent tape attached to that part of the card where it has to be fixed in the pci-e slot.i removed the tape from the bottom and fixed it in the pci-e slot.now it works wonders.but i have one more doubt:is 65 c normal temperature for this card? |
#7 (permalink) |
Resistance is Futile.
^ yes it is
Super User ♦ Moderator | About me Gadgets: HP Envy 14 | Google Cr-48 | D-Link DGL 4500 | Denon AH-C360 | Fiio E5 | iPhone 3GS | Dell U2312HM |
#8 (permalink) |
No pain....No gain
Now that's real troubleshooting
#9 (permalink) |
thanks for the help guys and my card does not cross 75 c when playing a game.(FEAR,1024x768,All settings max).does the temperature in the cabinet depend on whether it is closed or open.
#11 (permalink) |
-----ATi-----
Since you are using XFX 8600GT, it could be some kind of heating issue...
Try the card on a different computer and see if it works.
http://twitter.com/akshayms |
#12 (permalink) |
Rising ApocalypsE
My friend, U are one hell of a lucky XFX 8600GT owner!
I 've seen many guys having cards running at 85 C idle. Ur's might be newer one!
#14 (permalink) |
mine is ual3.i read somewhere that the newer ual3 cards do not heat as much as the udf7 cards.so i considered that while buying.also for my config can you suggest me a good Cabinet,PSU and UPS combo for Rs.5K.with my present UPS.my pc restarts every time the power is gone and because of this the PSU i buy does not last long than 4 months.
#15 (permalink) | |
-----ATi-----
#16 (permalink) | |
mine is ual3.i read somewhere that the newer ual3 cards do not heat as much as the udf7 cards.so i considered that while buying.also for my config can you suggest me a good Cabinet,PSU and UPS combo for Rs.5K.with my present UPS.my pc restarts every time the power is gone and because of this the PSU i buy does not last long than 4 months. also will my rig be enough to play Crysis at medium resolution and medium settings?i played the game earlier with onboard graphics but quit because of crappy frame rates.and also how would rate my rig on a scale of 1 to 10? |
#17 (permalink) |
-----ATi-----
^^I have the same processor and the same gfx card... You can play crysis at medium high settings and youll get around 25FPS... Even 20FPS is enuf for a smooth gameplay in crysis
#18 (permalink) |
i actually forgot that "the article i read somewhere" is your post nvidia.sorry i forgot to mention.so is ur card still a 109 c or did they give you a replacement.
also can anyone suggest me a cabinet,PSU and UPS combination for Rs.5k.my rigs details are AMD Athlon 64 X2 6000+ Biostar TA690G AM2 Transcend 2^1 GB DDR2 800MHZ Ram Viewsonic VA1912WB Monitor Zebronics 400W PSU(Stock) Hitachi HDS728080PLA380 80GB Hard Disk SATA2 Maxtor 6L080M0 80GB Hard Disk SATA2 Sony DVD-RW AWG170A DVD-Writer and a SONY Floppy Drive |
#19 (permalink) |
-----ATi-----
^^Never got any time to contact them actually...
It runs at around 91C when im running games. But when i run 3d mark, it goes to very high temperatures... Did you try to run your graphics card on a different computer?
#21 (permalink) | ||
Rising ApocalypsE
Yeah but the buyer must be aware of UDF7 heating issues. Quote:
Cooler Master 330 Elite @1860/- (Cabinet) Power Suuply: Cooler Master RS500W @ 2650/- Amigo AM-PS500AP @ 2200/- Point of View Black Diamond 500W @ 2800/- My personal suggestion is u should stick to ur current cabinet for a while and get UPS and power supply.
AMD Athlon 3200+,MSI RS482M4-ILD,Kingston KVR 512MB 400,Gainward 6800GS 256MB,250GB WD Caviar,Cooler Master 430Watts. Last edited by keith_j_snyder2; 04-05-2008 at 12:24 AM. Reason: Automerged Doublepost |
#22 (permalink) |
For Cabinets What about Zebronics Antibiotics and Peace.Someone said the stock psu that comes with them will be enough but i dont believe them.and suggest a ups even though they cost more than 2k.
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| HELP ME (Graphic Card Problem) Please Urgent | yarasu | Graphic cards | 5 | 15-04-2008 05:34 PM |
| Dell XPS 1530 Graphic Card Problem? | Rahuldhanpat | Graphic cards | 10 | 09-03-2008 02:26 AM |
| Help! Some problem with my graphic card | the.kaushik | Graphic cards | 7 | 03-03-2008 12:37 PM |
| Graphic Card Problem | vaibhavtek | Graphic cards | 13 | 19-12-2007 05:51 PM |
| Graphic Card Problem. Please Help | Polter | Graphic cards | 7 | 26-10-2006 08:16 PM |
