Go Back   Digit Technology Discussion Forum > Hardware > Graphic cards
Graphic cards News, discussions, queries and problems related to Graphic cards.
Old 24-02-2008, 05:31 PM   #1 (permalink)
Default Dell XPS 1530 Graphic Card Problem?
I m having Dell XPS 1530 Note book and configuration is 1.6 ghz , 2 gb Ram , 256 mb geforce 8600 graphic card, Window Vista home edition.
I m playing Games llike Gun , Sim Socities , and other game whihc require 256 mb or less graphic card ............
the game crashes or become slow while playing ........ I do not know y.?
The Game "GUN" takes only 128 mb Graphic card and 512 Ram but even then its not working well... after 1 hr of play it gets crashed and msg comes " Graphic card has recover and restarted now" How can i maximize the uses of graphic card of my laptop. And how can off animation in window vista ?
Please help.
Rahuldhanpat is offline
Old 24-02-2008, 05:40 PM   #2 (permalink)
Commander in Chief
QwertyManiac's Avatar
Default Re: Dell XPS 1530 Graphic Card Problem?
Welcome to the real "Wow" experience. Unfortunately many nVidia 8xxx owners complain about the same, it just crashes for no reason at all!
What you can do:
1. Update your drivers to the latest one available at nVidia's website: www.nvidia.com
2. Disable Aero by turning off transparency & animations under Appearance window.
Harsh J
www.harshj.com
QwertyManiac is offline
Old 24-02-2008, 05:44 PM   #3 (permalink)
Where is device manager in Window Vista or what is sort name for opening it form RUN Command?
Will this increase speed of my ciomputer and overall graphic ability?
Old 24-02-2008, 07:40 PM   #4 (permalink)
is NOT a PC/Mac
debsuvra's Avatar
Wink Re: Dell XPS 1530 Graphic Card Problem?
Go to 'Control Panel' and select Device Manager.
This will mostly speed up the laptop a little bit when u are just using the OS, not when u are playing a game.
debsuvra is offline
Old 24-02-2008, 09:45 PM   #5 (permalink)
You gave been GXified
gxsaurav's Avatar
Disabling Aero on a computer which has proper support for Vista will slow down the UI, not speed it.
It is not the fault of Windows Vista, this is a bug in the graphics card driver, blame nvidia for this.
about.me/gxsaurav
gxsaurav is offline
Old 24-02-2008, 10:03 PM   #6 (permalink)
Still Confused? There is no best answer and
Did not worked at all .
Please give some other suggestions.
Old 24-02-2008, 10:08 PM   #7 (permalink)
a_g = JPKN
s18000rpm's Avatar
most proabaly its temparature problem.
keep the laptop on flat surface, not on bed/lap when gaming.
look under the lappy, there are few air vents (one for CPU, gfx. card, HDD too), make sure they are not blocked when you keep the laptop on ur lap.
d/l some temp. monitoring s/w (like m/b monitor)
try "Intel Desktop Utility" if its supported by your m/b.
ASUS K53SV SX520D + BF3
s18000rpm is offline
Old 24-02-2008, 10:21 PM   #8 (permalink)
ya I follow all these things in general.
Old 24-02-2008, 10:27 PM   #9 (permalink)
a_g = JPKN
s18000rpm's Avatar
whats the temp.?
call DELL, they might tell (guide) you in reseating the gfx. card.
Old 24-02-2008, 10:58 PM   #10 (permalink)
whats the temp.?
let me try this
Old 09-03-2008, 02:26 AM   #11 (permalink)
Hi,
As of yesterday, I am experiencing the same problem. I've had my m1530 for about a month now, and when I first received the computer I downloaded the appropriate "tweak" driver at Laptopvideo2go. Everything was just peachy until yesterday, when my computer shut down in the middle of a game (World of Warcraft) and refused to stay on longer than usual. I let it stay off for awhile and started it back up to let it cool down, but now all game performance is sluggish and the computer shuts down after about 10-15 minutes of play. I tried undervolting it a bit, and this does keep it cooler, but the game just doesn't play the same... I'm on hold with Dell support as we speak, but I imagine that this phone purgatory will last awhile.
Any suggestions?
cartergspot is offline
Dell inspiron 1530 questions. gowtham QnA (read only) 11 27-01-2008 07:41 PM
Dell inspiron 1530 questions. gowtham Mobiles and Tablets 3 25-01-2008 05:48 PM
graphic card problem[new ati sapphire 9200] rk Graphic cards 12 02-01-2008 10:42 AM
Graphic Card Problem vaibhavtek Graphic cards 13 19-12-2007 05:51 PM
Graphic Card Problem. Please Help Polter Graphic cards 7 26-10-2006 08:16 PM
- by bhaskar
