Bgi Error: Graphics not initialized (use initgraph)
Results 1 to 4 of 4
Thread: Bgi Error: Graphics not initialized (use initgraph)
  1. #1
    Mar 2005
    Default Bgi Error: Graphics not initialized (use initgraph)
    I have made a program in c++. My program is running fine, but at the
    end of the program there is a error message on the screen:
    My program shows no error message at compile time or at run time.
    What's this bgi error? How can I correct this? I have initialized the graphics hardware by using the initgraph function on the main segment
    of my program. I am using Borland Turbo c++ compiler 3.1.
    [/b]
    Popular Gadget Deals
  2. #2
    May 2004
    off to "never ever" land
    For some reason initgraph() failed. To find out why, check
    the return value of graphresult(). For example:
    #include
    int main(void)
        int gerr;   /* graphics error */
        int gdriver = DETECT, gmode;
        /* Initialize graphics using auto-detection and look
        for the .BGI and .CHR files in the C:\TURBOC directory.
        initgraph(&gdriver, &gmode, "C:\\TURBOC");
        if ((gerr = graphresult()) != grOk)
            printf("Error : %s\n", grapherrormsg(gerr));
            exit(1);
    source: http://bdn.borland.com/article/0,1410,17916,00.html
    No Mercy, No Limits.
  3. #3
    Mar 2005
    Right behind you...
    bgi error usually occur when valid graphics driver are not loaded.
    using initgraph only not solve this problem, you have to give proper path for bgi graphics drivers which are usually find in bgi folder
    use this
    initgraph(&gd,&gm,"");
    where gd=GRAPHICS DRIVER
    gm=GRAPHICS MODE
    ""=path where driver reside
  4. #4
    Mar 2005
    Default bgi error
    hey bgi means borland graphics interface.
    i think u include graphics.h without writting code for graphics mode
    here is the code:
    #include"graphics.h"
    void main()
    int d=DETECT,m;
    initgraph(&d,&m,"c:\tc\bgi");//or mentioned the path of ur turbo c3
    printf("%d",d);//this will display which driver u have (u can check it in graphics.h)
    printf("%d",m);//which mode resolution
    getch();
    try it in c extention.....
    bye
    njoy c man
  1. Intel HD Graphics with Dedicated Graphics Card
    By RazorbladeXtreme in forum Hardware Q&A
    Last Post: 02-08-2011, 03:16 AM
  2. Replies: 1
    Last Post: 19-06-2008, 12:39 AM
  3. Replies: 17
    Last Post: 04-08-2007, 02:47 PM
  4. Replies: 1
    Last Post: 10-07-2006, 03:28 AM
  5. Error error error....gives me hell of a terror
    By abhilash in forum QnA (read only)
    Last Post: 06-11-2004, 12:41 AM
