03-05-2007, 07:59 PM
Always Questioning?
Suggest Graphics Card for Vista.
I want to buy a Graphics Card for Windows Vista.
I want to consider the following:
1:- I NEVER PLAY GAMES.
2:- Need to purchase only & only for running Windows Vista Aero features.
3:- DDR2.
4:- 2.0 or 3.0 Pixel Shader.
5:- AGP 8X or PCI.
6:- 128MB
7:- Seventh & Most important,ie; It should be Below Rs 3000.
:smile: Love Digit
03-05-2007, 08:46 PM
gooby pls
Re: Suggest Graphics Card for Vista.
XFX GeForce 6200 AGP 128MB Rs 1800
03-05-2007, 09:15 PM
Always Questioning?
NOT GOOD
It is PCI Express, but I want only PCI or AGP.
So, please suggest for RS 3000, PIXEL SHADER 3.0, VISTA Compitiable, only PCI or AGP.
:smile: Love Digit
03-05-2007, 09:28 PM
gooby pls
Its AGP dude
And it is pixel shader 3.0 and windows vista compatible
More info about this card -> http://www.buy.com/prod/xfx-geforce-...203122251.html
03-05-2007, 10:17 PM
Google Bot
Wich mobo do u hv?? Get a 7300 gt
05-05-2007, 01:35 PM
Always Questioning?
Yeh it is
SORRY FOR THAT.
I am now confusing between 6200, and 6800
Which one is good to BUY,, BUT will it cost below Rs 3000?
:smile: Love Digit
05-05-2007, 02:38 PM
gooby pls
6800 is more than your budget.
06-05-2007, 10:07 AM
Always Questioning?
What it costs?
& What about Nvidia 6600. Does it have 128 and 256 MODELS?
I have learnt from somebody, that if I buy 128 MB graphics card, large number of games will not work in Windows vista, but will work on XP. Is it right that the same Game will require only 128MB in XP, but 256Mb in vista?
:smile: Love Digit
06-05-2007, 12:04 PM
gooby pls
Originally Posted by emailaatif786
What it costs?
XFX 6800 GT 256MB 8X AGP Rs 16,500
It is available in 256MB
XFX 6600 Non-GT 256MB Rs 4500
Thats not true
But i would prefer if you go for 256MB
06-05-2007, 12:31 PM
You gave been GXified
Vista requires a graphics card with 128 MB RAM if you want to run the OS upto 1600X1200 resolution.
Beyond this resolution you will need 256 MB RAM
You best bet is indeed XFX 6200 with 128 MB RAM. Since you yourself mentioned you don't play games then this is enough for you. If you can get a 7300GT AGP then buy that.
about.me/gxsaurav
06-05-2007, 02:02 PM
is there anything like this with PCI-Express ? for vista at this lowest price ....?
06-05-2007, 02:09 PM
Rebooting
XFX 6200 LE comes in Both Interface the AGP 8x and PCI-E too...
I am using the XFX 6200 LE 128MB (TV/DVI out) PCI-E cost me some 1.9k or 1.8k i think incl TAX
rebooting
ChotoCheeta.com
07-05-2007, 01:43 PM
Always Questioning?
I would like to purchase NVidia GeForce 6600 128 MB Graphics card having maximun resolution of 2048 × 1536 at 85Hz.
BUT my LG 15" CRT Monitor supports a miximum resolution of 1024 X 768 at 60Hz. Will I be able to run Vista at 1600 X 1200 resolution at that Monitor?
:smile: Love Digit
07-05-2007, 03:30 PM
Rebooting
No you may not, even if you are able to run that high resolution, but u cant work, as text and other readable sizes will be so small u may need a magniflying glass
anyway, Even i am running 1152x864 in 17" CRT which i feel is the highest in which one can work properlly !!
rebooting
ChotoCheeta.com
07-05-2007, 07:53 PM
Always Questioning?
Sorry, but I am not asking that Can I read the Text, or I need a magniflying glass?
Q:-
If I purchase 128 MB Graphics card having maximun resolution of 2048 × 1536 at 85Hz. Will my LG 15" CRT Monitor support that 1600 X 1200 resolution, or It will show "OUT of Frequency"?
:smile: Love Digit
07-05-2007, 07:55 PM
gooby pls
Will my LG 15" CRT Monitor support that 1600 X 1200 resolution?
No
07-05-2007, 08:28 PM
Macboy
Didn't know that a resolution higher than 1600x1200 needed 256MB graphics card. lucky me. But seriously dude, Vista's Aero features are useless. Not worth spending 1.8k just for some transparency and the useless flippy thing...
I'm like a bird... :)
07-05-2007, 10:56 PM
Rebooting
Q:-
I dont undersnatd, when u ur self write,
then why the question comes... ?? if the hardware cant support that how u expect to run that high ?? u have given the answer for the question in ur own post..
rebooting
ChotoCheeta.com
30-05-2007, 02:28 PM
#19 (permalink)
Always Questioning?
What LOGO or any other NOTICE/Information I have to look on Card BOX, befor buying it for Vista?
& What about 7100? What It costs?
:smile: Love Digit
30-05-2007, 02:43 PM
#20 (permalink)
GeForce 7100 is for PCI express.
Get an AGP 6200 non ultra with 128 MB RAM atleast.
Or XFX 7300 GT AGP
about.me/gxsaurav
30-05-2007, 03:17 PM
#21 (permalink)
Alpha Geek Banned
yeah go for 6200 agp version but let me tell u..... its striclty not for games...............
if you want something really cheap u can also go for any geforce fx card such as geforce fx 5200... it supports aero and has the requisite support for shader model 2.0, which is the minimum required for vista.......
the speed of fx 5200 is more than 6200...... why?...... because it has a wider bus of 128 bit whereas the 6200 has 64 bit bus......sorry... too technical.....
i use vista with aero in one of my computers with that card, the fx 5200  ......
but anyways 6200 is a good deal
Reason: cuz i had mistyped
30-05-2007, 05:52 PM
#22 (permalink)
left this forum longback
my xfx7300 GT package says it is Vista Ready..baaki i dont know
03-06-2007, 03:51 PM
#23 (permalink)
Always Questioning?
I want Card in AGP, with 256MB Memory, 3.0 PIXEL Shader, with NVidia CHIP.
Which of it is for about/upto Rs 3500, can go in 6 or 7 Series?
I will repeat all my considerations. I want to buy a Graphics Card for Windows Vista
1:- I Almost Never Play Games.
3:- DDR2......(Maybe DDR3)
5:- AGP 8X or PCI.
6:- 128 MB or 256 MB.
7:- Must Have Second Video OUT Port......(Any S-Video, DVI etc ..)
8:- Must have NVidia CHIP.
9:- Nineth & Most important,ie; It should be Below Rs 3500.
Is there any Model like THAT Available?
:smile: Love Digit
Reason: Added the considerations.
03-06-2007, 07:40 PM
#24 (permalink)
gooby pls
^XFX GeForce 7300
03-06-2007, 08:13 PM
#25 (permalink)
Always Questioning?
But it's Bus Type is PCI-Express and I want only in AGP or PCI.
:smile: Love Digit
03-06-2007, 08:48 PM
#26 (permalink)
XFX GeForce 7300 GS is also available in AGP mate.
about.me/gxsaurav
04-06-2007, 11:47 AM
#27 (permalink)
Always Questioning?
A:-Is there any PERFORMANCE difference between, NVidia Graphics Card with NVidia Chip, AND Any other Brand with NVidia Chip?
B:-Is there any COST difference between, NVidia Graphics Card with NVidia Chip, AND Any other Brand with NVidia Chip?
C:-Is there any FEATURE difference between, NVidia Graphics Card with NVidia Chip, AND Any other Brand with NVidia Chip?
What if I opt for Zebronics Brand with NVidia Chip? What is the compariable model/Brand to Zebronics?
:smile: Love Digit
04-06-2007, 01:51 PM
#28 (permalink)
ToTheBeatOfUrHeart
Dude get a quadro plex 1000 series card.It will run any os for the next century.
04-06-2007, 03:28 PM
#29 (permalink)
G.A.M.E.R
I want to sell my XFX GeForce FX 5200 card. 256 MB version. If u want to buy it then contact me.
Core2Duo E7200 @ 3.16 Ghz| ABIT IP35-E | 2GB Transcend 800Mhz | GeCube ATI HD 4850 | 250 GB Western Digital | Corsair VX450W
Dell Studio 1558
10-06-2007, 11:08 AM
#30 (permalink)
Always Questioning?
and Price?
:smile: Love Digit
