Go Back   Digit Technology Discussion Forum > Hardware > Graphic cards
Graphic cards News, discussions, queries and problems related to Graphic cards.
Old 12-04-2007, 02:54 PM   #1 (permalink)
Default Gpu- Guyz Please Help Urgent!
i have msi nvidia 6600 gt heres the pic:
http://www.3dnews.ru/documents/12529...00GT-front.jpg
now the gpu fan got burnt so i have replaced iy with a 80mm fan stuck it on top. it keeps around 55 deg w/o load but while playing it goes above 100,
can anyone gimme a better way to keep temp low during load?
i am a bit short on money.
_________________
iamitp is offline
Old 13-04-2007, 08:46 AM   #2 (permalink)
Hells_Fury's Avatar
Default Re: Gpu- Guyz Please Help Urgent!
You can try and get a third party GPU cooler but they are not easily available in India and of course they dont come cheap. I got mine for around 45$ from the US through a friend of mine.
Q6600 G0 (TR Ultra-120), ASUS P5N32-E SLI, eVGA 8800GTX Superclocked (TR HR-03 Plus), Samsung 940BW, Corsair Dominator PC2-8500, CM Stacker 830, 700GB Storage, Corsair HX620W, APC Smart 750VA
Hells_Fury is offline
Old 13-04-2007, 10:37 AM   #3 (permalink)
darklord's Avatar
_________________
80mm should do a good job,anyways reapplication of thermal paste and directing as much air as possible from the 80mm on the heatsink should improve performance of the cooler.
darklord is offline
Old 13-04-2007, 01:15 PM   #4 (permalink)
the fan should be intake, right?
iamitp is offline
Old 13-04-2007, 01:38 PM   #5 (permalink)
Hells_Fury's Avatar
Have you removed the heatsink completely or have you stuck the fan on top of it?
Old 13-04-2007, 01:46 PM   #6 (permalink)
just suck the fan on top of the copper heatsink using fevi quick
iamitp is offline
Old 13-04-2007, 01:47 PM   #7 (permalink)
Yes, intake. Remove the old fan too. Let the old heatsink be on.
If nothing else works, try keeping the cabinet side cover open.
wilderness is offline
Old 13-04-2007, 02:02 PM   #8 (permalink)
this way my temp(using nvtemp) is 55 degrees, i have just firefox open, is it ok?
iamitp is offline
Old 13-04-2007, 11:32 PM   #9 (permalink)
darklord's Avatar
Fan should suck air and blow ON the heatsink it is fitted over.
darklord is offline
Old 14-04-2007, 12:27 AM   #10 (permalink)
it does exactly that
but whne i play warhammer 40k,mark of chaos with evrything on the temp goest to 117 degrees.
iamitp is offline
Old 14-04-2007, 01:05 AM   #11 (permalink)
darklord's Avatar
I suspect bad thermal interface,reapplying thermal paste shud work.
darklord is offline
Old 14-04-2007, 09:10 PM   #12 (permalink)
Hells_Fury's Avatar
But whatever you do, just sticking an 80mm fan over the heatsink wont be enough. It wont cool efficiently. I guess the only option is to use a replacement heatsink/fan combo.
RAM woes..............Help guyz techmax Hardware Q&A 2 25-09-2006 08:33 AM
MOBILE RATES!!! for all u guyz.... Aseem Nasnodkar Mobiles and Tablets 19 30-12-2005 06:05 PM
Best buy digicam under 5.5k help guyz! techmax Cameras and camcorders 2 15-09-2005 01:23 PM
Guyz tell me the prices of ............. divyadbzgt1 QnA (read only) 10 05-08-2005 04:34 PM
--HELP NEEDED GUYZ jamifahad Gamerz 9 28-05-2005 05:24 PM
