Go Back   Digit Technology Discussion Forum > Hardware > Graphic cards
Graphic cards News, discussions, queries and problems related to Graphic cards.
Old 18-02-2007, 04:37 PM   #1 (permalink)
Unhappy Help New Graphics Card Is Crashing My System
HEY ALL, I PURCHASED XFX GEFORCE 5200 few days back and i am almost crazy with the way my gaming expirience is going to the trash.} Errors like ---> AppName: hitman.exe AppVer: 0.0.0.0 ModName: d3dim700.dll
ModVer: 5.3.2600.2180 Offset: 0000fb77} keep on appearing and game crashes every five to ten minutes please help.......
nirusam is offline
Old 18-02-2007, 05:36 PM   #2 (permalink)
The Thread Killer >:)
phreak0ut's Avatar
Default Re: Help New Graphics Card Is Crashing My System
Does this happens to all the games or Hitman in particular. I think you have tried to apply a mod patch which hasn't worked out. Try to play with the normal game. If it works out fine, then its the problem with the patch. Well, if there are more extensive issues, I'll leave it to the gamers
Want to make this world a better place? Then, start seeding and don't be just a leecher
phreak0ut is offline
Old 18-02-2007, 07:19 PM   #3 (permalink)
no patches tried and yes buddy it happens in all games
nirusam is offline
Old 19-02-2007, 07:56 PM   #4 (permalink)
phreak0ut's Avatar
You don't have to -ve rep without no reason. It sucks you know!!
Old 19-02-2007, 08:04 PM   #5 (permalink)
caleb's Avatar
What is the driver version you are using? Also it helps when you post your system config. But on the face of it it sounds very much like a driver issue but do get back with the exact driver version and the system config you are using than I might be able to help you.
caleb is offline
