Go Back   Digit Technology Discussion Forum > Hardware > Graphic cards
Graphic cards News, discussions, queries and problems related to Graphic cards.
Old 14-12-2006, 10:29 AM   #1 (permalink)
Default Does Integrated graphics mobo support DVI output
I am planning to get a new config & plan to get Intel G965RY motherboard & samsung 940BW LCD. I wanted to know whether this motherboard would support DVI output from the samsung lcd.
I read at anandtech that none of the integrated graphics mobos have dvi port. Can anyone using it confirm. Will I be able to use DVI output with this mobo.
http://www.anandtech.com/guides/showdoc.aspx?i=2888&p=2
I want to take a integrated graphics mobo only as dont plan to take a seperate graphics card. Please comment.
pulkit101 is offline
Old 14-12-2006, 02:15 PM   #2 (permalink)
Default Re: Does Integrated graphics mobo support DVI output
yeah many have it .. makes msi,asus with chipset matters..
as nvidia M2n-mx with 6150 on board has a dvi port and msi rs482-m2il has a dvi onboard.. for AMD ..
Genius_mod is offline
Old 14-12-2006, 03:51 PM   #3 (permalink)
I want to know specifically for Intel G965 RY Mobo..whether this would support DVI output on Samsung 940BW LCD.
Old 14-12-2006, 04:08 PM   #4 (permalink)
GO TO http://www.intel.com/products/mother...65RY/index.htm
__________
yeah i supports with a n extra connector
Old 15-12-2006, 09:52 AM   #5 (permalink)
I have seen that link.... There is no mention of DVI on it ... so any users using RYCK please share their views...
Old 15-12-2006, 01:37 PM   #6 (permalink)
da' Ťurntable ruleth
techno_funky's Avatar
The motherboard needs to have a DVI connector to support DVI output from what i see that mobo probably has analog VGA output connector.High end mobos from co's like asus ,msi etc have dvi connectors.You will have to buy one of these mobos or get this mobo and buy a graphics card with a DVI connector.
| Dell Studio 15 | iPod Touch 16GB (Stolen) | iPod Video 5.5G 30GB | Sony Ericsson W910i |
| Sennheiser PX 100 | Sennheiser HD 202 |Creative EP630 | Altec Lansing ATP 3 |
techno_funky is offline
Old 15-12-2006, 05:44 PM   #7 (permalink)
I dont know any mobo with onboard graphic having DVI output but I guess you can use a converter to get analog signal,940BW ships with such convertor so technically you can run this monitor using the converter but whats the point buying the monitor without a card which support wide screen.
Better buy normal LCD or go for cheaper card around Rs 4000/- atleast.
ranjan2001 is offline
Old 15-12-2006, 07:39 PM   #8 (permalink)
Techno Funky & Ranjan thanks for your views. I do want to buy a decent graphics card in the future.
What i can understand from your comments is tht with this mobo currently i would be able to get analog output using 940BW LCD.What i want to know is
1. Later when i get a graphics card with DVI output can I switch to DVI from analog?
2. Currently in the Analog output would i atleast get normal widescreen display or not ?
Please comment
Old 15-12-2006, 07:44 PM   #9 (permalink)
shantanu's Avatar
YEAH SURELY YOU CAN
you will get the widescreen display ..
can be possible that quality gets a little a little less but you will get
shantanu is offline
Old 15-12-2006, 07:50 PM   #10 (permalink)
There will be no problem what so ever switching between digital and analog just a simple change of the cable so keep your dvi cable safe.
About the WS support on analog please go ahead there will be no problems you've got a new generation Onboard GPU it certainly supports WS.
Old 17-12-2006, 08:36 AM   #11 (permalink)
Please comment
1. This monitor ships with analog to dvi convertor which fits on to your analog mobo, so yes you can remove the convertor plug it in DVI when u buy the card.
2. U will get w i d e s c r e e n , stretched display bcoz this monitor will require custom resolution of 1440x900 which mobo may not support it. So in effect you will have a analog display of 1024x768 or higher, stretched into 1440 x900 that is why I said better buy a graphic card along with it.
I am not aware if ur Intel G965RY motherboard support WS, if it does then u will not have the above problem.
- by bhaskar
