| Forum |
| Graphic cards News, discussions, queries and problems related to Graphic cards. |
#2 (permalink) |
Nvidia 6600LE is a good gfx card but it fails badly in FEAR, have to play at 800*600 resolution to get decent frame rates, it depends on which games u wanna play.
Dunno much about ATi one , sorry. |
#4 (permalink) |
Check out from here: http://www23.tomshardware.com/graphi...=570&chart=197
#7 (permalink) |
But guys based on wat i've found on the net,the X600XT supports only SM 2.0B but the 6600LE supports Sm 3.0.Based on dis i think dat 6600LE will be a better card.So i dont think dat the X600XT will be able to run games like Splinter Cell Double Agent which req SM 3.0.
#8 (permalink) |
Even the 6150 has SM 3.0 suppor...get that instead???? ehh?? And 6600 is different from 6600LE..the 6600LE features clocks @300/400 and has only 4 pixel pipelines while the 6600 has 8 PPs.. .....The 6600LE has 128bit mem interface while the 6200 is a 64bit card...and the 6600LE is just above 6200..
Sam |
#9 (permalink) |
^^There might be a fairly good chance of unlocking a 6600LE with a simple bios flash.
C2D E8400@3.8, P5N32-E SLI, 2GB Cellshock DDR2 1000(4-4-4), 8800 Ultra SLI, 2.7TB storage, CM Stacker 830, TT 1200W, Dell 2005FPW, Lots of Audio HW. |
#10 (permalink) |
@Chaos tried unlocking my 6600LE both using RivaTuner and thru BIOS flash,but didnt succeed,cuz mine is a A4 core.u can unlock only A1 & A2 cores.
@samrulez I understand wat u hav said but dat doesnt mean dat all of a sudden a X600Xt willbe able to run games which specifically req SM3.0. |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
