04-09-2006, 03:26 PM
Nvidia Display Driver (91.47 Forceware) acting up ? :( :<
Hi There! I have Asrock 939NF4G-SATA2 MOBO, Nvidia 6100 onboard integrated Graphics. WinXp Pro+SP2 + AutoPatcher XP till June . AMD 64 bit 3000+ + 512 MB DDR 400 from Zion. My DIsplay is Samsung Synmaster 798 MB plus, 17" Flatscreen CRT.
Yesterday I Un-installed my 81.98 Forceware drivers to install the latest 91.47 Force ware drivers. After installing the latest one I was unable to Get 32 bit color @ res of 1152 x 864, also @ only a Refresh rate of 72 !!
But as soon as I uninstalled the new one and Got back the old 81.98 drivers..I was able to get 32 bit color @ 1152 x 864 and also a refresh rate of 75 HZ.
This was a wierd experience. Though the new driver set comes with varied applications and eyecandy it seems they have gone wrong somewhere ?
Any one having same prob ? Let me know ur experience and if any solution.
Thx in advance
Beware of my Wrath Mortals, Thou hast no choice.
04-09-2006, 03:34 PM
Manchester United
Re: Nvidia Display Driver (91.47 Forceware) acting up ? :( :<
I recently bought Syncmaster 798MB plus and I am using forceware 91.33 drivers without any problems. In fact I have the resolution set at 1280 X 1024 @ 60Hz.
PS3-Ipod Touch 4G-Samsung Galaxy Ace-Sapphire HD 6870 Twin Frozer-Creative Zen:cloud9:
04-09-2006, 04:07 PM
OK! I hv not tried higher res. becoz invariable i won't be getting a refresh rate above 75 Hz. Pls try the res I mentioned and lemme know if u r getting a refresh rate of 75 HZ ? Also r u getting 32 bit color ?
04-09-2006, 04:32 PM
Manchester United
Ya, I am getting 32-bit colour depth. I will try higher refresh rates greater than 60Hz and let you know.
04-09-2006, 06:42 PM
@digitized
Me too has same monitor. Its very strain on eye at 1280*1240..My eyes bagan to water within 1min. I think 1152*864 @75Hz is the best, could be better if it can do 1280*960@75.
About driver 91.xx
its totaly sux..The whole driver settings menu has changed nd can't find where r those advanced settings nd all. Also began showing BSOD in most games saying nv4.dll has gone crappy nd all. Now Ive reverted back to 84.xx nd is happy with it.
Also 91.xx showed at each startup that SLI technology has been disabled as I REMOVED ONE OF THE CARD. What the h**l ..I removed a second card..from my non SLI board???This time nvidia has gone mad I think.
G3: XPS M1530 |
FZ 16.
04-09-2006, 08:17 PM
Manchester United
Originally Posted by aravind_n20
@digitized
About driver 91.xx
It cannot do more than 60Hz at 1280 X 1024. Bad luck
By the way, the new nvidia 91.XX drivers have two interfaces. You can choose either one of the classic interface or the new nvidia control panel, where you would find advanced settings in a little different way. But I agree that it has one bugging point, i.e. the notification of "SLI-multi GPU setting has been disabled". Even if you disable the system tray icon and the message through the nvidia control panel or the msconfig file, still it returns on restarting. Let's hope nvidia corrects it in their next driver release...
06-09-2006, 04:15 PM
The 91.xx drivers sux. using them when i put anti-aliasing to 2x, my screen gets all stretched. dunno whats wrong??? Also the NEW control panel is sh*t. man........i feel that the the most stable are the 80 series drivers!!!
wats gone wrong with nvidia?? so many bugs??
| C2Q Q6600 G0 | Intel DG33FB | 4 GB Corsair 6400C5G DDR2-800Mhz | XFX 8800GTX | CM Extremepower 600W | 250GB Seagate HDD | Lite-ON 1635S DVD RW | Logitech MX-518 | Zalman RS6F | APC RS 800 |
06-09-2006, 04:26 PM
Manchester United
You can choose between the new control panel interface and the old classic one from the display properties itself. And I haven't faced any issues with the 91.XX drivers upto now.
06-09-2006, 09:53 PM
The new forceware drivers gave me problems too on my 15" crt with geforce fx 5200....each time anti aliasing was used the display would be stretched..so i had to revert back to 81 series drivers..
07-09-2006, 06:36 PM
@blademast3r
Yeah...........i have the same gfx card, do u think that the FX5200 has this problem with the newer drivers??
@digitized
dude, do me a favour...... set anti-aliasing to 2x and play any game at 640 or 800 resolution, see if u get a stretched screen......post the results here.
07-09-2006, 06:47 PM
gooby pls
@Thor: Rollback your previous driver,i think your graphic card doesnot latest nvidia drivers which are specially built for 7 series,i faced many problems on new drivers,now i have 91.36 Driver installed and my graphic card xfx 6600GT 256MB.
07-09-2006, 06:51 PM
I'm getting that problem with the 91.36 driver also...........
Reverting to the older 81 series driver solves the problem
07-09-2006, 07:01 PM
gooby pls
Your Card is nvidia 5200 so you need to try 81XX or 85XX Series.I think older card doesnot support beta drivers completely.....
08-09-2006, 09:29 PM
I hv not only un-installed 91 series divers but also hv gone back to my own old drivers for peace of mind. everything is working fine.!!
08-09-2006, 11:18 PM
@stalker
yup i think theres a prob with 91 seried drivers and older cards...any1 with some other card faced similar problems??
08-09-2006, 11:44 PM
Mine is Integrated 6100 chipset.... Performs great!
09-09-2006, 12:44 AM
Mine is a 7600GT nd full of blue screens nd other errors in almost any games with the 91 series forceware. But no problem with 84xx. I thnik its only meant for the 7950GX2 as its the first official forceware to support that special card. Previous version showed some kinda double omages nd textures on it.
G3: XPS M1530 |
FZ 16.
13-09-2006, 08:19 AM
Is it just me or anyone else noticed a performance dip with the driver?
I tried it on geforce 4 Ti 4400 and Geforce 6600GT , both seems to take plunge on the performance front.
Also the new control panel feels Slow and unresponsive and not at all friendly ( then again I prefer classic Control panel to XP's Categorzied one) . Im not going back there till Nvidia addresses these issues..
Back to 8 series Drivers then.
\"Hating people is like burning down your own house to get rid of a rat\" - Harry Emerson Fosdick
\"A Pessimist is one who makes difficulties of his oppertunities; an optimist is one who makes oppertunities of his difficulties\" - Reginald B. Mansell
oh yeah.. my Fav Quote
\"Sometimes a winner is just a dreamer who never gave up.\"
29-04-2007, 12:15 AM
#19 (permalink)
Hi Thor i have a gf 6100 and i play stalker with bad(scrath) sky ;/
what fix this problem ??
29-04-2007, 12:23 AM
#20 (permalink)
but i havent faced a single prob with the 9x.xx series drivers.i've used the 93.71 drivers and they were perfectly stable in all apps
30-04-2007, 07:33 PM
#21 (permalink)
To detect if the problem is with the nvidia Driver4s...install a bit older version like 81.98 ... and try playing.. if that still gives u prob, then try using the absolutely latest drivers....still if r stuck... maybe then the our onboard 6100 si not cut out to play it..
Unidtall all shreds of a driver b4 going and installing any new drivers.
I hv a copy of 81.98 driver .. if u can't find online mail me, i will send it to u..
01-05-2007, 12:49 AM
#22 (permalink)
Rising ApocalypsE
guys use these drivers from nVidia website
http://www.nvidia.com/object/winxp_2k_93.71.html
these are the latest....actually not that much but they are better than 91.47.
I m using it on my 6800GS & my card is running on full throttle without a problem!!!
