Results 1 to 17 of 17
Thread: need best gpu in under 10k
02-01-2013, 07:59 PM #1
1. Which Power
Supply do you
have? (Be
EXACT while
naming the
company and model) Ans:corsair tx 650v2 2. What is your
budget? Ans:under 10k 3. Which
resolution will
you game at? Ans:1080p Max resolution dell 21.5 inch st2205 4. What are
your current
computer
specifications?Ans amd fx 8350
asus crosshair vi formula
gskil ripjaws x series 16gb (2x8gb)
window 8 pro 64bit
any addtional u want to add Ans:i will be playing hd games like Battlefield 3,
Crysis 2 and
Elder Scrolls V :
Skyrim gta and so on i will be playing future coming game watching hd movies n pci 3.0 , ddrm5 ,playing games at high end setting edting photo/vedio__________________
add me/subscribe me on facebook
www.fb.me/warning7me
02-01-2013, 08:23 PM #2
Re: need best gpu in under 10k
HD 7770 is way to go..If you can extend upto 14k HD 7850 is bang for buck
. with new catalyst 12.11 it outperforms all nvidia cards in same price range.For 1080p HD 7850 will be best option
MSI HD 7770 MSI R7850-1GD5/OC GRAPHIC CARD
MSI HD 7850 MSI R7850-1GD5/OC GRAPHIC CARD
Gigabyte HD 7850 2GB GIGABYTE GRAPHIC CARD RADEON HD 7850 2GB DDR5 OCLast edited by Rajat Giri; 02-01-2013 at 08:29 PM.
Intel i3 3220|Gigabyte GA B75M-D3H|Corsair Vengeance 4x2 @ 1600 MHz|Corsair CX430V2|Sapphire HD 7850 2GB Dual-X |NZXT Source 210 Elite Transparent Side Panel|Logitech G100 Gaming Combo|Razer Goliathus Fragged Omega Mouse Pad Contol|Xbox 360 Controller For Windows|WD Green 1 TB|
Samsung Galaxy Ace|
02-01-2013, 09:43 PM #3
Which monitor is st2205 ?
@OP: Really good config, but only 10k for gpu ? You need a 7850/660 atleast.Need Help :Spoiler:
* Looking to purchase Noctua NH-U12P SE2 :(
02-01-2013, 10:08 PM #4
or, If you'd like to play games in low-med settings, look for a used HD 6850
02-01-2013, 10:23 PM #5
Btw, where is the 'asus crosshair vi formula' available ?
OP needs a really good gpu to do justice to rest of the system anyway.Need Help :Spoiler:
02-01-2013, 10:36 PM #6
At that budget, GTX650Ti @10.5k is the way to go.
02-01-2013, 11:11 PM #7
soriy st22ol
there is rate of ati 7000series there is a low price is it true
http://www.anandtech.com/show/6357/amd-cuts-radeon-hd-7850-prices-again
is it my mobe is nt gud or it wil nt suport hd7850
it is nt gud or nt for hd7850
is it gud from hd 7850__________________
03-01-2013, 05:16 AM #8
the motherboard ie asus crosshair formula is good for HD7850 and HD7850 performs better than GTX 650 ti.
Who Dares Wins
Avenging Angel !
Phenom II 955BE↔Asus M5a97 R2.0↔Corsair 2x 4GB RAM↔HD6850↔Corsair GS600↔CM Hyper 212↔CM 430 Elite
My Blog : http://topgeartopspeed.wordpress.com/
BlackListed : Viewsonic, Gigabyte
03-01-2013, 07:39 AM #9
I thought the budget was 10k >_>
03-01-2013, 08:50 AM #10
03-01-2013, 11:56 AM #11
03-01-2013, 01:20 PM #12
04-01-2013, 03:26 AM #13
the best HD7850 on the market is HD7850 power Edition (15-16k) - also sapphire makes good HD7850 selling around ~13.5k - before getting a HD7850 just make sure it has at-least 2 fans and supports volt mod/oc to get better performance and OC the gpu if needed.
Who Dares Wins
Avenging Angel !
04-01-2013, 01:36 PM #14
04-01-2013, 11:52 PM #15
which is best sapphire HD7850 or Gigabyte HD 7850
2GB DDR5 OCed
edition__________________
05-01-2013, 03:21 AM #16
if you don't need volt OC then get the Spahhire HD7850 2GB OC Ed.
Who Dares Wins
Avenging Angel !
05-01-2013, 08:50 AM #17
Gtx660 is also available at the sane price point.
LinkBack URL
About LinkBacks
