Results 1 to 30 of 45
Thread: 6870 or 560ti or 7850
09-09-2012, 12:37 AM #1Right Off the Assembly Line
- Join Date
- Jan 2012
- Location
- Bangalore
- Posts
- 34
1. Which Power Supply do you have? (Be EXACT while naming the company and model)
Ans: Seasonic SS 750JS WATTS
2. What is your budget?
Ans: 10 K to 15 K
3. Which resolution will you game at?
Ans:
No idea about resolution
4. What are your current computer specifications?
Ans:
INTEL I5 2500K PROCESSOR
ASUS P8 Z68 V PRO MOTHERBOARD
SAMSUNG 20 INCH (50 CM) B2030 WIDESCREEN MONITOR
CORSAIR CARBIDE 400R CABINET
4GB X2 GSKILL RIPJAW RAM
SEASONIC SS 750JS WATTS PSU
Please help me for purchasing GPU. I am a moderate gamer, love playing shooting games only. I am working so i do n't have much time to play too much games. It will be good for me to play games on high or medium settings(ultra high not required). I know only these three cards 6870,Zotac 560ti & Gigabyte 7850 fits in my budget but i am not able to decide b/w these three. I want to buy ZOTAC 560ti (13K) but problem is it is a 2nd gen card ... if gone for GIGABYTE 7850(15.5K) then high price, less playing time, some fan related issues are the bottlenecks ... I have been confused from last 2 months .. can't wait for 660 ...also overpriced for me... Need ur advices please help me in choosing ... ATI/NVIDIA ... If u have some better GPU ideas please tell....
09-09-2012, 12:45 AM #2
09-09-2012, 12:51 AM #3
Re: 6870 or 560ti or 7850
7850 is way to go .
AMD Athlon II X3 445 (ADX445WFGMBOX) |corsair 2X4gb ddr3 1333mhz | Fsp sagaII 500 | CM 310 | Asus M4A78LT-M LE | Sony ODD| segate 500gb HDD| Dell IN 2020M (1600X900) | Segate 500GB External | Nokia X2-01 |Gigabyte 5770|SkullCandy INK'D|Bajaj Discover 100cc | BSNL750ULD
09-09-2012, 01:06 AM #4Right Off the Assembly Line
- Join Date
- Jan 2012
- Location
- Bangalore
- Posts
- 34
@pratyush997, @abhinavmail1 ... i am not going for 15K+ 7850 cards ... is Gigabyte 7850 is a good purchase?
09-09-2012, 01:14 AM #5
09-09-2012, 01:34 AM #6Right Off the Assembly Line
- Join Date
- Jan 2012
- Location
- Bangalore
- Posts
- 34
Guys please do not misunderstand me for arguing myself for 560ti ....i just want a small discussion before purchasing...560ti can't exactly match 7850 in performance but 560ti still is a good purchase ...
560ti gives comparable performance to 7850 in high & medium settings
Here is some benchmark results ...
AnandTech - Bench - GPU12
U can see it gives better performance than its counterpart while playing BATTLEFIELD 3
Performs more or less similar to 6950 in less price
Graphics Card Hierarchy Chart : Best Graphics Cards For The Money: August 2012
ZOTAC GeForce GTX 560 Ti 448 Cores 1280 MB Review | techPowerUp
http://www.techpowerup.com/reviews/Z...Edition/7.html
Just look for the 560ti 1024M ... ignore GTX 560 Ti 448 Cores & GTX 560 Ti Amp Edition specs...Last edited by som; 09-09-2012 at 02:26 AM.
09-09-2012, 05:37 AM #7
^^ for your screen resolution GTX 560 Ti should be enough but if you upgrade to HD monitor in future the 2GB fare buffer of HD7850 will be handy and don';t foget the low power consumption of HD7850 which makes it worth the extra price you pay for HD7850.
Who Dares Wins
Avenging Angel !
Phenom II 955BE↔Asus M5a97 R2.0↔Corsair 2x 4GB RAM↔HD6850↔Corsair GS600↔CM Hyper 212↔CM 430 Elite
My Blog : http://topgeartopspeed.wordpress.com/
BlackListed : Viewsonic, Gigabyte
09-09-2012, 11:34 AM #8Right Off the Assembly Line
- Join Date
- Jan 2012
- Location
- Bangalore
- Posts
- 34
yes the lower power consumption of 7850 is a big plus point but i was thinking, i am using Z68 motherboard so max of the time it will use onboard integrated graphics HD3000 and it will switch to dedicated GPU on high graphics requirements .... so in that case my idle power consumption automatically will be low .... Please correct me if i m wrong...
09-09-2012, 11:41 AM #9
one more vote for 7850...the igpu switching sometime glitches on SB...so dont bank on it too much...
2500K|3570K|FX-8150|FX-8350|965BE|E7500
MVF|P8Z77-V Deluxe|P8Z68 Deluxe|CHV|880GM-USB3|M4A785T-M|G31M-ES2L
HD7850|GTX660Ti|HD6870|HD6670|HD5450|9400GT
HyperX Blu|HyperX Predator|RipjawsX|Value Select|CGM2X2|
09-09-2012, 11:53 AM #10Right Off the Assembly Line
- Join Date
- Jan 2012
- Location
- Bangalore
- Posts
- 34
that's ok dude but the igpu switching will be done automatically based on requirement ... i have to do nothing for this .... and the glitches will happen for everyone using z68 whose system changes its state from idle (like using FB,Listening Music, Watching movies) to playing high end games... it does not depend on whether u r using 560ti or 7850 ....
09-09-2012, 12:13 PM #11
As per your request.....U cant go wrong with any one of them.....but i would suggest u can go with hd7850 and have a piece of mind.......
560-Ti is a card from nvidia's last generation...though its a good card...but its old (a year old card)......its always better to invest in a current gen cards than the old ones
And if you are inclined towards nvidia at the moment...i sugget you wait for 660(non-ti version) that would suit your bill and may be perform better.....!
At the moment hd 7850 performs better in tessallation then any other card in that price range....believe me more and more games are coming this year with more eye candy settings so better to invets in new technology either by nvidia or amd....!Intel 2500k ||Corsair H100||Asus p8z68v-pro ||Sapphire HD7950 vapor-x|| Corsair Carbide 400R || Gskill 8gb-sr2 || Corsair 850tx-v2 || Seagate 500gb || Viewsonic vx1940w
09-09-2012, 12:40 PM #12Right Off the Assembly Line
- Join Date
- Jan 2012
- Location
- Bangalore
- Posts
- 34
Buddy its not specific that i like nvidia or ati... i would be happy with any one of them serving my purpose... Is it a good time to purchase a GPU? ... 660ti price listed on flipkart is 25000 .... with max price cut 660 will not be less than 17000 -18000 .... Also seen some posts AMD has cut down prices by 40$ .... God knows when it will be reflected in India ... any predictions?....
09-09-2012, 01:06 PM #13
May be setpember end prices would reflect some what...not more than 4k price cut u can expect in amd's case and 660-ti have started popping up at a 20~23k price as of now...flipkart doesnt updates their prices often...ask loacal dealer for current prices always....! then too u can go with sapphire hd7870 OC edition @rs.19928 at flipkart if u wish and save up!
When prices are updated HD7850 would be sub-15k, HD7870 would be sub-18K and HD7950 would be sub-25K
660-ti would be around 18K~22K in coming weeks...After all its India so dont expect drastic changes.....!Intel 2500k ||Corsair H100||Asus p8z68v-pro ||Sapphire HD7950 vapor-x|| Corsair Carbide 400R || Gskill 8gb-sr2 || Corsair 850tx-v2 || Seagate 500gb || Viewsonic vx1940w
09-09-2012, 04:01 PM #14
Btw you can buy saphire 7850 1gb version for 13.5k
If you Don't have a UID card Then Visit Bangladesh Once n buy it for 100 Inr..
09-09-2012, 05:40 PM #15
For your Screen a 560 Ti or a HD 6870 will Do . But , get a HD 7850 If you are Planning to go for a LARGE Screen .
Intel Core I5 2400 | Intel DH67CL B3 | Corsair Value Select 2x 4 GB | Seagate Barracuda 500 GB HDD | Asus DVD RW | CM Elite 310 | Corsair GS600 | Logitech MK200 | Creative Speakers | Samsung S20B300 | V Guard UPS | Intel HD 2000 | Nokia Lumia 520 |
09-09-2012, 06:35 PM #16
09-09-2012, 06:59 PM #17Right Off the Assembly Line
- Join Date
- Jan 2012
- Location
- Bangalore
- Posts
- 34
from where?
I am not going to change my monitor for at least one -two years.... living outside .... portability issues ...
The price difference b/w zotac 560ti(12.5k -13k) & 7850 gigabyte version(15k -15.5k)(no idea about sapphire 7850 pricing) is nearly 2k - 2.5k .... that's why i am thinking to much ... is it worth buying for a person who has fair amount of time to play games ...
09-09-2012, 07:05 PM #18
^^ Yes, it is worthy spending the extra 2.5K if not more.
09-09-2012, 07:13 PM #19Right Off the Assembly Line
- Join Date
- Jan 2012
- Location
- Bangalore
- Posts
- 34
@d6bmg ... when the prices for 7xxx series will come down in india ... should i wait? already being waiting since long time to purchase ...
09-09-2012, 07:13 PM #20
Another vote for 7850. 15k will fetch you a better card, else a 560 (non Ti) is within 10-11k and more than enough for your monitor.
Gaming Rig:i7 2600K | N620 | P8Z68 Deluxe | 2x4GB RipjawsX DDR3 1600 | Vertex 3 120GB | Logitech G510 | Logitech G400 | Sapphire 6950 1GB | BenQ G2420HD | Corsair HX750 | Lancool K62
HTPC Rig: C2D E7400 | EP45-DS3R | 2x2GB DDR2 800 | MS Wireless Desktop 2000 | Gigabyte 5770 | Samsung 32" | Seasonic SII 520W | Silverstone LC10
Audio Gear: Altec Lansing VS2421 | ASUS Vulcan ANC | HiFiMan RE-0
Storage: 2x250GB | 3x500GB | 3x1TB | 3x2TB
Android: Galaxy R | Galaxy Y
09-09-2012, 07:24 PM #21
09-09-2012, 09:11 PM #22
@d6bmg.....Will the price drop ever show up in India even if the Company itself has reduced the pricing of their product????
In case of AMD cards...the price drop is hefty...!Intel 2500k ||Corsair H100||Asus p8z68v-pro ||Sapphire HD7950 vapor-x|| Corsair Carbide 400R || Gskill 8gb-sr2 || Corsair 850tx-v2 || Seagate 500gb || Viewsonic vx1940w
10-09-2012, 03:59 AM #23
^^ I think price drops thing work though it takes time as this depends on stock of old gpu/stock of high priced new gpus - even if a AMD/Nvidia announces a price cut distributor's/importers who has bought the product for higher price won't sell it for lower price but if the old stock ( of new cards ) get cleared fast you will see a god price drop and a good example of this is a Sapphire HD7870 is available on FK @ less than 20k
@ Op - don't think too much over paying ~2.5k extra for HD78520 - when you change the monitor to ne with HD resolution 2 years later the extra 1GB frame buffer of HD7850 will come handy ( get the 2GB GDDr5 version ) and the lower power consumption in games will make it up for you over the times.Who Dares Wins
Avenging Angel !
11-09-2012, 12:40 PM #24
11-09-2012, 07:38 PM #25Right Off the Assembly Line
- Join Date
- Jan 2012
- Location
- Bangalore
- Posts
- 34
will wait till 19th sep ... will purchase locally here at Bangalore on that day ... Ganesh Chaturthi at that day... hope some miracle happen till that day or at that day ...
12-09-2012, 06:16 PM #26Right Off the Assembly Line
- Join Date
- Sep 2012
- Posts
- 9
I really hope the price goes down by Sept End.
Iam going to take a system too by Oct 2nd week.
Even I had HD7850 2Gb in my mind. But still my wish is to go for a higher card in hierarchy.But then Money issues.
Hope a higher end card comes to the current price of HD 7850
b/w my GPU card budget is 16k
16-09-2012, 05:39 AM #27Right Off the Assembly Line
- Join Date
- Jan 2012
- Location
- Bangalore
- Posts
- 34
Please tell me whether i should take 1GB or 2GB GFX card based on my current monitor resolution....
16-09-2012, 06:26 PM #28Apprentice
- Join Date
- Feb 2012
- Location
- Jaipur
- Posts
- 53
78502 GB Sapphire is available for 15100Rs
Q6600@2.9|Cm AMMO |Z5500 |ASUS XONAR DX|HD6870 Twin frozr 2 | Prolimatech Megahalem | Corsair TX650| 1 TB Seagate | 250 Gb Seagate| Patriot Vipers 4 GB| MSI P45 CT51| Samsung T190
16-09-2012, 06:57 PM #29Sage of the Six Paths
- Join Date
- Sep 2011
- Posts
- 925
Buy the 7850.
16-09-2012, 07:56 PM #30Right Off the Assembly Line
- Join Date
- Jan 2012
- Location
- Bangalore
- Posts
- 34
LinkBack URL
About LinkBacks
