Results 1 to 6 of 6
  1. #1
    Aug 2012
    Muzaffarpur, Bihar, India
    Question Need Advice for buying graphic card
    Hello everybody, i need a urgent advice on buying a graphic card as cheap as possible enough to play crysis 2, nfs shift 2, assains creed 2, COD Blackops 2, Gta IV at medium settings. my pc configuration is as follows:-
    ram- 2.50gb
    hdd- 500gb
    motherboard- intel chipset 946gz
    processor- intel pentium dual core @ 2.2ghz
    256mb onboard video memory
    os- windows 7 ultimate 32bit
    current monitor resolution- 1440X990
    please suggest me a good graphic card of 1gb and capable of playing all latest games at medium settings.
    Thanks in advance....
  2. #2
    BMG ftw!! d6bmg's Avatar
    Aug 2011
    Kolkata
    Default Re: Need Advice for buying graphic card
    makes no sense at all.
    Please state the model number & manufacturer of PSU you are using.
    Another thing:
    This also makes no sense.
    Post your max budget.
    Inactive in TDF.
  3. #3
    Error 404 gautam_dey66's Avatar
    May 2012
    Kodad, Hyderabad
    Without Posting Any Definite Requirement, How Can We Help You???
    God Is A Big Excuse For Hiding Ur Own Mistakes and Putting It All On Him At Once, At twice, All The Time.
  4. #4
    Fast 'N' Furious topgear's Avatar
    Jul 2006
    Geek's Heaven
    the cheapest possible gpu capable of playing all games should be HD5570 1GB DDr3 @ 3.5k though it's not suitable form playing all latest games at medium settings but it will handle all the games upto 1024*768 resolution easily.
    Who Dares Wins
    Avenging Angel !
    Phenom II 955BEAsus M5a97 R2.0Corsair 2x 4GB RAMHD6850Corsair GS600CM Hyper 212CM 430 Elite
    My Blog : http://topgeartopspeed.wordpress.com/
    BlackListed : Viewsonic, Gigabyte
  5. #5
    Feb 2012
    New Delhi
    the cheapest gpu capable of playing those games at medium would be a hd 5670 ddr3
    but your cpu will severely bottleneck most cards
    POCKET MONEY RIG-Intel Core i5 2500|Intel DH61WW|2*2gb DDR3 1333mhz |SAPPHIRE Hd 6770| Lg E2060 @1080p|Iball Piano 18 CASE| Corsair CX 500 |WD CAVIAR BLUE 500GB|ASUS 24X DVD DRIVE|SEAGATE 1TB EXPANSION DRIVE|SKULLCANDY HESH RASTA |X360 WIRELESS CONTROLLER |IBALL PREMIUM COMBO|LG p500 ] ICySnap v1.6 LG UI 3.0 ICS
    straight from tom's- http://www.tomshardware.com/forum/profile-989398.htm
  6. #6
    Alpha Geek koolent's Avatar
    Oct 2010
    Rawatbhata, Kota, Rajasthan
    Budget and PSU please as you can also play them at medium settings with a 7970, even GTX 680 or a 5750 and up.
    Secondly, specify your power supply, it is ver important to have a suitable power supply before purchasing a new GPU as they eat a lot of it.
    Intel Core 2 Duo @ 2.8 GHz, Corsair CX430 v2, 3 GB DDR 2 RAM, MSI R6770 MD1GD5 (finally), MSI MS-7525 (v1.0), Compaq W185q 1366 X 768 HD LED Monitor
Tags for this Thread
