Results 1 to 11 of 11
Thread: Is The problem due to PSU???
15-08-2012, 06:35 PM #1
I purchased MSI n9600gt 512 graphics card 3 years ago..That time it didnt work.I had it tested in gamers then.They told me that its defective .I could not return it as it was gifted to me by my cousin living in Kuwait...But when I connected it now to my cyberage PC it got detected for the first time but the screen gets distorted and blurry...My PC satisfied all the system requirements for the graphics card except for PSU..My PSU claims to be 400 watts but is of local company...Is the screen problem due to PSU ??? Will my card work fine if I use PSU from Cooler Master or Corsair??
CPU:-AMD Athlon x2 4450e
Ram:- 2 gb ddr3
15-08-2012, 07:21 PM #2
Re: Is The problem due to PSU???
try the graphics card in some other system.it may be graphics card or may be PSU,you will come to know only by trial and error method so check it in different comp if it works then its psu if it doesn't then no doubt its gfx card.but if you want you can change the psu.its always good to have a good branded reliable psu.if possible post the image of the monitor with that problem(distortion and blurry).
" Behind this mask there's more than flesh Mr.creedy, behind this mask there's an Idea and ideas are bulletproof. " - V for Vendetta.
15-08-2012, 07:43 PM #3
i 've attached the images of how the original wallpaper looks like and how it appears on my screen..distorted screen.JPGoriginal wallpaper.jpg
15-08-2012, 07:56 PM #4
try setting the colors and resolution in display properties. Also update drivers.
Discountghar.in - Several Discounts from flipkart.com in one place
Search Indian tech bazaar forums. Its back online!
Computer parts search Engine(for india) : http://goo.gl/Sg8Yv
15-08-2012, 08:44 PM #5
15-08-2012, 09:03 PM #6
16-08-2012, 03:45 PM #7
You should RMA the GPU.
Inactive in TDF.
16-08-2012, 04:22 PM #8
16-08-2012, 05:06 PM #9
@ OP - most probably the memory chips of the GPU is bad - so you can't do much about this but you can try by changing the PSu though.
Who Dares Wins
Avenging Angel !
Phenom II 955BE↔Asus M5a97 R2.0↔Corsair 2x 4GB RAM↔HD6850↔Corsair GS600↔CM Hyper 212↔CM 430 Elite
My Blog : http://topgeartopspeed.wordpress.com/
BlackListed : Viewsonic, Gigabyte
16-08-2012, 06:47 PM #10
As far as I can tell, I used to get similar results in win 98 when i would change the colors to 16 colours in the display properties window. Could be a windows palette setting or a driver setting. Memory corruption would also distort the screen..
AMD Athlon II X4 630 | MSI 785GM E51 | 4 GB DDR3 1333 Corsair | 500+160 GB Seagate | SAPPHIRE HD 6850 | NZXT Gamma | Seasonic 500 Watt :D | Samsung 19" LCD | Google Nexus 4 16GB | Google Nexus 7 16GB
17-08-2012, 06:25 AM #11
^^ I faced similar issue because of a faulty ram module - so whenever intel gfx driver file ( ialmnt5.dll ) stopped working the screen would look like the pic Op has posted ... but the issue OP is facing must be related with the gfx card/PSU/Ram and gfx driver - also Op can try a fesjh windows installation and only after that install new driver to be free from any kind of driver related issue.
Who Dares Wins
Avenging Angel !
LinkBack URL
About LinkBacks
