Results 1 to 9 of 9
  1. #1
    Condition:___ Abnormal
    Jul 2012
    Dum Dum, Kolkata
    Arrow GeForce GTX 550 Ti OR Zion 2 GB DDR2
    It's been about 5 days since I bought my GTX 550 Ti. First game I played on this was Prototype which ran smoothly.
    The second one was Assassin's Creed(2007), in this game I pointed a pretty big issue that when I move Altair forward, things(houses/trees/objects) in distance pops up, and other thing was, when I move closer to an object, the shadow of it gradually refines it's edges.
    I played both the games in max settings.
    But now when I try to play Call of Duty: Modern Warfare 3 in max settings, the game hardly runs.
    What kind of problem is this? My config is here . .
    PSU: Seasonic S12(II) Bronze - 620W
    Motherboard: Intel DG31PR
    Processor: Intel Core2 Duo CPU E7400 @ 2.80GHz
    RAM: Zion 2GB DDR2
    Display: Samsung SyncMaster 743NX [Maximum resolution is 1280x1024x75 hertz]
    I gave all the information I could collect myself. For more system information I ran myself a CPU-z test on my PC. The result is here . .
    I really have no idea if it's my Motherboard/Processor/RAM/GPU, for which I am having this problem. PLEASE HELP ME OUT . .
  2. #2
    sam
    sam is offline
    Forum Moderator sam's Avatar
    Jan 2010
    Guwahati
    Default Re: GeForce GTX 550 Ti OR Zion 2 GB DDR2
    2GB is sufficient for that resolution. though adding ram will increase FPS but game should be playable at your monitors native resolution. check if VSync is on (i don't know if COD have VSync support). And secondly check if your game is upto date.
  3. #3
    Jul 2012
    Try deframent of your HDD and i guess RAM is the culprit here. Check your Ram usage when running game, You may also want to increase virtual memory...
  4. #4
    Wise Old Owl Myth's Avatar
    Jun 2012
    Bhubaneswar / Kolkata
    In Task Manager, check the ram usage before and during the game.
    Install the latest graphics drivers.
    Change the graphics settings to low in the concerned games and check for differences.
    Intel i7 2600k, Asus P8Z77-M Pro, Sapphire HD 7950 VaporX with Boost | Palit 9600GT, Corsair TX650v2, CM Hyper 212 Evo(push-pull), CM Elite 430, Altec Lansing ATP3 2.1, Samsung Syncmaster 2033, Corsair 2x2GB, Seagate 1TB + WD 1TB Black + Maxtor 300GB, Win7 Ultimatex64, CPU-Z , GPU-Z
    Need Help :
    * Looking to purchase Noctua NH-U12P SE2 :(
  5. #5
    Jul 2012
    Dum Dum, Kolkata
    Arrow Re: GeForce GTX 550 Ti OR Zion 2 GB DDR2
    Quote Originally Posted by Sam View Post
    Call of Duty: Modern Warfare 3 doesn't have VSync & My game is upto date.
    Quote Originally Posted by zinbart View Post
    My HDD is always properly defragmented.
    Quote Originally Posted by Myth View Post
    The RAM usage before & during gaming is here. In lower graphics settings there is no problem at all.
    BEFORE
    DURING
  6. #6
    Jun 2012
    Increased virtual memory ?
    Installed latest nvidia graphics drivers ? if yes, reinstall the same.
    If you have done the above things and the problem still persists, experiment with the video settings and check the performance.
    If nothing works, check the ram and gpu separately on another system.
    Need Help :
  7. #7
    Jul 2012
    Dum Dum, Kolkata
    I have latest Nvidia Graphic Driver installed properly . .
    But what do you mean by increasing virtual memory?
  8. #8
    BMG ftw!! d6bmg's Avatar
    Aug 2011
    Kolkata
    You need more RAM.
    Add another 4 GB module.
    2GB is too low to run win 7 + a good game.
    Inactive in TDF.
  9. #9
    Fast 'N' Furious topgear's Avatar
    Jul 2006
    Geek's Heaven
    ^^ yep, Op should get at-least one more 2GB memory module r else he will face lagging issue with games like Crysis - I've faced such issues when I only had 2GB ram and vista x64 SP1 OS though after upgrading to 4GB the games ran like butter
    Who Dares Wins
    Avenging Angel !
    Phenom II 955BEAsus M5a97 R2.0Corsair 2x 4GB RAMHD6850Corsair GS600CM Hyper 212CM 430 Elite
    My Blog : http://topgeartopspeed.wordpress.com/
    BlackListed : Viewsonic, Gigabyte
