Results 1 to 11 of 11
  1. #1
    Alpha Geek koolent's Avatar
    Oct 2010
    Rawatbhata, Kota, Rajasthan
    Default AMD Display driver not installing [Solved]
    Well, I got a new MSi HD6770 MD1GD5 and Corsair CX430 v2 and I installed them.
    Now,
    1. Connected the VGA Cable to the GPU.
    2. Started the PC.
    3. After booting in 800x600 resolution, inserted the driver Disk.
    4. When I tried to install stuff, the Display Driver did not install.
    when I viewed the LOG, it said "Driver Install: the driver package does not specify a hardware identifier."
    Please help me with this issue here.. Reply quick please.
    Intel Core 2 Duo @ 2.8 GHz, Corsair CX430 v2, 3 GB DDR 2 RAM, MSI R6770 MD1GD5 (finally), MSI MS-7525 (v1.0), Compaq W185q 1366 X 768 HD LED Monitor
  2. #2
    That Elusive 7850 HD
    Jul 2012
    Chennai, India.
    Default re: AMD Display driver not installing [Solved]
    Did you connect the graphics card to the power supply properly? Also, try downloading the latest drivers online and try to install them.
    Intel Core i7 2600k on an Intel DZ68DB || 4 gb Corsair 1333mhz Ram x 2 || Intel HD 3000 (MSI r7850 PE soon) || Huntkey Green Power 550w PSU || Hitachi 1 TB SATA || Huntkey Case A402 ||
  3. #3
    Oct 2010
    ^ I am working on the VGA Slot of my GPU only, as specified. Downloading drivers now
  4. #4
    Jul 2012
    Chennai, India.
    Okay, as it is being downloaded, go to device manager and see whether the card is shown in graphic adapters. If yes, then most probably it is a problem with the Driver CD they gave you. Also, were you using an ATI card before this? If yes and you still have those drivers installed, please do a clean uninstall of those drivers before you install the new ones.
    See if this helps: http://www.tomshardware.com/forum/32...770-recognized
  5. #5
    Oct 2010
    I had intel GMA (onboard) graphics before this and so the drivers, I am removing them with Driver Sweeper.
    Now, I am using my card only, it is detected but not installing drivers, thats all..
    Everything I see is in 800 x 600 Resolution.
  6. #6
    sam
    sam is online now
    Forum Moderator sam's Avatar
    Jan 2010
    Guwahati
    selected PEG from bios? if no then select it and try installing driver again.
  7. #7
    Jul 2012
    Chennai, India.
    Quote Originally Posted by koolent View Post
    Try the drivers that you are now downloading from if even that is not working, then there is some hardware problem.
  8. #8
    Oct 2010
    Quote Originally Posted by Sam View Post
    I selected PCI-E from the BIOS, will do the same again after downloading driver and while rebooting
  9. #9
    Jul 2012
    Chennai, India.
    Did it work?
  10. #10
    Oct 2010
    Well, it was already selected but the new driver I downloaded from AMD Website worked and I played Team Fortress 2 for testing it, will play more when I get time from studies in next 3 hours !
    Thanks for the help guys, you rock
  11. #11
    Jul 2012
    Chennai, India.
    Glad to know that, Happy gaming, Koolent!
