Results 1 to 20 of 20
  1. #1
    Why So Serious ??? mandarpalshikar's Avatar
    Aug 2012
    Pune
    Exclamation Aftermarket cooler for GTX 550ti
    mistake in title - should be "Aftermarket cooler for GTX 550ti"
    Hi Guys, I have put in 2 Zotac GTX 550TIs ( yes.. dont question me.. had one from before so got another one until prices of 6 series drops ). The problem is, as in any SLI config.. My first GPU gets extremely hot sometimes..touching 96 degrees. So I was thinking of getting an aftermarket cooler for it ( 2 slots).. So please suggest if any techies here have any idea abou this. ideas for reducing the temp are welcome to. I have already used good thermal paste from Cooler Master on the card.
  2. #2
    knocking on heavens door sumonpathak's Avatar
    Jul 2011
    Skeleton city
    Default Re: Aftermarket cooler for FTX 550ti
    ARCTIC
    take ur pic...u have to import them though....
    2500K|3570K|FX-8150|FX-8350|965BE|E7500
    MVF|P8Z77-V Deluxe|P8Z68 Deluxe|CHV|880GM-USB3|M4A785T-M|G31M-ES2L
    HD7850|GTX660Ti|HD6870|HD6670|HD5450|9400GT
    HyperX Blu|HyperX Predator|RipjawsX|Value Select|CGM2X2|
  3. #3
    Aug 2012
    Pune
    Thumbs up Re: Aftermarket cooler for FTX 550ti
    Quote Originally Posted by sumonpathak View Post
    ARCTIC
    Ye.. probably we wont find any VGA cooling solutions on sell in India.
    I'm able to find Arctic Cooling Accelero Twin Turbo II on ebay.in from a US seller priced at 4411.00 Rs.
    Any other solutions ?
    Arctic Cooling Accelero Twin Turbo II Cooler - DCACO-V540000-BL | eBay
  4. #4
    Jul 2011
    Skeleton city
    Default Re: Aftermarket cooler for GTX 550ti
    guess not..even those are imports
  5. #5
    Wise Old Owl Sainatarajan's Avatar
    Apr 2012
    Santiago Bernabeu , Madrid , Spain
    Intel Core I5 2400 | Intel DH67CL B3 | Corsair Value Select 2x 4 GB | Seagate Barracuda 500 GB HDD | Asus DVD RW | CM Elite 310 | Corsair GS600 | Logitech MK200 | Creative Speakers | Samsung S20B300 | V Guard UPS | Intel HD 2000 | Nokia Lumia 520 |
  6. #6
    Aug 2012
    Pune
    @sainatarajan - Thx for suggestion but its just a PCI slot cooler and not a graphics card cooler... also we can not fit that one between two cards in SLI or Crossfire. I am looking for a GPU cooler which can replace my stock cooler and give me lower temps...
    I'll be getting my ASRock Z77 Extreme6 delivered 2moro... It has more clearing between top two slots so I am hoping it will help the airflow a lot bringing down the temps.
  7. #7
    Jul 2011
    Skeleton city
    ^^why that board? am sure u will find better board in that price range...
  8. #8
    Aug 2012
    Pune
    I wanted to try ASRock one this time around, never used it before. Actually I've got ASUS Maximus V Gene which has gone for RMA with Rashi/Asus. So wanted to get one mobo as replacement till the time I get MVG back and then use ASrock for 2nd build.
    I read its reviews and all of them were positive.... and our beloved Digit also gave Extreme4 best value award ( which is younger sibling of Extreme6).
  9. #9
    Jul 2011
    Skeleton city
    sadly none of them investigated into the horrible llc
    however to each his own....
  10. #10
    Aug 2012
    Pune
    Please explain or give me some links where I can investigate... I read in some forums that ASRock lies about their Digital VRM where as its actually analog one. But really not sure about that but have to trust ASRock if they claim it is digital.
  11. #11
    Jul 2011
    Skeleton city
    ^^well...from my personal testing of these two boards i have seen the Extreme 4 has a tendency of setting the cpu vcore a bit higher than instructed...the issue was same in the Extreme 6..since ivy or sandy is extremely sensitive(what do u expect from chips with that kind of name ) i always suggest people to stay away form boards having llc issues...as it outs the chip in danger...
    well..Asrock do have some issues about furnishing proper information
    [H]ard|Forum - View Single Post - Best Z77 mATX board? Overclocking in mind.
  12. #12
    Aug 2012
    Pune
    Thumbs up Re: Aftermarket cooler for GTX 550ti
    Alright... so I'll need to keep myself away from tampering with voltages while OCing processor or RAM ... thx for heads up.
  13. #13
    Jul 2011
    Skeleton city
    ^^u CANNOT oc without "tampering" with the voltages...cancel the order if ya can
  14. #14
    Aug 2012
    Pune
    Already too late... shipment on the way. Anyways wont be using this board as primary one... will use my old i3-2100 on this
    I just love my Maximus V Gene....
  15. #15
    SWAT 4 GameR ashis_lakra's Avatar
    Sep 2008
    Rajgangpur, Orissa
  16. #16
    Aug 2012
    Pune
    Thx guys for important insights and product recommendations. I've decided not to purchase VGA cooler as they are costing more than half the cost of 550ti itself. I've got my ASRock Z77 Extreme 6 in my hand now and have build the rig. There is space of 1 full slot in between my two 550ti's now and hence the temp of the upper card has gone down by almost 10 degrees now. They run at 35 degrees at idle and rich maximum of 70 degrees on full load.
    I'll save the money to purchase nvidia 600 series or amd HD 7000 series when prices drop down. As of now I dont have any worries as all games run at ultra settings on my rig giving 50 to 60 FPS in Skyrim / DeusX / BF3 and around 30 to 40 FPS in Unigine Heaven.
    Once again thx you all for your suggestions.
  17. #17
    BMG ftw!! d6bmg's Avatar
    Aug 2011
    Kolkata
    Quote Originally Posted by mandarpalshikar View Post
    One piece of suggestion: Unless the ambient of your room is 20C, don't run Unigine heaven. It have the capability to burn GPU out. If that happens you will lose warranty instantly.
    Inactive in TDF.
  18. #18
    Aug 2012
    Pune
    Quote Originally Posted by d6bmg View Post
    Yes... will take care...will run the full Unigine benchmark only when i switch on the AC and put on low temp in my room. thx.
  19. #19
    Aug 2011
    Kolkata
    ^^ Instead use 3D mark for the purpose of benchmarking your GPU. Any version will be good. Avoid using Unigine heaven altogether, if you can.
    Inactive in TDF.
  20. #20
    Fast 'N' Furious topgear's Avatar
    Jul 2006
    Geek's Heaven
    I've run unigine Heaven ( version 2.5 and 3.0 ) many times ( even for continuously for an hour ) and this won't do any harm to the gpu but one should not play with Kombuster/Furmak though.
    Who Dares Wins
    Avenging Angel !
    Phenom II 955BEAsus M5a97 R2.0Corsair 2x 4GB RAMHD6850Corsair GS600CM Hyper 212CM 430 Elite
    My Blog : http://topgeartopspeed.wordpress.com/
    BlackListed : Viewsonic, Gigabyte
  1. Adding 550Ti for physx.. is it worth?
    By max.4u in forum Graphic cards
    Last Post: 17-03-2012, 12:19 PM
  2. Cooler Master Hyper 212 evo cooler fan speed problem
    By sukesh1090 in forum CPU / Motherboards
    Last Post: 21-01-2012, 03:12 AM
  3. XFX 6770 OR ASUS 550ti
    By Shibaprasad in forum Graphic cards
    Last Post: 13-12-2011, 05:33 AM
  4. Stock vs aftermarket
    By Tarun in forum Overclocking
    Last Post: 22-11-2011, 05:30 AM
  5. Is aftermarket thermal paste really necessary??
    By sriharsha_madineni in forum Hardware Q&A
    Last Post: 19-11-2009, 09:34 PM
