Help me choose graphics card mainly for GTA V
Results 1 to 25 of 25
Thread: Help me choose graphics card mainly for GTA V
  1. #1
    Apr 2004
    Bangalore,Karnataka
    Default Help me choose graphics card mainly for GTA V
    Hi, I need help in choosing a graphics card mainly for the upcoming GTA V. I had an nVidia 7600GS 512MB DDR3 card before but it stopped working, so I am looking to buy a new one now. The old card worked fine with moderate settings in GTA IV and I am really looking forward to playing GTA V when it comes out. My assembled PC's config is as follows:
    Mobo: Intel DG33 FB
    Processor: Intel C2Q Q6600 2.4 GHz
    RAM: 2 X 2GB DDR2 800MHz RAM
    How better is a DDR5 graphics card compared a DDDR3 card, with all other parameters kept the same? I am thinking I should spend less than 4K for this but that is a little flexible. But I do not want to spend unnecessarily either. I play mostly only FIFA and GTA, so I don't want to pay for something that is too high for my requirement.
    Thanks for helping out
    Popular Gadget Deals
    Have you heard of aliens?Well,I M 1 of them.
  2. #2
    The Pirate King
    Feb 2012
    Default Re: Help me choose graphics card mainly for GTA V
    Try the Ati 5670 fits well in budget , it would be better if u mention ur monitor size
    The Pirate king !
  3. #3
    Apr 2004
    Bangalore,Karnataka
    Its a Samsung Sync Master 920NW 19" and 1440X900
  4. #4
    In The Zone digitaltab's Avatar
    Nov 2011
    C
    these are the links, the card is AMD 6670 1GB i'll prefer msi one as that is ddr5 and faster than 6670 ddr3, but buy which suits your budget well...
    PowerColor AMD/ATI Radeon HD5670 1 GB DDR3 Graphics Card | Graphics Card | Flipkart.com
    HIS AMD/ATI Radeon HD 6670 GPU 1 GB DDR3 Graphics Card | Graphics Card | Flipkart.com
    Sapphire AMD/ATI Radeon HD 6670 1 GB DDR3 Graphics Card | Graphics Card | Flipkart.com
    MSI AMD/ATI R6670 MD1GD5 1 GB DDR5 Graphics Card | Graphics Card | Flipkart.com
    EDIT: you should try local markets, you can get 5670 ddr5 at cheaper price, may be around 4.5k or less...
    intel core2duo e7400 2.80GHz, intel DG41TY, Kingston 3 GB DDR2 800MHz, 1TB seagette SATA, 320 GB WD sata, samsung 22x DVD-RW, sapphire [B]AMD RADEON HD 6870 1 GB GDDR5[/B], CM xtremepower 600W, [B]logitech z506[/B], samsung BX2031N, HCL keyboard, microtek 600VA UPS, Microsoft XBOX360 controller, Nokia Xpressmusic 5320
  5. #5
    In a flash.. Flash's Avatar
    Jul 2012
    <Classified>
    DDR5 under 4k is not possible. Try for a used DDR5 card bro
    [or]
    Get 6670 DDR5 from ebay @ 5.9k. With 10% off, you may get 6670 DDR5 around 5.4k.
    IMO, flipkart is costly. Buy it from forum vendors.
    Gearbox is now Flash...
    R.I.P Siggy!
  6. #6
    Human Spambot thetechfreak's Avatar
    Nov 2008
    Guwahati
    Pick up a HD 5670. The DDR 3 version is also enough for this game
  7. #7
    Apr 2004
    Bangalore,Karnataka
    Thank you all for your responses. So is DDR5 really not worth the extra cost? And if I do choose to go for DDR3, would there be a massive difference in performance between a 1GB card and a 2GB card?(considering it is the same model except for the diff in memory). Also, all of you seem to suggest AMD Radeon. There seems to be no support for nVidia here. Any reason?
  8. #8
    Moving dashing.sujay's Avatar
    Nov 2009
    New Delhi
    ^DDR5 matters but the card has to be fast enough to utilise it. Same reason goes for "1GB" "2GB" stuff. A 512 MB 5670 will perform same as 2GB 5670 simply because it isn't fast enough to utilise the extra VRAM. Understand it like driving a ferari in a road limited to 60kmph.
    And suggesting AMD against nVidia is simply because its a better VFM at any given price bracket. True for here.
    Rules !!
    DropBox: Get .5GB free
    Vaio CB35
    Prized possession
    Asus U32U ATH M20 Asus RT-N13U B1 Razer DA Young Duos
    Vaio CB35 Review
    How fast can you type?
    Quote Originally Posted by axes2t2
    Before working on a master piece you have to first master the pieces.
  9. #9
    In The Zone IndianRambo's Avatar
    Sep 2011
    Tiruppur, TN..
    Try golchhait at sp road, they might have msi 6670 gddr-5. it may cost around 5000/-.
    [I][B]Intel I5-2400[/B] | [B]Intel DH67BL B3 |[/B] [B]MSI R7850 PE[/B]- [B]benched @ 1250/1450[/B] | [B]Corsair xms3 4gb[/B] + [B]Gskill Ripjawsx 4gb[/B] | [B]Corsair cx500 v2[/B] | [B]Cm elite 430 [/B]| [B]WDC[/B] [B]BLUE[/B][B] 1tb[/B] | [B]LG E2060T[/B] | [B]APC RS 600[/B] | [B]CM HYPER 212 EVO | CORSAIR VENGEANCE 1500 / LOGITECH G300 / STEEL SERIES QCK MINI / LOGITECH C270 HD / [U]WINDOWS 8 PRO[/U] /[/B][/I][I][U][B] NEXUS 4[/B][/U][B] /[/B]
    [/I] [HR][/HR]Be Black or White, don't be Grey.
  10. #10
    Apr 2004
    Bangalore,Karnataka
    Okay, so I think I'll go for DDR3 because DDR5 is costly and I don't really need that. And I was thinking AMD Radeon HD 6450 and its available for a good rate at Flipkart. 1GB is 2778 Sapphire AMD/ATI Radeon HD 6450 1 GB DDR3 Graphics Card | Graphics Card | Flipkart.com and 2GB is 3539 Sapphire AMD/ATI Radeon HD 6450 2 GB DDR3 Graphics Card | Graphics Card | Flipkart.com. But the AMD site says its slot is PCIe x8 Gen 2.0 Compare Desktop Graphic Cards
    And my Intel's site says my mobo has a PCIe x16 slot Intel® Desktop Board DG33FB
    So it will not work, right? There is a PCIe x16 card on AMD that is AMD Radeon HD 6570. But the price for that is 1GB - 4312 Sapphire AMD/ATI Radeon HD 6570 1 GB DDR3 Graphics Card | Graphics Card | Flipkart.com and 2GB - 4704 HIS AMD/ATI Radeon HD 6570 2 GB DDR3 Graphics Card | Graphics Card | Flipkart.com
    Also with regard to the suggestion given by 'thetechfreak' in this thread, AMD Radeon HD 5670, 1 GB card is 4592 PowerColor AMD/ATI Radeon HD5670 1 GB DDR3 Graphics Card | Graphics Card | Flipkart.com. Why is it so costly although it is a 5000 series card?
    I am confused now. Also, anything in nVidia that can compete with the cards 6450 and 6570?
    Edit:The same page on AMD site Compare Desktop Graphic Cards says 6450 comes only in 512 MB and 1GB but there is 2GB in the market. Is it just a case of AMD not having updated the info?
  11. #11
    Pro/An---tagonist xD
    Dec 2009
    Kolkata
    Don't worry about x8 and x16 in pci-e lanes. they'll work.
    But hd6450 is not really a card that you can game with.
    [B]Desktop[/B] :- Amd athlon II X3 435 unlocked to [B]Phenom II X4 B35[/B] | [B]MSI 785 G-E53[/B] |[B] MSI R6850 Cyclone power edition [OC edition] [/B]| [B]Corsair Vengeance 4GB DDR3 RAM @ 1600 Mhz[/B] | [B]Corsair GS600[/B] | [B]Seagate 500 gb 7200.12 [/B]| [B]Cooler Master CM 690II Advanced[/B] | [B]Dell ST2220L[/B] |
    [B]Laptop[/B]:- Dell Inspiron 15R Turbo => i5-3210m,4gb RAM, 1 tb HDD, AMD HD 7730M 2gb.
  12. #12
    sam
    sam is online now
    Forum Moderator
    Jan 2010
    Guwahati
    Quote Originally Posted by ali.en View Post
    doesn't matter if its 2GB or 4GB. anything less than 6670/5670 can't use more than 512MB of ram. and 512MB GDDR5 will offer more performance than 1GB DDR3.
  13. #13
    Apr 2004
    Bangalore,Karnataka
    @Jripper: Thank you for clearing that up. I only play FIFA and am looking to play GTA V when it releases. No Crysis, BattleField or any such games. Will AMD Radeon HD 6450 still not be sufficient to play GTA V? (I know requirements are not out yet but just speculating) I do not want to spend on something that I do not need..
    @Sam:So is 5670 better than entry level 6000 series like 6450 and 6570? Because 6670 starts from INR 5370 Online Shopping India - Buy Books, Mobile Phones, Digital Cameras, Laptops, Watches & Other Products @ FlipKart and I don't think I really need that high a card for my FIFA and GTA V
  14. #14
    Wise Old Owl Sainatarajan's Avatar
    Apr 2012
    Santiago Bernabeu , Madrid , Spain
    IF you can find HD 5670 GDDR5 @ 4.5K , get it .
    Whatever Happenes get GDDR5 Memory
    [b] Intel Core I5 2400 | Intel DH67CL B3 | Corsair Value Select 2x 4 GB | Seagate Barracuda 500 GB HDD | Asus DVD RW | CM Elite 310 | Corsair GS600 | Logitech MK200 | Creative Speakers | Samsung S20B300 | V Guard UPS | Intel HD 2000 | Nokia Lumia 520 | [/b]
  15. #15
    Apr 2004
    Bangalore,Karnataka
    Flipkart has listed HD 5670 GDDR5 at INR 4910 Sapphire AMD/ATI Radeon HD 5670 1 GB GDDR5 Graphics Card | Graphics Card | Flipkart.com but the item is out of stock. There is also 6670 at INR 4999 Go Gaming! | GolchhaIT.com as 'rajesh.s' has mentioned earlier in the thread. SO which of the two would be better? More importantly, do I really need cards as high as these for just FIFA and GTA V? I will go for it if the experts here confirm
    P.S: I am looking at various sites now but if someone finds any of these or similar DDR5 cards (seems like it is the way to go) for a lower price then please mention here.
  16. #16
    Apr 2012
    Get the HD 6670 GDDR5 from GOLCHAIT .
  17. #17
    Feb 2012
    New Delhi
    as we all know that max payne 3 is a beta trial of the engine which is going to be used in gta v
    a hd 6770 (paired with an i5-2500) is able to manage 45-50fps @ 1600X900 @ ultra + no aa (on my rig)
    so a hd 6670 ddr3 (or ddr5 ) should manage that res at medium(Ddr3) or high(ddr5)
    so its up to you now- performance or quality
  18. #18
    Apr 2004
    Bangalore,Karnataka
    @panwala95:Good analysis!
    Thank you so much to each one of you. Went to Golchha Computers and bought an HD6670 1GB DDR5. All set and looking forward to GTA V Thank you so much guys
  19. #19
    Sep 2011
    Tiruppur, TN..
    congrats. good buy buddy.
  20. #20
    Apr 2004
    Bangalore,Karnataka
    Thank you very much Rajesh, especially for being the first one to point to Golchha. Their site shows INR 4999, they said the same on the phone but charged me 5200+tax when I bought. I am still happy with the price because it was quoted at 5800+tax at Computer Warehouse where I usually buy my computer related stuff. Thanks
    Btw, this is what they had and what I finally bought Sapphire Technology Web Site
  21. #21
    Jun 2012
    Lucknow, Uttar Pradesh
    Get MSI's R6670 MD1GD5 which is an awesome card retailing for around 5.5k.
  22. #22
    SWAT 4 GameR ashis_lakra's Avatar
    Sep 2008
    Rajgangpur, Orissa
    Quote Originally Posted by Utkarsh Sharma View Post
    Already bought card
    Core i5 2500K @ 3.3 GHZ | Asus P8P67 | 8GB DDR3 XMS3 | 1 TB Seagate Barracuda | BenQ GL2450 24" | Zotac GTX 670 OC 2GB GDDR5 | Razer Deathadder 3500dpi | Cooler Master Elite 430 | Microsoft Keyboard 600 | Seasonic S12 II 620W | iBall Nirantar 1080 UPS | Sennheiser HD 202
  23. #23
    Jun 2012
    Sorry. Posted a bit late.
  24. #24
    In The Zone CarlonSamuels's Avatar
    May 2012
    Bangalore,Karnataka
    it is not really possible to recommend a card for a game that will release in late 2013 and rockstar's games usually need a good processor so a 6670 hd might give 30 frames on low textures with low res with that config
  25. #25
    Feb 2012
    New Delhi
    awesome card
    you are lucky to have a displayport connector on a hd 6670
    i still dont have a displayport even on ahd 6770
    any way nice card
    could have had better cooling though!
    [spoiler]POCKET MONEY RIG-Intel Core i5 2500|Intel DH61WW|2*2gb DDR3 1333mhz |SAPPHIRE Hd 6770| Lg E2060 @1080p|Iball Piano 18 CASE| Corsair CX 500 |WD CAVIAR BLUE 500GB|ASUS 24X DVD DRIVE|SEAGATE 1TB EXPANSION DRIVE|SKULLCANDY HESH RASTA |X360 WIRELESS CONTROLLER |IBALL PREMIUM COMBO|LG p500 ] ICySnap v1.6 LG UI 3.0 ICS
    straight from tom's- [url]http://www.tomshardware.com/forum/profile-989398.htm[/url][/spoiler]
  1. Intel HD Graphics with Dedicated Graphics Card
    By RazorbladeXtreme in forum Hardware Q&A
    Last Post: 02-08-2011, 03:16 AM
  2. How to choose a TV Tuner Card?
    By ysmonyog in forum Peripherals
    Last Post: 21-12-2010, 08:22 PM
  3. Replies: 1
    Last Post: 19-06-2008, 12:39 AM
  4. Which graphics card should I choose over NVIDIA RIVA
    By //siddhartha// in forum Graphic cards
    Last Post: 05-04-2005, 07:44 AM
  5. Please Help me to choose a graphics card
    By techno tublai in forum Graphic cards
    Last Post: 08-08-2004, 11:49 AM
