Results 1 to 11 of 11
  1. #1
    Jul 2012
    Default need serious help with my gpu
    Guys you all gotta help me out here.
    i have nvidia geforce 9600gt 512 ram which is giving me problems lately.
    the games crash frequently, windows hangs,crash dumps. But when i disconnect the gpu and use the OB graphics these problems do not appear.
    Ill mention my pc specs
    cpu AMD Phenome X2 550 black edition 3.1 ghz
    MOBO Asus M2N68-Am plus
    Kingston 2gb ddr2 ram
    GPU Nvidia Geforce 9600 GT 512 mb ram
    PSU iball LPE 223-400 ( i think it is 250 w but m not sure and i think the psu is not good enuf)
    Screen resolution 1600x900
    do i need to change my gpu is it fried???
    do i need to change my psu???
    And what is this wire/connector coming out from the back of my gpu what is it used for...
  2. #2
    Pro/An---tagonist xD
    Dec 2009
    Kolkata
    Default Re: need serious help with my gpu
    ^ Try using the gpu on a friend's pc. If it runs perfectly there then most probably the culprit is the psu.
    And in any case you should change your current psu.
    Desktop :- Amd athlon II X3 435 unlocked to Phenom II X4 B35 | MSI 785 G-E53 | MSI R6850 Cyclone power edition [OC edition] | Corsair Vengeance 4GB DDR3 RAM @ 1600 Mhz | Corsair GS600 | Seagate 500 gb 7200.12 | Cooler Master CM 690II Advanced | Dell ST2220L |
    Laptop:- Dell Inspiron 15R Turbo => i5-3210m,4gb RAM, 1 tb HDD, AMD HD 7730M 2gb.
  3. #3
    SWAT 4 GameR ashis_lakra's Avatar
    Sep 2008
    Rajgangpur, Orissa
    9600GT is power hungry card :O
    Since you didn't complain about artifacts, there's a good chance that your GPU is fine.
    Change your PSU quickly to Corsair CX430 v2 or better depending on your budget.
  4. #4
    Jul 2012
    hey thanks a lot for the replies..
    i knw m gonna change my psu asap b4 it does any damage to any other parts..
    Pls recommend me some good psus...Im willing to spend about 3 to 3.5k...
    Tell me some that i can use even if i need to upgrade my system in the future
    thanks again
  5. #5
    Jul 2012
    Hey just a quick update
    Just as a test I used my gpu in games and kept a lower resolution 1024x768
    I normally use 1600x900
    And the crashes bsod stopped...and as soon as I switched back to the 1600x900
    Boom another hang with bsod
    So what does this mean....
    How should I go about solving this
  6. #6
    Sep 2008
    Rajgangpur, Orissa
    Since you lowered your res, the gpu uses less power and bsod might disappear temporarily.
    Get Corsair CX430 v2 at 2.6K from theitwares.com
  7. #7
    Dec 2009
    Kolkata
    Yes power supply is definitely the culprit here then. change psu to the cx430 v2
  8. #8
    ico is offline
    . ico's Avatar
    Jun 2007
    Bangalore
    You might want to use the latest nVidia driver.
    AMD A8-3870K with Radeon HD 6550D | Digilite A55M (Foxconn) | 2 * 4 GB Corsair 1600 Mhz Value RAM | Corsair CX430v2 | NZXT Gamma | Dell S2240L 22" @ 1080p
    Intel i5-2500K | Asus P8Z68 Deluxe | 2 * 4 GB Corsair Vengeance | WD Caviar Blue 500 GB | CM Hyper 212 Evo | AMD Radeon HD 6950 2 GB | NZXT Tempest Evo | Corsair AX850 | AverMedia AverTV Capture HD H727
    Samsung Galaxy S2 | Mac mini (Late 2009) with OS X Mountain Lion, 10.8
    Pandaboard ES | OMAP 4460 SoC | 2 * ARM Cortex A9 cores | PowerVR SGX540 graphics
    Arch Linux amd64 | Ubuntu 12.04 amd64 + omap4 ARM | Windows 7 x64
  9. #9
    Fast 'N' Furious topgear's Avatar
    Jul 2006
    Geek's Heaven
    @ OP - most probably your gpus ram chips have some sort of issue - RMA it.
    Who Dares Wins
    Avenging Angel !
    Phenom II 955BEAsus M5a97 R2.0Corsair 2x 4GB RAMHD6850Corsair GS600CM Hyper 212CM 430 Elite
    My Blog : http://topgeartopspeed.wordpress.com/
    BlackListed : Viewsonic, Gigabyte
  10. #10
    sam
    sam is online now
    Forum Moderator sam's Avatar
    Jan 2010
    Guwahati
    Quote Originally Posted by ashis_lakra View Post
    yup. if it was a GPU problem, OP will have artifacts or strange colour generation and not BSOD.
  11. #11
    Jul 2006
    Geek's Heaven
    OK .. then everything is happening for the crap PSU OP has.
    Who Dares Wins
    Avenging Angel !
