Page 1 of 2 1 2 LastLast
Results 1 to 30 of 40
  1. #1
    Playing The Game mrinmoy's Avatar
    Feb 2012
    Kolkata, India
    Default Inbuilt or discrete graphics card?
    Hi,
    I want to buy a sub 40k laptop
    for casual gaming and some
    games like fifa 11, call of duty
    or assasin's creed. I dont need
    high graphics or high fps.
    My question is which
    is better between this two
    1.
    Intel HD 4000 with 3rd
    generation intel core i5-3210M
    with 3Mb cache, clock speed
    2.5GHz upto 3.1GHz in 1366x768 resolution. The ram
    is 4Gb ddr3 1600MHz.
    2. ATI
    Radeon HD 7450M 1Gb,
    with 2nd generation intel core
    i5-2450M with 3Mb cache and
    clock speed 2.5GHz to 3.1GHz. And the ram is 4Gb ddr3
    1333MHz. Screen resolution is
    1366x768pixel.
    Thanks in
    advance.
  2. #2
    That Elusive 7850 HD
    Jul 2012
    Chennai, India.
    Default Re: Inbuilt or discrete graphics card?
    2nd one.
    Intel are no competitors to ATI/Nvidia, I suggest you give importance to graphics as well as your processor and choose the 2nd option. 2nd gen i5 is good enough for a couple of years at least.
    Intel Core i7 2600k on an Intel DZ68DB || 4 gb Corsair 1333mhz Ram x 2 || Intel HD 3000 (MSI r7850 PE soon) || Huntkey Green Power 550w PSU || Hitachi 1 TB SATA || Huntkey Case A402 ||
  3. #3
    tH3 !0$t $0u! Rishi.'s Avatar
    Jun 2012
    New Delhi.
    Definitely 2nd generation if Gaming is your concern.
    Integrated graphics are no match for Descrete GPU's when it comes to gaming.
    Intel HD4000 series are one of the best IGPs in consumer market , but still they are IGPs.
    Lack of dedicated memory reduces the performance..
    The difference in 2nd gen and 3rd gen is mainly the Integrated GPU , smaller design , and higher base clock speed.
    However 3rd gen are not considered good when it comes to overclocking and heat-up issues.
    Though the RAM frequency is higher but still ,1333mhz vs 1600mhz won't make noticeable difference.
    A 2nd Gen + Dedicated GPU will certainly beat a 3rd gen without dedicated GPu in gaming with large difference. (Assuming that the Dedicated GPu is not from stoneage)
    As in case of HD4000 vs Amd Radeon HD7450M , here are the statistics :
    Hd 7450M
    And Intel HD4000.
    As per the gaming FPS and performance , the difference is not that huge , still the Amd Radeon rules over the IGP.
    Current : Acer Aspire V3-571G.
    Config : Ivy Bridge Corei7 3610QM @2.3Ghz | 2GB GT 640m DDR3 GPU (O'Ckled to GTX660m DDR3) | 4 GB DDR3 RAM | 500GB HDD | 15.6' HD.
    Previous :
    NetBook : HP Pavilion DM1-4003au
    Config : AMD E-450 1.65Ghz dual Core with Radeon HD 6320 IGP.
    2 GB DDR3 1333Mhz RAM.
    11.6" Glossy Screen.| 6 Cell LIon Battery.
    RIG : Intel C2D E4500 2.2GHz | Intel DG41RQ | 1*2GB DDR2 RAM 800Mhz Kingston + 1GB Apacer DDR2 @666Mhz. | WD Caviar SE 250GB SATA 7200 RPM | WD Caviar Green 1 TB 7200 RPM with 64M Cache | Nvidia GeForce 8400GS 512MB DDR2.| Samsung SMB2030" 16x9. |.
    Audio Gear : Dunnu Hephaes DN-16 IEM | Tekfusion TwinWoofer V1.| Sansa CLip V1.
    HandHelds : Motorola Atrix 4G(MB860) | Nokia N95 8GB | Nokia 6630.
  4. #4
    ico is offline
    . ico's Avatar
    Jun 2007
    Bangalore
    Pick up this laptop if only casual gaming is your priority - http://www.thinkdigit.com/forum/lapt...d-trinity.html
    HD 7640G + HD 7670 Crossfire. Doesn't really get better than that in 33K.
    AMD A8-3870K with Radeon HD 6550D | Digilite A55M (Foxconn) | 2 * 4 GB Corsair 1600 Mhz Value RAM | Corsair CX430v2 | NZXT Gamma | Dell S2240L 22" @ 1080p
    Intel i5-2500K | Asus P8Z68 Deluxe | 2 * 4 GB Corsair Vengeance | WD Caviar Blue 500 GB | CM Hyper 212 Evo | AMD Radeon HD 6950 2 GB | NZXT Tempest Evo | Corsair AX850 | AverMedia AverTV Capture HD H727
    Samsung Galaxy S2 | Mac mini (Late 2009) with OS X Mountain Lion, 10.8
    Pandaboard ES | OMAP 4460 SoC | 2 * ARM Cortex A9 cores | PowerVR SGX540 graphics
    Arch Linux amd64 | Ubuntu 12.04 amd64 + omap4 ARM | Windows 7 x64
  5. #5
    L33+ P$yCh0 Chaitanya's Avatar
    Jul 2011
    Paradise City
    Wink Re: Inbuilt or discrete graphics card?
    Quote Originally Posted by ico View Post
    Absolutely.. I too would suggest you this 1 . Best lappy for gaming in sub 50k
  6. #6
    Feb 2012
    Kolkata, India
    Thanks for the suggestion. This hp module looks just great. I was thinking to go for dell. But now after seeing this model I have changed my mind. Just one question though. Can I buy extended warrenty from HP?
    Also, will it be future proof for next 2-3 years? Or should I go for intel?
  7. #7
    Requiscat in Pace Gearbox's Avatar
    Jul 2012
    \home\office\
    Comparing to Radeon, Intel is way below in terms of gaming.
    Reality is always controlled by the people who are the most insane.
  8. #8
    Feb 2012
    Kolkata, India
    I mean amd processor (hp model with dual amd graphics card) or intel processor (dell model with single amd graphics card?)
  9. #9
    Jul 2011
    Paradise City
    Lightbulb Re: Inbuilt or discrete graphics card?
    Quote Originally Posted by mrinmoy View Post
    I mean amd processor (hp model with amd graphics card) or intel processor (dell model with dual amd graphics card?)
    Which DELL model are you reffering to ??
  10. #10
    Feb 2012
    Kolkata, India
    Quote Originally Posted by Chaitanya View Post
    sorry my mistake. I have swaped the company names.
  11. #11
    ico is offline
    . ico's Avatar
    Jun 2007
    Bangalore
    AMD A8-4500M + Radeon HD 7640G + Radeon HD 7670 is much faster in games because of faster graphics.
    Though processor wise, A8-4500M is equal to Core i3. But this shouldn't matter as you won't be feeling limited in anyway by this while reading documents, web browsing etc.
    imo, that laptop is unbeatable for the price.
  12. #12
    Jul 2011
    Paradise City
    I think even processing power of AMD one is greater but it doesnt matter to you since gaming is primary purpose for you ...
    Get the AMD one. ( HP g6 20005 ax )
  13. #13
    Feb 2012
    Kolkata, India
    Actually I also use it for some c++, java and sql programming. There will be no problem, will there?
  14. #14
    ico is offline
    . ico's Avatar
    Jun 2007
    Bangalore
    No problem.
  15. #15
    Feb 2012
    Kolkata, India
    Ok. Thanks. There are no concerns now. Going for the hp. Let you know after buying it.
    also see this post and give some opinion.
    www.thinkdigit.com/forum/graphic-cards/160599-can-laptop-run-without-graphic-card.html
    Hey guys how about this model? Asus K53SD-SX809D / 2nd Gen Ci3/ 4 GB/ 500 GB/ 2GB Graphics/ Free DOS: Flipkart.com: Compare, Review Asus Notebook
    ci3-2350M(2nd gen); 4Gb DDR3; GeForce 610M(2Gb DDR3), 31k price
  16. #16
    ico is offline
    . ico's Avatar
    Jun 2007
    Bangalore
    ^ that Asus one has GT 610M which is very slow for games. It might very well be the worst laptop you can buy for 32K.
  17. #17
    Feb 2012
    Kolkata, India
    Ok. Thanks everybody
  18. #18
    sam
    sam is online now
    Forum Moderator sam's Avatar
    Jan 2010
    Guwahati
    heard about 1yr extra warranty. But some said about 2yr is available too. But these schemes are laptop specific AFAIK. So better to visit an authorized HP reseller and ask them. And they refresh these scheme every few months.
    yup. safe for 2-3yrs. You can grab same laptop powered by 3rd gen Core i5 but that will cost you 42-43k. 10k increase.
    Intel HD4000 is faster than Nvidia GT610/520/520MX.
    true
  19. #19
    Feb 2012
    Kolkata, India
    Its decided, buying HP G6-2005ax. Thanks TDF.
  20. #20
    Jul 2011
    Paradise City
    Congrats..
    Get it & tell us more about that little beast wen you get it.
  21. #21
    In search for Tech Gyan! CyberKID's Avatar
    Jul 2010
    New Delhi
    One more thing. You could go in for an upgrade to Windows 8 Pro for Rs.699 (this offer is till 31st Jan, 2013) or else try upgrading the OS from Windows 7 Home Basic to either Home Premium or professional, as in my opinion Home Basic too restricting (not in terms of visuals, but in terms of performance), and on the slower side of windows.
    I'm a KID in this BIG Cyber World!
    Intel C2D E4500|CM Hyper TX3 EVO|Corsair VS450|MSI G41M-P26|Kingston VR 2 x 4GB DDR3 1333 MHz|Seagate 500 GB SATA 3.0+ WD 80 GB IDE|AOC E2243Fw2k|| Dell Inspiron 14R|Core i5 480M 2.66|WD 320GB SATA 3.0|6GB DDR3 1333|Philips SHP 2700|Microsoft Mobile 1000||Nokia C6-00
    My Blog: http://www.metro-greens.in
  22. #22
    Jul 2011
    Paradise City
    Exclamation Re: Inbuilt or discrete graphics card?
    Quote Originally Posted by CyberKID View Post
    Yeah a nice tip..
    See if you get HomePremium/Ultimate
  23. #23
    Feb 2012
    Kolkata, India
    I have a 32bit home premium key. Can it be used to upgrade from 64bit home basic to home premium?
  24. #24
    Jul 2011
    Paradise City
    Nope...
    32 bit & 64 bit keys are diff AFAIK
  25. #25
    Jul 2010
    New Delhi
    ^ yup! he's correct! you need to have a different key for a 64bit windows. Moreover, we'd not suggest you to use a pirated version of windows, if you're thinking so. Get the windows home basic available with the hp laptop ico suggested, upgraded to Windows 8 Professional. Windows 8 has only two versions Windows 8 and Windows 8 Pro read this and once you purchase the laptop register here
  26. #26
    Feb 2012
    Kolkata, India
    the key is genuin. Its from my old laptop
    I will register for win 8
  27. #27
    sam
    sam is online now
    Jan 2010
    Guwahati
    these are OEM key and mayn't work with a different laptop.
  28. #28
    Feb 2012
    Kolkata, India
    Hey guys, I am confused again should I go for hp g6 2005ax or wait for g6 2002ax with a10 and 7660g+7670m?
  29. #29
    Jul 2011
    Paradise City
    How much it cost??
    Specs wise it has greater procesing power...
    If budget permits it go for it.
  30. #30
    Feb 2012
    Kolkata, India
    How much it cost??
    hp released it quite some times age. Though it is not present in India currently. I think I should wait for some days. And if budget permits then will go for it.
  1. Use of Integrated GPU when discrete card is opted?
    By ajaymailed in forum Graphic cards
    Last Post: 23-03-2012, 11:42 AM
  2. Latest inbuilt graphic card
    By raghav472 in forum Graphic cards
    Last Post: 27-02-2012, 09:20 PM
  3. Replies: 2
    Last Post: 03-04-2008, 11:08 PM
  4. Incresing Inbuilt Graphics Memory
    By nitin_gict in forum Graphic cards
    Last Post: 08-08-2004, 12:00 PM
  5. Incresing Inbuilt Graphics Memory
    By nitin_gict in forum QnA (read only)
    Last Post: 08-08-2004, 02:09 AM
