Results 1 to 10 of 10
  1. #1
    Jul 2005
    Default Graphics card problem
    I have a p-4 system with Nvidia geforce FX 5200 graphicscard(AGP). Recently I updated the driver of the graphics card. Since then the video performance of my system has deteriorated. I installed the old driver and remarkably it has performed better than the new one. The problem is, whenever i install the old driver, after sometimes my system hangs and is not able to run anymore. Plz help.
  2. #2
    Pro/An---tagonist xD
    Dec 2009
    Kolkata
    Default Re: Graphics card problem
    Did you remove the new drivers properly?
    1.) Uninstall current drivers
    2.)Use driver sweeper to remove all traces of all drivers(new and old)
    3.) reinstall old drivers
    Try this and let us know what happened.
    Desktop :- Amd athlon II X3 435 unlocked to Phenom II X4 B35 | MSI 785 G-E53 | MSI R6850 Cyclone power edition [OC edition] | Corsair Vengeance 4GB DDR3 RAM @ 1600 Mhz | Corsair GS600 | Seagate 500 gb 7200.12 | Cooler Master CM 690II Advanced | Dell ST2220L |
    Laptop:- Dell Inspiron 15R Turbo => i5-3210m,4gb RAM, 1 tb HDD, AMD HD 7730M 2gb.
  3. #3
    Jul 2005
    Quote Originally Posted by Jripper View Post
    Did it. But now after installing the old driver no improvement!It can't play the vids that it used to play!
  4. #4
    Fast 'N' Furious topgear's Avatar
    Jul 2006
    Geek's Heaven
    install new drivers and update directx runtime components and for video playback use KMPlayer.
    Who Dares Wins
    Avenging Angel !
    Phenom II 955BEAsus M5a97 R2.0Corsair 2x 4GB RAMHD6850Corsair GS600CM Hyper 212CM 430 Elite
    My Blog : http://topgeartopspeed.wordpress.com/
    BlackListed : Viewsonic, Gigabyte
  5. #5
    Jul 2005
    Quote Originally Posted by topgear View Post
    Video playback definitely improved with KMplayer.But 720p vids are having audio-video mismatch,means the audio is playing normal but the video playback lags behind.
  6. #6
    Jul 2006
    Geek's Heaven
    ^^ try with some different Renderer ( from KMplayer settings ) and set KMPlayer in performance mode - ( suitable for cpus with 1 Ghz speed ) - for Renderer you can try "Old Video Renderer or something else which gives you best performance.
    Who Dares Wins
    Avenging Angel !
  7. #7
    Jul 2005
    Did it. Works much better. I have to free up the processor some way cause when it using 100% thats when the problem starts.Can u help in this regard?
  8. #8
    Jul 2006
    Geek's Heaven
    ^^ for that you need to buy a gfx card with hardware accelerated HD video playback support - look for agp version of ATI HD2400 .
    Who Dares Wins
    Avenging Angel !
  9. #9
    Jul 2005
    ATi Radeon HD 2400 Pro AGP Video Card - Reviews, Specifications, and Pictures - GPUReview.com. Is this the one? Also how much wiil it cost?
  10. #10
    ico is offline
    . ico's Avatar
    Jun 2007
    Bangalore
    Rather buy a cheap new PC. AGP cards are non-existent now.
    AMD A8-3870K with Radeon HD 6550D | Digilite A55M (Foxconn) | 2 * 4 GB Corsair 1600 Mhz Value RAM | Corsair CX430v2 | NZXT Gamma | Dell S2240L 22" @ 1080p
    Intel i5-2500K | Asus P8Z68 Deluxe | 2 * 4 GB Corsair Vengeance | WD Caviar Blue 500 GB | CM Hyper 212 Evo | AMD Radeon HD 6950 2 GB | NZXT Tempest Evo | Corsair AX850 | AverMedia AverTV Capture HD H727
    Samsung Galaxy S2 | Mac mini (Late 2009) with OS X Mountain Lion, 10.8
    Pandaboard ES | OMAP 4460 SoC | 2 * ARM Cortex A9 cores | PowerVR SGX540 graphics
    Arch Linux amd64 | Ubuntu 12.04 amd64 + omap4 ARM | Windows 7 x64
  1. Problem with my graphics card??
    By vulcan86 in forum Graphic cards
    Last Post: 17-12-2010, 06:44 PM
  2. Replies: 13
    Last Post: 09-08-2010, 07:36 AM
  3. Problem with my Graphics card
    By Cilus in forum Graphic cards
    Last Post: 07-01-2010, 03:55 PM
  4. graphics card problem! plz help :(
    By george101 in forum Graphic cards
    Last Post: 27-01-2007, 01:44 AM
  5. GRAPHICS CARD PROBLEM
    By saiaspire in forum Graphic cards
    Last Post: 15-03-2006, 03:50 PM
