Results 1 to 11 of 11
  1. #1
    Jun 2012
    Jaipur
    Default Need a FUTURE PROOF GPU !!!!
    1. Which Power Supply do you have? (Be EXACT while naming the company and model)
    Ans: Corsair VS 450
    2. What is your budget?
    Ans:7K MAX
    3. Which resolution will you game at?
    Ans:1920 X 1080
    4. What are your current computer specifications?
    Ans: i5-2400
    DH67CL
    Gskill 4Gb
    Note:- Suggest me some good GPU thorgh which i can play future games atleast till next 3-4 years..
  2. #2
    defeating my fears..... the_conqueror's Avatar
    Mar 2012
    Kanpur
    Default Re: Need a FUTURE PROOF GPU !!!!
    Your budget is pretty low for gaming at 1080p. Increase it by 2-3k and get HD 6850. HD 7750 and HD 6770 might be able to hold for a few games but they won't last long. You'll need to reduce the resolution.
  3. #3
    AMD Fanboy bavusani's Avatar
    Jan 2011
    Hyderabad
    You can get HIS/Sapphire 7750 1 GB GDDR5 Graphics Card for 7500INR locally.
    AMD FX 8320, Asus M5A97 R2.0, Sapphire 7770 1GB, Kingston V+200 240GB, Corsair TX650M, Corsair Vengeance 8GB 1600MHz, Corsair H60, Corsair 300R, Asus 24B5ST DVD-RW, Deep cool 120mm 4 BLUE LED Fans, Dell ST2220L LED, Microsoft Sidewinder X6, Logitech G400, Logitech Z313.
  4. #4
    Human Spambot thetechfreak's Avatar
    Nov 2008
    Guwahati
    No GPU is future proof. Most become obscene obsolete in around 5 years. 1080p gaming needs atleast a HD 6850 which is above your budget
    Follow me on Twitter: http://twitter.com/wuodland
  5. #5
    Human Spambot The Sorcerer's Avatar
    May 2008
    Quote Originally Posted by thetechfreak View Post
    Most become obscene in around 5 years.
    Obsolete.
  6. #6
    Human Spambot saswat23's Avatar
    Jan 2011
    Bhubaneswar
    Get HD 7750 or HD 6770 for ~6.3k
    Check here
    My Blog :D
  7. #7
    Fast 'N' Furious topgear's Avatar
    Jul 2006
    Geek's Heaven
    get the HD6770 or if you can extend the budget by 1k then HD6790.
    Who Dares Wins
    Avenging Angel !
    Phenom II 955BEAsus M5a97 R2.0Corsair 2x 4GB RAMHD6850Corsair GS600CM Hyper 212CM 430 Elite
    My Blog : http://topgeartopspeed.wordpress.com/
    BlackListed : Viewsonic, Gigabyte
  8. #8
    L33+ P$yCh0 Chaitanya's Avatar
    Jul 2011
    Paradise City
    Arrow Re: Need a FUTURE PROOF GPU !!!!
    Get this 6770 @ 6.6k
    For future proofiing ur GPU get TWO GTX690/7970GHz editions & SLi/Crossfire them
  9. #9
    In The Zone Nighthawk12's Avatar
    Jan 2012
    Try extending it by 2k and get 6850..
  10. #10
    Jun 2012
    Jaipur
    Quote Originally Posted by saswat23 View Post
    7750 for 6.3k !!!!
    where???
    thanks guyz for ur suggestion..
    after getting ur response i m convinced for HD6850 but will check the best price from my local dealer..
    If my pocket will not allow me to buy dis then i will go for HD7750 as it consumes less power...
  11. #11
    Jul 2011
    Paradise City
    Wink Re: Need a FUTURE PROOF GPU !!!!
    yup if u can xtend budget & get 6850 then it's nice one...
  1. Future proof PC under 25k
    By ilikecool1 in forum PC Components / Configurations
    Last Post: 15-07-2012, 06:06 PM
  2. Need a Future proof mobile.
    By SahilAr in forum Buying Advice
    Last Post: 15-04-2012, 05:55 PM
  3. Need a Future proof mobile.
    By SahilAr in forum Mobiles and Tablets
    Last Post: 15-04-2012, 04:07 AM
  4. A future proof mobile
    By DizitalNovice in forum Mobiles and Tablets
    Last Post: 25-12-2010, 01:30 PM
  5. Future proof mobo..
    By cooldip10 in forum Hardware Q&A
    Last Post: 22-05-2006, 09:25 AM
