Results 1 to 19 of 19
Thread: Gt650m
  1. #1
    Jun 2012
    Default Gt650m
    How would you rate the gt650m for high end gaming? And, is it in any way inferior to the old gtx 260m?
    Am asking this because i'm getting a replacement m14x for my m15x. Other specs are way better in the m14x. Just want to know about the graphics.
    Comparasion between these two might seem silly to some. Kindly bear with and answer.
    Thanks in advance.
    Edit: Also, is 1TB 5400 rpm slower than 750GB 7200 rpm? Or does the disk density make them equal in speed?
  2. #2
    as Sam Fisher rider's Avatar
    Aug 2011
    ThinkDigit Forum
    Default Re: Gt650m
    GT 650M is more than 50% better than GTX 260M.
    And buy the laptop with 1TB 5400rpm, their is not much real life difference in comparison to 7200rpm.
    Also take a look on samsung series 5 550p laptop, the core-i7 15.6" version is with 300nit 900p anti-reflective screen, 8GB RAM, 1TB HDD, blu-ray drive and GT 650M 2GB DDR3 that costs approx 57k.
    Google Nexus 4 16GB running 4.2.2 Jelly Bean | Antutu Score: 17552 | GeekBench 2 Score: 2151 | SoundMAGIC PL11
    hp pavilion dv6-6165tx powered by Intel Core i7-2670QM 2.2Ghz-3.0GHz | Radeon HD 6770M 2GB GDDR5 | 8 GB DDR3 RAM | 750GB HDD | GeekBench Score: 12022 | Windows 8 Pro x64 | 1TB Seagate Backup Plus USB 3.0 HDD | Edifier M3200 Speakers | CoolerMaster Notepal L1 |
  3. #3
    tH3 !0$t $0u! Rishi.'s Avatar
    Jun 2012
    New Delhi.
    Default Re: Gt650m
    ^Don't forget the 1600mhz DDR3 Ram and JBl sp3akers.
    Btw, GT650M is currently the Top end Multimedia graphic card for laptop segment by Nvidia.
    On NotebookCheck it ranks somewhere in Top 30's amongst laptop Graphic card.
    Current : Acer Aspire V3-571G.
    Config : Ivy Bridge Corei7 3610QM @2.3Ghz | 2GB GT 640m DDR3 GPU (O'Ckled to GTX660m DDR3) | 4 GB DDR3 RAM | 500GB HDD | 15.6' HD.
    Previous :
    NetBook : HP Pavilion DM1-4003au
    Config : AMD E-450 1.65Ghz dual Core with Radeon HD 6320 IGP.
    2 GB DDR3 1333Mhz RAM.
    11.6" Glossy Screen.| 6 Cell LIon Battery.
    RIG : Intel C2D E4500 2.2GHz | Intel DG41RQ | 1*2GB DDR2 RAM 800Mhz Kingston + 1GB Apacer DDR2 @666Mhz. | WD Caviar SE 250GB SATA 7200 RPM | WD Caviar Green 1 TB 7200 RPM with 64M Cache | Nvidia GeForce 8400GS 512MB DDR2.| Samsung SMB2030" 16x9. |.
    Audio Gear : Dunnu Hephaes DN-16 IEM | Tekfusion TwinWoofer V1.| Sansa CLip V1.
    HandHelds : Motorola Atrix 4G(MB860) | Nokia N95 8GB | Nokia 6630.
  4. #4
    Aug 2011
    ThinkDigit Forum
    Default Re: Gt650m
    Quote Originally Posted by Rishi. View Post
    every 3rd gen core-i series laptop comes with 1600Mhz DDR3 RAM and their is nothing woopy about, the change will come when DDR5 RAMs will come.
  5. #5
    Jun 2012
    New Delhi.
    Default Re: Gt650m
    Quote Originally Posted by rider View Post
    Well most of them have 1600mhz or higher ,but not all of them .Although there is seriously nothing woppy about it , since 1333 vs 1600mhz doesn't makes a really big difference.
    Btw, why did you skipped DDR4 ram and went straight to DDR5 ?
    Previous :
  6. #6
    Fast 'N' Furious topgear's Avatar
    Jul 2006
    Geek's Heaven
    Default Re: Gt650m
    nope .. this is the Nvidia's current top end offering for laptop's :
    AnandTech - NVIDIA GeForce GTX 680M: Kepler GK104 Goes Mobile
    Who Dares Wins
    Avenging Angel !
    Phenom II 955BEAsus M5a97 R2.0Corsair 2x 4GB RAMHD6850Corsair GS600CM Hyper 212CM 430 Elite
    My Blog : http://topgeartopspeed.wordpress.com/
    BlackListed : Viewsonic, Gigabyte
  7. #7
    Aug 2011
    ThinkDigit Forum
    Default Re: Gt650m
    Which ivy bridge laptop has 1333Mhz? If you are thinking sony vaios, i will tell you specs may be written wrong.
    And I slipped direct to DDR5 because VRAM started to come GDRR5 after DDR3 in high end laptops.
  8. #8
    Jul 2012
    Default Re: Gt650m
    Quote Originally Posted by topgear View Post
    Lol.
    He said its the best multimedia graphic card. Not the best Nvidia GPU outright Einstein.
    And FYI, the GTX 690 SLI is now the best Nvidia GPU for laptops.
    Samsung 550P5C-S02IN : 3rd gen i7 3610QM, 8 GB RAM, 1 TB HDD, 15.6" 1600X900 screen, 2 GB Nvidia GT 650M, Blu Ray + DVD combo, Microsoft XBOX Controller.
    Samsung Galaxy S2 GT i9100
    PS3 fatboy 80 GB
  9. #9
    vkl
    vkl is offline
    Super Moderator
    Apr 2012
    Default Re: Gt650m
    Leap from ddr3 to ddr4 ram would be significant.It would run on 1.2V or less.
    It would have higher regular speed.
    DDR4 adaptation is still far.
    No point in comparing VRAM development and adaptation with normal RAM.
    @gunner_kanishk
    Nvidia's top current mobile card is gtx680m as said by topgear.
    And the best the gaming laptops can offer is gtx680m sli not gtx690 sli.
  10. #10
    Jun 2012
    New Delhi.
    Default Re: Gt650m
    I think I mentioned Multimedia Series , not the Extreme series , right ??
    I know about the GTX680M , infact (GTX680M SLI) is the best commercial laptop GPU currently but from Xtreme series
    Quote Originally Posted by vkl View Post
    AFAIK , DDR4 was released in 2011 , but not commercially and yes the Adapatation is still far.
    I don't think , it was a wise idea for him to dream about DDR5 ram , atleast not as per current scenarios.Maybe in next couple of years.
    @gunner_kanishk
    GTX690 is probably the best GeForce GPU and by far the most expensive too.
    Actually its a dual GPU , the only important thing it has inferior from GTX680 is the Core Clock.
    He must have speculated the release of Mobile version of GTX 690M , its not available though.
    But the moment when it will be, its definitely going to be the best , but not right now.
    Previous :
  11. #11
    Jul 2006
    Geek's Heaven
    Default Re: Gt650m
    Quote Originally Posted by gunner_kanishk View Post
    Lol.
    may be I got to much obsessed with gaming gpus anyway, thanks for all the infos.
    Who Dares Wins
    Avenging Angel !
  12. #12
    Jun 2012
    Default Re: Gt650m
    so, is the gt650 futureproof for gaming?
  13. #13
    Jun 2012
    New Delhi.
    Default Re: Gt650m
    ^Nope, as such it is not a gaming GPU , although it succedes several low end GTX series gfx cards.
    In the price range of under 60k range laptops , the answer will be yes.
    You will be able to play all the latest games on it , with Medium to high gfx settings.
    But when lokking for better option , there are many better mobile gfx cards available in GTX series.
    Previous :
  14. #14
    Jun 2012
    Default Re: Gt650m
    you mean, the older gtx cards like gtx 260m?
  15. #15
    Aug 2011
    ThinkDigit Forum
    Default Re: Gt650m
    GT 650M is great GPU only just 10% lower than GTX 660M in benchmarks, but big price difference.
  16. #16
    Jun 2012
    Default Re: Gt650m
    Actually as i mentioned i'm switching from the m15x to the m14x. my m15x had a gtx graphic card, while the m14x has gt series which are really different in many aspects, like the memory bandwidths: gt - 128 bit gtx - 256 bit
    My gtx 260m still runs battlefield 3 on high, no lag.
    hence the confusion.
  17. #17
    vkl
    vkl is offline
    Super Moderator
    Apr 2012
    Default Re: Gt650m
    Gtx660m is more like 20-30% faster in games like CoD:MW3,BF3,Batman:AC,dirt showdown,alan wake.
    It is 15% faster in crysis 2
    In other games it is like 15-20% faster.
    In some games the gap is very though(8-12%)
  18. #18
    Jun 2012
    New Delhi.
    Default Re: Gt650m
    There is a throttling issue with GT650M at high temperature. Choose wisely.
    Previous :
  19. #19
    Aug 2011
    ThinkDigit Forum
    Default Re: Gt650m
    I said in benchmarks, through 3DMark 11 score.
