Results 1 to 30 of 45
18-07-2012, 07:41 PM #1That Elusive 7850 HD
- Join Date
- Jul 2012
- Location
- Chennai, India.
- Posts
- 138
Will a 7850 HD work on my motherboard?
Hi, i just decided to buy a Sapphire 7850 HD from the US as it is a lot cheaper over there. I was just wondering whether it will run on my motherboard without any trouble, i have an intel dz68db board with a 2600K processor.
The things that worry me about this card is the issues many people seem to have with the drivers, is it really serious?
And, my is not an overclocked edition, its factory clock is at 860mhz, i will still be able to run most games at ultra without overclocking, right?
Thanks in advance.
18-07-2012, 09:04 PM #2
Re: Will a 7850 HD work on my motherboard?
Yes, your board supports it. 12.7 beta driver had minor scaling problem. I'm running it on 12.3. And it can max out most of the demanding titles @ 1080p with nice fps. Don't buy from US or any other country since you'll lose the warranty. Wait for a month, AMD recently slashed the prices, so it'll go a bit cheaper in India.
18-07-2012, 11:30 PM #3
yea, it will work well.
AMD A8-3870K with Radeon HD 6550D | Digilite A55M (Foxconn)
| 2 * 4 GB Corsair 1600 Mhz Value RAM | Corsair CX430v2 | NZXT Gamma | Dell S2240L 22" @ 1080p
Intel i5-2500K | Asus P8Z68 Deluxe | 2 * 4 GB Corsair Vengeance | WD Caviar Blue 500 GB | CM Hyper 212 Evo | AMD Radeon HD 6950 2 GB | NZXT Tempest Evo | Corsair AX850 | AverMedia AverTV Capture HD H727
Samsung Galaxy S2 | Mac mini (Late 2009) with OS X Mountain Lion, 10.8
Pandaboard ES | OMAP 4460 SoC | 2 * ARM Cortex A9 cores | PowerVR SGX540 graphics
Arch Linux amd64 | Ubuntu 12.04 amd64 + omap4 ARM | Windows 7 x64
18-07-2012, 11:30 PM #4That Elusive 7850 HD
- Join Date
- Jul 2012
- Location
- Chennai, India.
- Posts
- 138
:O why will i lose my warranty? i don't understand. :\ are you telling me it will be hard for me to claim my warranty if something happens or that it doesn't come with warranty if i buy from the US or any other country?
18-07-2012, 11:34 PM #5
You won't get 7850 at cheaper prices than us in india but price cuts should be reflected here as well. Don't buy from US as international warranty isn't found with most gpu board makers.
You can wait for price cuts or grab one here at around 15k.Core i5 750, biostar h55 A+ (X16+X4), 4gb 1333 ddr3, corsair vx450, cm elite 335,Asus EAH 5750 FORMULA , samsung 2033 sw plus, wd green 1tb , wd 1tb my book ,Seagate freeagent ext hdd 1tb , hp dvd writer,Apc 650 va, logitech z313 , Micromax Funbook , Klipsch image S3 (IEM).
19-07-2012, 12:23 AM #6That Elusive 7850 HD
- Join Date
- Jul 2012
- Location
- Chennai, India.
- Posts
- 138
Thanks guys, i decided i will buy it from here rather than the US if that's the case, i need to save up some more before i can order it. I live in Chennai, which is the best option for me to buy? Online or hands on in the market? Ritchie street is the place you go for computers here but last i saw the cheapest 7850 there was for 17.2K and it was sapphire make.
Any good online stores that do free shipping(apart from flipkart, they don't have sapphire as of now and are kinda over priced at 16.5)? I am hoping to buy it for 15k or less, that is after the suggested price cut. Planning to buy it by September.
Also, which is the better? Gigabyte OC or Sapphire non OC? :\ Gigabyte seems to be cheaper even though its OCed.Last edited by ram22693; 19-07-2012 at 01:42 AM.
19-07-2012, 05:39 AM #7
^^ if you won't OC manually then Gigabyte HD7850 is what you should get - other than this both of them can be Oced upto 1050 Mhz manually and both of them have similar cooler - so there's not much performance difference - look at SMC, primeabgb, theitwares for a good deal on the HD7850.
Who Dares Wins
Avenging Angel !
Phenom II 955BE↔Asus M5a97 R2.0↔Corsair 2x 4GB RAM↔HD6850↔Corsair GS600↔CM Hyper 212↔CM 430 Elite
My Blog : http://topgeartopspeed.wordpress.com/
BlackListed : Viewsonic, Gigabyte
19-07-2012, 06:34 PM #8That Elusive 7850 HD
- Join Date
- Jul 2012
- Location
- Chennai, India.
- Posts
- 138
Thank you Topgear. also, how much of a difference does the over clocking make while playing games like skyrim on ultra? I know I have to overclock my card to get the best out of it but I am running on a Huntley green power 550 psu for which I have received mixed reviews.
I have decided to buy Gigabyte OCed edition from GIGABYTE GV-R785OC-2GD Radeon HD 7850 2GB 256-bit GDDR5 PCI Express 3.0 x16 HDCP Graphic Card
Both gigabyte and Sapphire have same cooling effect and gigabyte comes factory overclocked and that's good for me because i am not the kind that would risk overclocking a new GPU. Gigabyte seems to have 3 years warranty while Sapphire has only two, not sure if this is true but read it on a forum elsewhere.
Any one tried the gigabyte version? i would like your feedback.
20-07-2012, 06:22 AM #9
^^ the warranty period info is true and get the Gigabyte HD7850 Ced version but the PSu you have .. it's not that good AFAIK - can you post the +12v spec of the psu ?
Who Dares Wins
Avenging Angel !
20-07-2012, 10:27 AM #10That Elusive 7850 HD
- Join Date
- Jul 2012
- Location
- Chennai, India.
- Posts
- 138
If i should be changing my SMPS, i'd like to know which one would be suit my configurations. Is it really necessary to change my SMPS? I was hoping to buy a cooler master evo 212 rather.
21-07-2012, 02:45 AM #11
^^ if the specs are right then it should handle your rog along with HD7850 just fine but Huntkey once tried to bribe a foreign tech review website for their product review - so don't expect that Huntkey psus are of very high quality - so to be safe ( if you have to use the PSU ) just don't Oc the CPU/GPU anything.
If you want a replacement PSU look for Corsair Cx500 or GS600.Who Dares Wins
Avenging Angel !
21-07-2012, 11:06 AM #12That Elusive 7850 HD
- Join Date
- Jul 2012
- Location
- Chennai, India.
- Posts
- 138
22-07-2012, 02:23 AM #13
^^ nope
- there's only ~5W-7W load power consumption difference.
Who Dares Wins
Avenging Angel !
22-07-2012, 10:45 AM #14That Elusive 7850 HD
- Join Date
- Jul 2012
- Location
- Chennai, India.
- Posts
- 138
29-07-2012, 06:32 PM #15Right Off the Assembly Line
- Join Date
- Jun 2012
- Location
- Nanded,Mah
- Posts
- 3
Yes , it will work Fine .. :
08-08-2012, 07:34 PM #16That Elusive 7850 HD
- Join Date
- Jul 2012
- Location
- Chennai, India.
- Posts
- 138
Okay guys, so i have narrowed down my options to:
Sapphire AMD/ATI HD 7850 HDMI OC Edition 2 GB GDDR5 Graphics Card | Graphics Card | Flipkart.com
MSI R7850 Power Edition 2GD5/OC
MSI R7850 Twin Frozr 2GD5/OC
Which one do you guys suggest? If Sapphire is the best, i will need to save up money for one more month.
08-08-2012, 07:39 PM #17
Pick up MSI HD 7850 Power Edition.
08-08-2012, 08:56 PM #18
Get MSI, Good stability and is less prone to problems compared to Sapphire. I hate Sapphire compared to MSI , Zotac.
08-08-2012, 09:20 PM #19
dude, buy the msi pe, at this price , its the best vfm card.
Intel I5-2400 | Intel DH67BL B3 | MSI R7850 PE- benched @ 1250/1450 | Corsair xms3 4gb + Gskill Ripjawsx 4gb | Corsair cx500 v2 | Cm elite 430 | WDC BLUE 1tb | LG E2060T | APC RS 600 | CM HYPER 212 EVO | CORSAIR VENGEANCE 1500 / LOGITECH G300 / STEEL SERIES QCK MINI / LOGITECH C270 HD / WINDOWS 8 PRO /
Be Black or White, don't be Grey.
08-08-2012, 09:32 PM #20That Elusive 7850 HD
- Join Date
- Jul 2012
- Location
- Chennai, India.
- Posts
- 138
08-08-2012, 09:41 PM #21
08-08-2012, 09:59 PM #22That Elusive 7850 HD
- Join Date
- Jul 2012
- Location
- Chennai, India.
- Posts
- 138
08-08-2012, 10:51 PM #23
if u choose surface express(300/-) it will take 5 days. normal(100/-)will take more than a week.
i had a bad experience with them. on 25th july around 9pm i placed order. next day morning around 11.15am they called me to confirm the payment. i replied, will pay tomorrow. again next day same time they called, i didnt answer. after a hour i called them and enquired about price and stock. they said 16600+300 shipping. but the price in their website is 16800, i informed about it , they immediately updated the price. same day i made payment and send them payment details. after that they didnt contacted me regarding payment and shipping details.packaging, its a worst, they just covered with carton box(just two cartoon sheets taped as box) nothing inside the box to protect the graphic card.graphics card box seal is opened and no crossfire bridge connector inside. contacted them, they said all the boxes are opened and none of them has crossfire bridge connector.
hope the same will not happen with you.Intel I5-2400 | Intel DH67BL B3 | MSI R7850 PE- benched @ 1250/1450 | Corsair xms3 4gb + Gskill Ripjawsx 4gb | Corsair cx500 v2 | Cm elite 430 | WDC BLUE 1tb | LG E2060T | APC RS 600 | CM HYPER 212 EVO | CORSAIR VENGEANCE 1500 / LOGITECH G300 / STEEL SERIES QCK MINI / LOGITECH C270 HD / WINDOWS 8 PRO /
08-08-2012, 10:57 PM #24That Elusive 7850 HD
- Join Date
- Jul 2012
- Location
- Chennai, India.
- Posts
- 138
Woah! that's kind of lame to not have a crossfire link inside and opened boxes? WTF? One of the best things about buying any electronic item is the joy of unboxing. Not even gonna order from them if that's that case.
Did anyone else experience similar shortcomings with SMC international?Last edited by ram22693; 08-08-2012 at 11:07 PM.
08-08-2012, 11:23 PM #25
one more thing my delivery has been delayed. so i contact local bluedart branch, they said it will take another 15 days,iam shocked, then i contact smc international to help about this matter, they said we are not responsible and cut the phone(in rude voice). again called i said i have to talk to head of the authority, someone came and said will contact with bluedart and immediately will send the details in the mail. after five minutes i got mail. those I***ts just sent tracking no. on expected delivery date they are sending tracking no . myself contacted bluedart delhi branch and they said within two days it will deliver.
08-08-2012, 11:40 PM #26That Elusive 7850 HD
- Join Date
- Jul 2012
- Location
- Chennai, India.
- Posts
- 138
09-08-2012, 12:15 AM #27
flipkart service is excellent, even though some of the products rates are high, they satisfy the customer.
09-08-2012, 09:31 AM #28That Elusive 7850 HD
- Join Date
- Jul 2012
- Location
- Chennai, India.
- Posts
- 138
They don't have MSI 7850s.
09-08-2012, 10:43 AM #29
have u check local.
09-08-2012, 12:12 PM #30That Elusive 7850 HD
- Join Date
- Jul 2012
- Location
- Chennai, India.
- Posts
- 138
Yes, the local dealers (The whole of Ritchie Street) have only ASUS and XFX available and both cost more than 19K.
help me to buy a hd 7850
By IndianRambo in forum Graphic cardsReplies: 30Last Post: 05-08-2012, 06:02 PM -
Help me choose. 560 ti vs HD 7850
By darkrider99 in forum Graphic cardsReplies: 37Last Post: 01-07-2012, 07:27 PM -
Processor and Motherboard for work PC?
By NaifAmoodi in forum PC Components / ConfigurationsReplies: 7Last Post: 24-02-2012, 04:22 PM -
Will two DDR2 RAMs of different speeds work together on the same motherboard ?
By RockerKG in forum Hardware Q&AReplies: 5Last Post: 27-10-2011, 11:12 AM -
Will DDR2 RAM work on DDR3 supporting motherboard.
By sasuke in forum Hardware Q&AReplies: 6Last Post: 10-05-2010, 09:08 PM
LinkBack URL
About LinkBacks
