Results 1 to 17 of 17
  1. #1
    Apprentice elton_1991's Avatar
    Jul 2008
    Mumbai
    Default OC friendly graphics card up to 20k
    My current config:
    i5 2500k @4.6GHz (stock cooler )
    Asus P8Z68-M PRO
    Corsair XMS 3 4GB 1600MHz
    Corsair CX600 power supply
    MSI GTX260 TF II OC 216SP @695/1448/1178(summer) and 701/1448/1186(winter)
    Hey guyz,
    am looking to buy a graphics card that has good overclocking potential.I'm mostly a team Green(Nvidia) guy but as my motherboard does not have SLI support and there's no Nvidia 600 series in this price bracket, I've decided on getting a HD7850 as there's lots of good reviews about it and I want to make it a crossfire setup later on(will change PSU accordingly).Please suggest which one I should buy out of these:
    MSI Twin Frozr III
    Theitdepot - MSI Radeon HD7850 2GB DDR5 ATI PCI E Graphic Cards (R7850 Twin Frozr 2GD5-OC)
    MSI Power Edition
    Theitdepot - MSI Radeon HD7850 2GB DDR5 ATI PCI E Graphic Cards (R7850 Power Edition 2GD5-OC)
    SAPPHIRE Radeon HD 7850
    SAPPHIRE Radeon HD 7850 2GB 256-bit GDDR5 PCI Express 3.0 x16 HDCP Ready CrossFireX Graphic Card
    XFX Radeon HD7850
    Theitdepot - XFX Radeon HD7850 2GB DDR5 ATI PCI E Graphics (FX-785A-CDFC)
    Asus Radeon HD7850 (is this tri-slot?)
    Theitdepot - Asus Radeon HD7850 2GB DDR5 ATI PCI E Graphic Card (HD7850-DC2-2GD5)
    Also,if there is any better offer,please do tell.
    Thanks in advance!
  2. #2
    . fz8975's Avatar
    Jun 2011
    surat/anand
    Default Re: OC friendly graphics card up to 20k
  3. #3
    defeating my fears..... the_conqueror's Avatar
    Mar 2012
    Kanpur
    Go for the Sapphire one, or increase your budget by 1k and buy sapphire HD 7870.
  4. #4
    In The Zone saikiasunny's Avatar
    Feb 2011
    amritsar
    Go for the sapphire, gigabyte or the HIS 7850. Don't spend more than 16.5k on a 7850.
    If you can increase you budget by 1k get a 7870.
  5. #5
    Query Killer!!!!!! max_snyper's Avatar
    May 2006
    Mumbai
    IMO u can go for sapphire hd7850 it would be best as it has the same config as the oc version of the same card.(u can oc it better upto 920~950 mhz range with that heatsink)
    Isn't the prices of the OC versions of the card from msi,asus,xfx are way out of the price bracket...by almost 4k........!
    If some one can spent 2k more than that,they could buy a hd7870 oc version..!
    Intel 2500k ||Corsair H100||Asus p8z68v-pro ||Sapphire HD7950 vapor-x|| Corsair Carbide 400R || Gskill 8gb-sr2 || Corsair 850tx-v2 || Seagate 500gb || Viewsonic vx1940w
  6. #6
    vkl
    vkl is offline
    Super Moderator
    Apr 2012
    better get hd 7870 for around 21k.
    or check this GIGABYTE GV-R787OC-2GD
  7. #7
    In The Zone abirthedevil's Avatar
    Nov 2010
    Port Blair(A & N Islands)
    where are those 7850 prices from? planet mars? seesh 19k for a 15k card.................. and what have XFX been smoking of late their prices are uber high
  8. #8
    Jul 2008
    Mumbai
    Hmm..7870 is a tempting offer...but I am/was also buying a cabinet(NZXT PHANTOM 410 @6k)with the card,with a total budget of 25k.IF I am to get the HIS 7870,I wont get the cabinet.Also,would it fit in my Cooler Master 310 eclipse?
  9. #9
    Mar 2012
    Kanpur
    Get corsair carbide 400R @ 4.9k. Don't know wether it'll fit in your 310 eclipse or not .
  10. #10
    Jul 2008
    Mumbai
    @conquerer
    Sorry but its the 410 or bust .400R and others in that price look plain or too business to me lol
  11. #11
    BMG ftw!! d6bmg's Avatar
    Aug 2011
    Kolkata
    My current config:
    Strictly avoid OCing at first.
    About graphics card, buy Gigabyte 7850 2GB from SMC.
  12. #12
    Jul 2008
    Mumbai
    Quote Originally Posted by d6bmg View Post
    Its been that high since I bought it in January with max temp. around 81-86 degrees.
    Anyways,checked out the Gigabyte 7850 reviews on other forum and sites, and it looks like it's either faulty or the fan's too loud.Plus overclocking wise its no good. =/
    OK,checked a lot of reviews of the HIS HD7870 IceQ Edition...hook,line and sinker! Gonna get it as soon as my exams get over in 1st week of july.
  13. #13
    Feb 2011
    amritsar
    The 7870 iceQ is an amazing card. But keep in mind that the cooler uses more than 2 slots but other than that its a Beast
  14. #14
    Jul 2008
    Mumbai
    Quote Originally Posted by saikiasunny View Post
    What!?! Are you sure?Because that would mean I have to select some other brand or fit a different cooler (which i have no intention of doing as its
    expensive in india) when adding another 7870 or 7850...
  15. #15
    In The Zone dibya_kol's Avatar
    Dec 2011
    kolkata
    first of all i must say ur cpu temp is a bit high. U should nt oc with stock intel cooler. Get CM hyper 212 evo ( low price and damn good one in it's class).
    For gpu, go for 7870 and chk reviews(gpu and mobo) for space if u have plan of cfx in future.
    | i5-2500k With CM Hyper 212 EVO | Biostar TZ68K+ | 8GB(4x2)G.Skill RipjawsX | XFX 5770+240GT PhysX | LG E2240(22'' LED) | Corsair vx 550 | Cooler Master 690 |
  16. #16
    Jul 2008
    Mumbai
    Quote Originally Posted by dibya_kol View Post
    Yes,I know...Hence the reason for wanting to get a new cabinet as the motherboard plate in my current one does not have a window for the cooler support plate to come out..
    As for the 7870,only HIS and Gigabyte offerings are under 23k,other all are 25k and above.
  17. #17
    Feb 2011
    amritsar
    The gigabyte one is also gud, you can go for that too!
  1. Dual graphics card or a single high end graphic card
    By Gamersam in forum Graphic cards
    Last Post: 13-05-2012, 12:36 AM
  2. Intel HD Graphics with Dedicated Graphics Card
    By RazorbladeXtreme in forum Hardware Q&A
    Last Post: 02-08-2011, 03:16 AM
  3. Replies: 1
    Last Post: 19-06-2008, 12:39 AM
  4. Tv tuner card / Graphics card for my config ...
    By gsenthil in forum PC Components / Configurations
    Last Post: 08-09-2006, 07:23 PM
