Results 1 to 23 of 23
Thread: gpu help
16-05-2012, 12:40 PM #1Right Off the Assembly Line
- Join Date
- May 2012
- Posts
- 11
gpu help
i want to buy gpu budget of 10000k and i had think about corsair gx 800 watts psu but my friend told me to buy nvidia card because it has nvidia physics so please recommend me a good card
17-05-2012, 05:08 AM #2
Re: gpu help
Do you have the GS800 PSu ? If yes opt for GTX 560 - this is the best gfx card you can get at 10k.
Who Dares Wins
Avenging Angel !
Phenom II 955BE↔Asus M5a97 R2.0↔Corsair 2x 4GB RAM↔HD6850↔Corsair GS600↔CM Hyper 212↔CM 430 Elite
My Blog : http://topgeartopspeed.wordpress.com/
BlackListed : Viewsonic, Gigabyte
17-05-2012, 09:18 AM #3Right Off the Assembly Line
- Join Date
- May 2012
- Posts
- 11
Re: gpu help
i dont have Gs800 psu but i will get it. but at 10k GTX 560 is not available in my colony or in raipur. my friend has GTX 560ti it is a very good card but it has many problems like black screen problem my friend has faced many problems. he has changed 4 to 5 times his card all of them are faulty but at last he has got GTX 560ti Gone edition which is really good
but i am thinking about GTX 550 ti which is available at 8.5k.
17-05-2012, 09:49 PM #4Pro/An---tagonist xD
- Join Date
- Dec 2009
- Location
- Kolkata
- Posts
- 1,135
Re: gpu help
That is a really poor choice :\ 550ti is a lame card. too much power consumption for the performance it offers.
Desktop :- Amd athlon II X3 435 unlocked to Phenom II X4 B35 | MSI 785 G-E53 | MSI R6850 Cyclone power edition [OC edition] | Corsair Vengeance 4GB DDR3 RAM @ 1600 Mhz | Corsair GS600 | Seagate 500 gb 7200.12 | Cooler Master CM 690II Advanced | Dell ST2220L |
Laptop:- Dell Inspiron 15R Turbo => i5-3210m,4gb RAM, 1 tb HDD, AMD HD 7730M 2gb.
17-05-2012, 09:56 PM #5
17-05-2012, 10:50 PM #6Right Off the Assembly Line
- Join Date
- May 2012
- Posts
- 11
17-05-2012, 11:51 PM #7Super Moderator
- Join Date
- Apr 2012
- Posts
- 821
Re: gpu help
Dont go for 550 ti.
Instead pick up radeon 6850 at 8.5k.
It performs much better than 550 ti.
Physx is not worth it especially with the kind of performance hit it has on gameplay and that too with a card like 550ti.
Pick up radeon 6850 for better gameplay.
If you can expand your budget then go for 560ti or else get the 6850.
18-05-2012, 12:19 AM #8
18-05-2012, 12:50 AM #9
Re: gpu help
turn Physx on these sub-560 GPU and game. you'll get Physics. nothing else. no framerates.
18-05-2012, 04:11 AM #10
Re: gpu help
get this :
MSI N560GTX-M2D1GD5Who Dares Wins
Avenging Angel !
18-05-2012, 08:28 AM #11Right Off the Assembly Line
- Join Date
- May 2012
- Posts
- 11
18-05-2012, 09:20 AM #12
Re: gpu help
PhysX is a Gimmick.
HCL ME | Intel i3 310M | 320 GB | 2 GB DDR3 1333 MHz |
HP ENVYM6 | Intel i5 3210M 2.5 GHz | 8GB DDR3 1600 Mhz | AMD Radeon 7670M | 1TB
Samsung Galaxy Tab 2 |7.0 P31000
18-05-2012, 12:25 PM #13
Re: gpu help
should be available but surely not at this price.
if you have a powerful GPU, a game that really uses Physx (not just shows Physx logo on startup) like Mafia II then its fun. Else yes its a Gimmick for most. And they learn soon after they buy their favorite Nvidia GPU.
18-05-2012, 12:29 PM #14
19-05-2012, 08:22 PM #15Right Off the Assembly Line
- Join Date
- May 2012
- Location
- Bangalore, India
- Posts
- 8
20-05-2012, 12:35 AM #16
Re: gpu help
20-05-2012, 01:29 AM #17Alpha Geek
- Join Date
- Jun 2005
- Location
- The New World Order
- Posts
- 657
Re: gpu help
HD 6850 or Palit GTX 460 V2. If you can buy online, go for MSI or Sparkle GTX 560 since these two brands have lesser reports of black screen for 560/560 Ti cards.
Last edited by Happy Bytes: Today, at 3:45 AM. Reason: added a signature spreading worm....
20-05-2012, 08:29 AM #18
20-05-2012, 01:01 PM #19Right Off the Assembly Line
- Join Date
- May 2012
- Posts
- 11
20-05-2012, 03:39 PM #20
Re: gpu help
Fsg saga 500 is a good choice. . .it wil easily handle Gtx560. .
Amd athlon x2 260 3.8 ghz ocd |4gb starlite ddr3 1333 mhz |Gigabyte GA-ma78lmt-S2p|Xfx Amd Radeon hd 6670 1gb ddr5 |WD caviar blue 500gb |LG flatron l1515s | :-D
Samsung monte(s5620)|Frontech jil-1731 controller:razz
sony srs-d4 :-)
20-05-2012, 10:04 PM #21Right Off the Assembly Line
- Join Date
- May 2012
- Posts
- 11
Re: gpu help
thanks but fsp saga will available in raipur or i will have to buy online. previously i was thinking about gs 800 watt psu but fsp saga will handle GTX 560 then its ok
my system config is
core2DUO e7500
4 GB RAM ddR3
ASUS P5G41-TMLX motherboard
and currently having intex 450 Watt psu and
Zotac 440 gt DDr3 1gb
20-05-2012, 10:36 PM #22
Re: gpu help
saga 500 is more than enough fr you. . if u dnt get localy,buy online. ..
sony srs-d4 :-)
21-05-2012, 12:38 AM #23
Re: gpu help
LinkBack URL
About LinkBacks
