Results 1 to 30 of 56
Thread: Graphics Card for 1920*1080
12-05-2012, 08:11 PM #1
Resolution : 1920*1080
Should RUN games (Full Settings) : COD, NFS , FIFA etc.
Budget : 12K (Can extend, if worth spending more)
Is 6850 or 6870 sufficient OR Should I wait for prices to fall ? ?Phenom x6 1055T 3.36 GHz | MSI 890GXM G65 | Corsair XMS3 2*4GB 1600mhz | BenQ E2200HD | Xbox 360 Controller | Seagate 500GB | Seagate GoFlex 3.0 2TB | WD My Book Essential 3.0 1TB | CM HAF 922 | Corsair VX 550 | Logitech MX 518 | Logitech Wireless Keyboard | Sapphire 7850 OC | APC 1kVA | Razer Goliathus Control | Logitech C270H | Hyper 212EVO (Push Pull) | Asus RT N13U on DD-WRT |
12-05-2012, 08:13 PM #2
Re: Graphics Card for 1920*1080
HD 7850 2GB @ 15K. <== get this.
AMD A8-3870K with Radeon HD 6550D | Digilite A55M (Foxconn)
| 2 * 4 GB Corsair 1600 Mhz Value RAM | Corsair CX430v2 | NZXT Gamma | Dell S2240L 22" @ 1080p
Intel i5-2500K | Asus P8Z68 Deluxe | 2 * 4 GB Corsair Vengeance | WD Caviar Blue 500 GB | CM Hyper 212 Evo | AMD Radeon HD 6950 2 GB | NZXT Tempest Evo | Corsair AX850 | AverMedia AverTV Capture HD H727
Samsung Galaxy S2 | Mac mini (Late 2009) with OS X Mountain Lion, 10.8
Pandaboard ES | OMAP 4460 SoC | 2 * ARM Cortex A9 cores | PowerVR SGX540 graphics
Arch Linux amd64 | Ubuntu 12.04 amd64 + omap4 ARM | Windows 7 x64
12-05-2012, 08:49 PM #3
How is MSI N560GTX-Ti Twin Frozr II 2GD5/OC compared to 7850 (same price) ?
12-05-2012, 08:51 PM #4
HD 7850 is faster. Consumes less power. Current generation. Overclocks more - if you care. You get 2 GB of memory by default.
12-05-2012, 08:53 PM #5
Will there be any price fall in 1-2 months ?
12-05-2012, 09:31 PM #6
7850 is more or less rightly priced ATM.
Dont bother much about the price downfall in next 2-3 months.
It wont be any thing like drastic!HCL ME | Intel i3 310M | 320 GB | 2 GB DDR3 1333 MHz |
HP ENVYM6 | Intel i5 3210M 2.5 GHz | 8GB DDR3 1600 Mhz | AMD Radeon 7670M | 1TB
Samsung Galaxy Tab 2 |7.0 P31000
12-05-2012, 10:03 PM #7
In india its really hard to predict or even anticipate price drops. US price changes also reflect here but after a while. Currently 7850 has no competition and 560-ti is last gen as pointed by ico and isn't recommended now considering its higher power requirements and relative lower performance.
660-ti and 660 from nvidia are the real competitors of 7870 and 7850 respectively but those cards are a couple of months away or even more. Until these show up in indian soil, i don't think 7850 will undergo any price drop anytime soon.
So 15k is a fair price considering lack of competition so its a no brainer to grab a 7850. Its far more efficient and offers better performance per watt than 560-ti.Core i5 750, biostar h55 A+ (X16+X4), 4gb 1333 ddr3, corsair vx450, cm elite 335,Asus EAH 5750 FORMULA , samsung 2033 sw plus, wd green 1tb , wd 1tb my book ,Seagate freeagent ext hdd 1tb , hp dvd writer,Apc 650 va, logitech z313 , Micromax Funbook , Klipsch image S3 (IEM).
12-05-2012, 10:23 PM #8
Ok...MSI or Sapphire or Gigabyte ?
12-05-2012, 10:25 PM #9
^^ Get the one which is cheapest and comes factory clocked.
12-05-2012, 11:00 PM #10
The gigabyte is the fastest considering the clocks, but has some fan related issues. The best would be sapphire dual fan edition, but its not factory overclocked. Though you can always manually overclock it if you have such a nice cooler
12-05-2012, 11:11 PM #11Phenom x6 1055T 3.36 GHz | MSI 890GXM G65 | Corsair XMS3 2*4GB 1600mhz | BenQ E2200HD | Xbox 360 Controller | Seagate 500GB | Seagate GoFlex 3.0 2TB | WD My Book Essential 3.0 1TB | CM HAF 922 | Corsair VX 550 | Logitech MX 518 | Logitech Wireless Keyboard | Sapphire 7850 OC | APC 1kVA | Razer Goliathus Control | Logitech C270H | Hyper 212EVO (Push Pull) | Asus RT N13U on DD-WRT |
12-05-2012, 11:41 PM #12
GV-R785OC-2GD GIGABYTE @ 15.2k
This is the model to get. Has a dual fan design and comes factory clocked. These windforce cards have become a hit recently.
Sapphire 7850 dual fan edition @ 15.6kLast edited by vickybat; 12-05-2012 at 11:50 PM.
13-05-2012, 08:21 AM #13
13-05-2012, 10:18 AM #14
Yeah.. They r reliable dude
If you Don't have a UID card Then Visit Bangladesh Once n buy it for 100 Inr..
13-05-2012, 10:31 AM #15
13-05-2012, 11:53 AM #16
13-05-2012, 12:37 PM #17
13-05-2012, 12:42 PM #18
^^ thanks for confirming
13-05-2012, 02:56 PM #19
Going with 7850
Confused between : Gigabyte or Sapphire ??Phenom x6 1055T 3.36 GHz | MSI 890GXM G65 | Corsair XMS3 2*4GB 1600mhz | BenQ E2200HD | Xbox 360 Controller | Seagate 500GB | Seagate GoFlex 3.0 2TB | WD My Book Essential 3.0 1TB | CM HAF 922 | Corsair VX 550 | Logitech MX 518 | Logitech Wireless Keyboard | Sapphire 7850 OC | APC 1kVA | Razer Goliathus Control | Logitech C270H | Hyper 212EVO (Push Pull) | Asus RT N13U on DD-WRT |
13-05-2012, 06:31 PM #20
Sapphire for sure. Get it, overclock it, enjoy it
. Heard that gigabyte one had some noise problems, but I m not sure...
13-05-2012, 07:08 PM #21
Not available with SMC...
13-05-2012, 07:18 PM #22
Try searching local market and few more online shops like Theitdepot - India's First IT Online Shopping Store and hardwire.in
13-05-2012, 07:39 PM #23
In Gigabyte card...there is noise problem with fans..
Newegg.com - GIGABYTE GV-R785OC-2GD Radeon HD 7850 2GB 256-bit GDDR5 PCI Express 3.0 x16 HDCP Ready CrossFireX Support Video Card
There is solution as well
1) The vibration comes from a flimsy piece of plastic under the fan closest to the video ports. If you loosen the three screws that hold that fan in, lift up the fan and push on the plastic, you will feel how loose and flimsy it is and that it doesn't quite touch the aluminum tightly enough. If you shim a piece of electrical tape that's been doubled a few times under this piece of plastic, the vibration ceases!
2) http://www.gigabyte.com/support-down...=1876&pid=4155
I never bought anything from stores other than SMC...But they don't have Sapphire 7850 (as per their site)...Should I go with Gigabyte or ask them to arrange Sapphire 7850 ?Last edited by bajaj151; 13-05-2012 at 08:41 PM.
13-05-2012, 07:50 PM #24
13-05-2012, 10:16 PM #25In The Zone
- Join Date
- Apr 2012
- Posts
- 220
13-05-2012, 10:33 PM #26
Sapphire : 16,500 (hardwire)
Gigabyte : 15,200 (smc)
Worth paying extra 1300 ?Phenom x6 1055T 3.36 GHz | MSI 890GXM G65 | Corsair XMS3 2*4GB 1600mhz | BenQ E2200HD | Xbox 360 Controller | Seagate 500GB | Seagate GoFlex 3.0 2TB | WD My Book Essential 3.0 1TB | CM HAF 922 | Corsair VX 550 | Logitech MX 518 | Logitech Wireless Keyboard | Sapphire 7850 OC | APC 1kVA | Razer Goliathus Control | Logitech C270H | Hyper 212EVO (Push Pull) | Asus RT N13U on DD-WRT |
13-05-2012, 10:58 PM #27In The Zone
- Join Date
- Apr 2012
- Posts
- 220
SAPPHIRE HD7850 2GB GDDR5
For 15,600 (mdcomputers)
14-05-2012, 04:54 AM #28
@ bajaj151 - build quality of Sapphire HD7850 looks solid.
Who Dares Wins
Avenging Angel !
Phenom II 955BE↔Asus M5a97 R2.0↔Corsair 2x 4GB RAM↔HD6850↔Corsair GS600↔CM Hyper 212↔CM 430 Elite
My Blog : http://topgeartopspeed.wordpress.com/
BlackListed : Viewsonic, Gigabyte
14-05-2012, 08:38 AM #29
14-05-2012, 09:46 AM #30Professional Newbie
- Join Date
- Apr 2012
- Location
- At Home : 22.5697° N, 88.3697° E
- Posts
- 372
^^ Sapphire one has a really great cooler whereas the cooler on the HIS is not that great. In our Indian weather conditions it's always wise to get the coolest card you can, whether you wanna OC or not. And of course for OCing a good cooler is required thus the Sapphire is the obvious choice. Even I'm getting one personally today or tomorrow
monitor when browsing 1920/1080
By dfcols71 in forum Hardware Q&AReplies: 2Last Post: 03-06-2012, 05:31 PM -
Intel HD Graphics with Dedicated Graphics Card
By RazorbladeXtreme in forum Hardware Q&AReplies: 5Last Post: 02-08-2011, 03:16 AM -
having problem in watching 1080 HD vidoes
By ravi23 in forum Software Q&AReplies: 10Last Post: 03-06-2010, 09:29 AM -
finally gone 1902*1080
By chicha in forum Chit-ChatReplies: 13Last Post: 03-07-2009, 06:31 PM -
My graphics card not Supporting Turbo C++ graphics plz help
By Maxx32 in forum Graphic cardsReplies: 1Last Post: 19-06-2008, 12:39 AM
LinkBack URL
About LinkBacks
