Results 1 to 4 of 4
  1. #1
    asia://india/ka/bangalore a_to_z123's Avatar
    Nov 2004
    Bangalore, India
    Default Difference b/w Vector based & Raster based graphics
    Hey I wanted to know this:
    What is the difference b/w Vector & Raster graphics?
    I've just heard a few things about it, that Vector graphics can be scaled to any dimensions without distortion, etc.
    Is this true?
    And, whether Corel Draw is Vector based??
    Please enlighten me on this issue. Can someone explain in detail??
    :) I've got my F, C and K . Now all I need is You !!! :)
  2. #2
    Mar 2005
    Computer graphics falls into two main categories--bitmap and vector. Understanding the difference between the two categories helps as you create, edit, and import artwork.
    Bitmap Images
    ! Bitmap images--technically called raster images--use a grid of colors known as pixels to represent images. Each pixel is assigned a specific location and color value. For example, a bicycle tire in a bitmap image is made up of a mosaic of pixels in that location.
    ! When working with bitmap images, you edit pixels rather than objects or shapes. ! Bitmap images are the most common electronic medium for continuous-tone images, such as photographs or digital paintings, because they can represent subtle gradations of shades and color.
    Bitmap images are resolution-dependent--that is, they contain a fixed number of pixels. As a result, they can lose detail and appear jagged if they are scaled onscreen or if they are printed at a lower resolution than they were created for.
    Bitmap images are good for reproducing subtle gradations of color, as in
    photographs. They can have jagged edges when printed at too large a size or displayed at too high a magnification.
    Vector graphics
    ! Vector graphics are made up of lines and curves defined by mathematical objects called ‘vectors’. Vectors describe an image according to its geometric characteristics. For example, a bicycle tire in a vector graphic is made up of a mathematical definition of a circle drawn with a certain radius, set at a specific location, and filled with a specific color. You can move, resize, or change the color of the tire without losing the quality of the graphic.
    ! Vector graphics are resolution-independent--that is, they can be scaled to any size and printed at any resolution without losing detail or clarity. As a result, vector graphics are the best choice for representing bold graphics that must retain crisp lines when scaled to various sizes--for example, logos.
    ! Vector graphics are good for reproducing crisp outlines, as in logos or
    illustrations.
    ! They can be printed or displayed at any resolution without losing detail.
    Because computer monitors represent images by displaying them on a grid, both vector and bitmap data is displayed as pixels on-screen.
  3. #3
    Nov 2004
    Bangalore, India
    Well that was good, but is that all I need to know!
    Anyone else who can also give his views on the topic.
  4. #4
    Feb 2004
    New Delhi
  1. Replies: 42
    Last Post: 07-11-2008, 01:03 PM
  2. Replies: 1
    Last Post: 21-08-2008, 04:07 AM
  3. Mac OS X on X86 based System...
    By prankie in forum Software Q&A
    Last Post: 27-03-2006, 01:14 PM
